trailer question
/ trailer question #1
gregz
Hoosier
BX 2350
Just wondering if a 12' utility trailer with SINGLE axle rated at 3500# will be safe to carry my 855 w fel. I figure my tractor w BM and FEL weigh in at 3000# or so. I will only be trailering it a few miles, maybe a couple times a year.
thanks in advance
gregz
/ trailer question #4
Just to add to that, most utility trailers with a 3,500# axle are rated to a gross weight of 2,990#. By time you take into account the weight of the trailer itself, the trailer only can have a true payload of 1,700# - 2,000#.
/ trailer question #5
I was also looking at a trailer 12'x6' single axle for my 2305, but after numerous discussion with the members on TBN, I am now looking for a trailer 14'x6' double axle with brakes on one axle. Henri
/ trailer question #6
Henri, you may find a 16' utility with brakes cheaper than a 14' with brakes. Seems the 16s are a dime a dozen in my area and anything shorter or longer costs more.
/ trailer question #7
Agree! I did notice, but I was hoping to find a use trailer. 16' trailer just kind of seem overkill for my 2305.
/ trailer question #8
Henri,
I think a 16' would be a better choice. I have a 12' tandem axle trailer I use to move my x749 with and would much prefer to get another 4' of length for attachments. That is without a fel on the front which adds a few feet to the length.
/ trailer question #9
Henri,
You just may be right, and you are not the first one to suggest the 16' but you just may be the one who made me change my mind. I'm going to look into it. Thanks! Henri
/ trailer question #10
Henri,
Depending on the weight distribution of the equipment, a longer trailer may provide better flexibility for positioning equipment to arrive at appropriate trailer tongue weight ratios etc. Although my trailer comfortably handles the weight and length of my equipment, I have a hard time getting 10-15% tongue weight...a longer trailer would alleviate the problem.
/ trailer question #11
Not sure how big the tractor itself is compared to my 3720, but I'm at 20' with my 3720 and depending what implements I carry I'm hanging over. Typically just the tail wheel on the MX.
Like frencht points out additional length is really handy to tune tongue weight.
/ trailer question #12
My 2305 with the blower and the ballast box including the rear quickhitch comes to 14'. The FEL is actually a little shorter if I recall right. Henri
/ trailer question #13
I find that to be a very valid point when moving my 110 with cab but not much of an issue with the x749 or a 2305. For those using a light truck or car the balance issue and loading can make a big difference.
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2006 International 9400 (A62180)
2006 International...
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
Giyi 59" Vibratory Roller (A62183)
Giyi 59" Vibratory...
2019 John Deere 8320R (A62180)
2019 John Deere...
Quick Coupler (A62183)
