Soundproofing the B3030 Cab and found something interesting
/ Soundproofing the B3030 Cab and found something interesting #41
WaxMan,
Have you thought about installing Dynaliner inside the cab on the seat pan and back wall under the back window? I'm thinking that will absorb a lot of unwanted in-cab sounds. Do you think that stuff would be fairly easy to clean - ie. vacuum & wipe down with a damp rag every so often? I want to cut down on the amount of exposed sheed metal inside the cab. I think that grey Dynaliner would look ok on the grey sheet metal.
I plan to leave the orange fenders alone inside, but am seriously considering adding something like this to the exterior wheel wells: Spectrum - 1 Gallon - Second Skin Audio
I did put it under the seat, I'm hoping what I am doing underneath the cab will be enough, I want it to look as much factory as possible. I'm sure that stuff would work ok back there but not sure about the look. Did you notice the new Kubota has a inside liner on the wheel wells? I wonder if that will match up to our inside fenders?
/ Soundproofing the B3030 Cab and found something interesting #43
Looks like there are enough minor differences that the new liners may not work. That's why I'm considering lining the wheel wells and throwing a pad material on the seat pan. I've found a product that doesn't have an adhesive backing on the pad, so it could just be cut out and laid on the horizontal surface of the seat pan. I thought about some automotive carpeting, since that would absorb some of the in-cab noises, but I'm concerned that may hold too much dirt. The sound absorbing high density vinyl infused pad might be easier to clean.
/ Soundproofing the B3030 Cab and found something interesting #44
Do's and don'ts
Ok made a mistake today, well probably made many but this one I know about.
I thought it would be a good idea to put a small strip of the sound deadener on the sides as shown in the first pictures. After all the fenders and the floor bolt together metal to metal.
The Extreme is only 1/16 thick. I thought it would make a nice gasket. But once tighten down it squeezes out and leaves a sticky seal which is just going to get covered with dirt. I don't like it. So I will have to take the two panels back out and remove the side strips. Seems the Extreme is not good under pressure, it's meant to be just on a panel not squeezed. I think it will just keep squeezing out until metal to metal again.
Now I think I should also remove the Extreme on top and below the waffle mount and have the rubber mount be touching the bare metal on top and bottom. At first I thought it would be better with a little more movement, but now I'm not sure? any Idea's? about the Extreme on top and below the waffle mount? Over time it's just going to squeeze out. What do you guys think leave it under and over the mount or remove it.
I like this Daynamat Extreme I can see I'm going to be using a lot of this stuff under the plastic dash, this is where most of the dirt is entering the cab, being blown in from the engine fan. This I knew for years after having the cover off before. Just didn't know how to stop it. This Extreme can cover all the holes. Also around the wires entering the cab.
i think I would leave the extreme on the seam and let it ooze out, then wipe it down with acetone (basically to make it like "seam Sealer")
This item is the best for that , too bad the white lettering, that is why I'm using it under the floor mat.
You should wait and see what doing the underneath brings, it might be good enough. I'll be done with mine in a few days or by next weekend.
Dynamat 21100 Dynapad | eBay
/ Soundproofing the B3030 Cab and found something interesting #46
I found an online retailer selling commercial versions without any lettering. I guess they cut your order off of a huge roll. There's also versions out there with black lettering. I figure no one's gonna see it but me, and even then, it wouldn't take long before I don't even notice it when I'm climbing in and out.
/ Soundproofing the B3030 Cab and found something interesting #47
dynamat is rather expensive and mostly paying for the name. Check ebay for similar products that use same material and with greater thickness with no name attached like mentioned. At a fraction of the cost
/ Soundproofing the B3030 Cab and found something interesting #48
I've been looking into Second Skin products. They seem to have quite a following in the audiophile community, but may actually be more expensive than Dynamat products. I like the idea of getting everything I need from one place, and they have a liquid undercoating product that I want to put on the wheel wells since I don't want to cover the orange fenders inside the cab.
Their Luxury Liner Pro can be used under the rubber floor mat, as well as on the seat pan and the back vertical cab section under the back window, as it is a charcoal grey color, and is an easy to clean vinyl top layer bonded to a closed cell foam under layer. The only portion I would have to adhere would be the vertical surface under the window, and I think that will be a better option than attempting to install the foil mat on the outside of that section, since it is visible. All of that can go inside the cab, while the Damplifier Pro black foil/butyl adhesive sheets can go on the underside of all the sheet metal sections of the cab floor & seat pan.
Then I will use a closed cell foam to seal up all the little cracks & crevices around the cab, which will help to further cut down on dust, though surprisingly, I didn't have very much making it into the cab last fall when I was doing some work that covered the entire outside of the machine. The dust layer was so bad, I had to blow it off the windows each day so I could see in the early/late day sunshine.
/ Soundproofing the B3030 Cab and found something interesting #49
OK, so I ordered some products today. I got the Dynamat Xtreme because I found it cheaper on Amazon than I could get the Second Skin Damplifier Pro for, and with cashing in some of my Amazon points, was able to get it at no charge to my credit card. I ordered the Luxury Liner Pro & Spectrum undercoating from Second Skin, however. I think the Second Skin products are slightly better than the Dynamat products, but couldn't resist the deal on the Xtreme - I'm sure it will do a very good job. Xtreme is 1.7 mm compared to 2mm thick for the Damplifier Pro.
I have a bunch of miscellaneous foam backer rod & foam weatherstripping from previous projects that I will also make use of to seal off seams - basically anywhere I can still see daylight will get that product, and possibly inside some of the hollow frame channels that I can get to. I haven't decided exactly what I will use between the headliner and plastic roof panel, but am leaning toward some egg crate foam just to add a little additional sound absorption at the roof.
I have some spare 1/2" rubber isolation mat in my shop that I will use at that small area where the floor pan sits directly on the transmission. That product has open holes in it that may need to be addressed. I still think I'm going to install the Dynamat Xtreme on the underside of that floor pan that sits on the transmission simply to solidify that piece of sheet metal, even if it gets significantly compressed, because I still think it will do it's job.
WaxMan,
I was digging around late this afternoon, and found an area that I think will be difficult to deal with, but am pretty sure needs more than the low density foam installed at the factory. I think it may be a big job to get to this section, as it appears to run both inside the cab and outside toward the engine compartment, but will have a better idea once I have things torn down. Have you thought about how to deal with this piece under the steering cover? It doesn't look like it'll be too easy to reach from underneath, and looks like it may not be able to be removed with the cab on the machine.
Bandit , did you put that foam in this picture at the cracks at the bottom? Near the floor mat?
If that is factory foam in those cracks then that is the reason my 2005 B3030 is full of dust and yours is not.
I have NO foam in these areas, just the formed piece of foam behind the plastic panel. From what I remember.
I have been putting my tractor together unfinished because of snow tomorrow here in CT. Guess I'll find out if it's quieter still three floor panels to go, I'll see if i'm on the right track.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2016 Chevrolet Trax AWD SUV (A59231)
2016 Chevrolet...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60352)
2014 International...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2017 ATLAS COPCO CPS110 PORTABLE AIR COMPRESSOR (A59823)
2017 ATLAS COPCO...
