komatsu left steering clutch problem
/ komatsu left steering clutch problem #1
DeArmond
greenville ky
komatsu d20p,IH706,caseIh459,mahindra 4500
when operating on a flat plane clutch wont work , but when you nose the trator down hill clucth work like a charm is this a clucth, break, or a linkage problem?
/ komatsu left steering clutch problem #2
Since the clutches are disengaged by applying pressurised oil, im wondering if you are just low on hyd oil.
/ komatsu left steering clutch problem #3
Thats what it sounds like to me too but I'm confused why it should just be the left side
this one is a old straight shift tractor ,left clucth paddle two hand controls for steering right paddle breake the right clucth works but makes nose like its breake needs adj . my dozer is a d20p-5 s/n 45001 and up range (an old rice patty special)
/ komatsu left steering clutch problem #5
You got me stumped there. I only have experience with powershift wet clutch models and newer. Sorry i cant help ya.
/ komatsu left steering clutch problem #6
If you haven't already I'd try to adjust the steering clutch on that side. At the rear of the dozer (on my d20p6) there are removable plates with a 17mm adjustment bolt under it. It can be hard to move if not adjusted in a long time. Bring a breaker bar and wd40 just in case.
thanks boys wil-do
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
100 gal Portable Fuel Tank (A66408)
100 gal Portable...
2022 EZ-GO ELITE...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
1992 Jeep Cherokee (MPV), VIN # 1J4FJ78S6NL230132 (A65563)
1992 Jeep Cherokee...
