JohnDeere391
Member
Is it ok to hook up a 48 backhoe with the 3 point hitch?
Ok lets see the #7 backhoe
i lift it up and it slides into place and i put the pins in and release the pressure and connect the lines
Not with the 3 point on but i lift it up and it slides into place and i put the pins in and release the pressure and connect the lines
I get that its ok to us the 3pt hitch but why not just use the downriggers and bucket? I just back up over the frame close enough to hook up the hydraulics and done, 30 seconds.
While the #7 is an older styly backhoe, one of the things I like about it is the fact that it has a "stack valve" setup on it instead of a solid one-piece valve body. The very first thing I did before using mine was to separate the stack of valve and reorder them to obtain the SAE (aka Cat) pattern instead of the IMO retarded ISO (aka John Deere) pattern. Something I wouldn't have been able to do on a one-piece valve body.
