RTV 900 radiator
/ RTV 900 radiator #1
ManyFoldFarm
Chattahoochee Hills, GA
I have a ~10 year old RTV900W, and my radiator is very rusted and now leaking. I suspect the prior owner ran tap water in it. I'd like to replace it, but the dealer price on the part is really high (>$450). I noticed that it is a Denso part, but the part number is worn away on mine.
Can anyone tell me the Denso part number of the radiator and/or suggest a way to get a less expensive replacement?
/ RTV 900 radiator #3
It is going to be expensive to replace regardless of where you get it, BUT, find a radiator repair shop. They can custom make one for you from solid brass core and tank tops for about that price. I had the one on my JD 332 garden tractor custom made for around $300 compared to over 500 from JD and it was plastic tops with aluminum core whereas the radiator guy used all brass.
/ RTV 900 radiator #4
Ditto on using a radiator repair shop. We've had one of the larger shops in Phoenix rebuild a couple for us using a larger core in place of the original. Cost less that the OEM.
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
Zero Turn Mower (A59231)
Zero Turn Mower...
JOHN DEERE 3025E TRACTOR (A62130)
JOHN DEERE 3025E...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
UNUSED CFG INDUSTRIAL QH12R MINI EXCAVATOR (A62130)
UNUSED CFG...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A61165)
2016 Hino 195h...
