New7040 tire option
/ New7040 tire option #42
Goods specs, if I counted correctly that's 2.2" taller, I'm not sure if it would make a ratio difference but that's not a huge difference in sizes
/ New7040 tire option #43
The circumference is not much different. I found a place before that had the revolutions per mile but I can't. It was not much different either.
/ New7040 tire option #44
2.2" taller is quite a lot of inches in circumference. 8" to be exact. Static radius is what is important for gearing calculation though. The radius as measured from the center of the axle to the ground, specifically, due to squat. I'm wondering if you couldn't lower the air pressure to get the same radius measurement where it counts. Those tires show a static radius difference of 0.9". That much will definitely put the driveline in a bind unless the air pressure is adjusted down significantly or a half inch or so is ground from the bar height.
The front axle is already geared to pull more than the rear when in FWD, adding circumference will only ask the front axle to pull even more while engaged.
/ New7040 tire option #45
I would just like to have a wider front tire for better loader working ability and that way it shouldn't change the gear ratio
/ New7040 tire option #46
I'm with you on that one. The problem is that any of the wider tires that we've found are also taller. Tall enough to cause backlash and strain in the driveline. Thus the conundrum.
I dunno I ran mine 8hrs pulling 15ft batwing and several hours doing loader work,I just haven't seen/felt/heard anything. I don't run very much 15lbs front,10lbs back...
/ New7040 tire option #48
I wish I had a number to call Kubota directly and ask someone on their end and see what ranges of ratios are safe
/ New7040 tire option #50
Nauxier, my local dealer didn't want to sell me the wheels and tires because he said Kubota's position on it was "not recommended due to driveline stress." I want to hear it direct from Kubota though.
/ New7040 tire option #51
Yeah that would be nice to get an answer from them
/ New7040 tire option #52
11.2-24: 491 revolutions per mile
9.5-24: 510 revolutions per mile
Was the front axle engaged doing those tasks?
Yeah running in 4x4,the hills I had to pull mowing where pretty good ones and sandy so just left it in 4x4. I really haven't thought to much about it,just operate it the same as the other 7040..
/ New7040 tire option #54
My local dealer says a change to 11.2 x 24 front tires will damage driveline over the "long" hours. The 7040 in Canada are often sold with 360R/70x20 (R1 W)tires. According to the Michelin tire book this has the same rolling circumference as 9.5 x 24.
I was told that the 360R/70x20 is the very close to 12.2 x20 but have not seen that in writing. Another thing is the cost, 360R/70x20, R1 W is about $750 per tire plus the wheel. 12.2 x 20 should be cheaper as it is often found on New Holland TN series.
/ New7040 tire option #55
/ New7040 tire option #56
I've researched going to 11.2-24's on my 7040 a lot. I've talked to my dealer and several others and nobody really had an answer. All you really need to know is the front to rear drive ratio and you could do the calculations yourself. The problem is nobody seems to know the number. You generally want a 0-5% overrun in the front. "If" the 9.5's were around zero, then the 11.2's would be just under 5%, depending on manufacturer.
I've talked to several people directly at Kubota, also. No one has been able to tell me the actual front/rear ratio. The most knowledgable person I talked to, though, said that it would be fine to run 11.2-24's on the front with the stock rear tires.
/ New7040 tire option #57
What about the 5040 and 6040? They use the same 9.5 fronts as the 7040, but have smaller rear tires. Do they have a different front to rear gear ratio? It doesn't seem like it would make sense for kubota to have different gears in them.
/ New7040 tire option #58
Check on the Firestone SAT II 23 R1 in the 11.2 x 24 size. They seem to be a slightly lower profile than others ... come in 4 and 8 ply. This would probably give a roll radius between normal 9.5 and 11.2. A little extra front lead is good. :smile:
Firestone Super All Traction II (SAT II) 23 R-1 Tires at SimpleTire.com
/ New7040 tire option #59
Just wondering if anyone has anymore updated information on whether they have swapped to the larger front tires on a 7040 or 7060 and if they have had any problems?
Thanks
6E7C77EA-2B34-4B8F-AA9B-908574F4A766.jpeg just bought new set fronts. It’s been around 8yrs and 1400+hrs, no issues to date.
36in AIM Tooth Excavator Bucket (A64194)
36in AIM Tooth...
2005 Nissan Frontier Crew Cab Pickup Truck (A61573)
2005 Nissan...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2017 Ford F-250...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
iDrive TDS-2010H...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
