Will Trade Ags for R4s.
/ Will Trade Ags for R4s. #1
Short Game
Sunny SW Washington
LS R4010 & Cub Cadet 7300
When I got my used 7300, I learned by the time I drove it the 50 feet from the trailer to its new house that ag tires were not going to work here. They really tore up the ground, even going straight. I now have it on the foamed R4s from my old tractor. If I ever get my old 7274 going again, I will want R4s on it too.
The ag rears are loaded with calcium and all have only 250 hours on them.
Front is 7.2-16, rear is 12.4-24.
So, I would trade for Cub Cadet wheels and R4 tires: rear: 27x8.5-15 and front: 15-19.5.
I am in SW Washington State between Longview and the coast.
/ Will Trade Ags for R4s. #2
if you were closer i would trade with you you shouldnt have any trouble trading i would put the word out at your local dealers alot of used tractors are sold with 4s on them and a lot of people want the ags
/ Will Trade Ags for R4s. #3
Checking the JD online manual, mine are close but not quite.
I'm going to double check when I get home.
Edit; no there not even close, got to excited and read it wrong. Dang it.
I would need them to bolt on my 7274.
Possible matches are the 1991 Case IH 1140, and Mahindra 2815, 3015, and 3215. I believe these are all from the same Mitsubishi built base as the Cub Cadet 7*** series.
what about mahindra 2816?
I see the R4s are the same size, and both tractors are Mitsubishi built. The Cub Cadet Ags are larger than the 2816's. So these ag tires would probably be an upgrade for a Mahindra (if they'll fit under the fenders). The question would come down to the bolt hole sizes and pattern, and the size of the center holes in the wheels. My guess is they would be the same and interchangeable.
Mahindra 2816 Tires:
Ag front: 7x16
Ag rear: 11.2x24
Industrial front: 27x8.5-15
Industrial rear: 15x19.5
(From Tractor Data at: TractorData.com Mahindra 2816 tractor dimensions information)
Cub Cadet 7300 Tires:
Ag front: 7.2-16
Ag rear: 12.4-24
Industrial rear: 15-19.5
(TractorData.com Cub Cadet 7300 tractor dimensions information)
