Buying Advice 110TLB vs. backhoe for tractor
/ 110TLB vs. backhoe for tractor #1
T Dew
Culpeper, VA
John Deere
I need a backhoe, and I was thinking of adding the backhoe to a 5075M tractor. Now I have the option of buying a 110TLB with about 800 hours on it. The tractor will cost me about $5000 more than adding the backhoe to a 5075M, but I get another toy for that $5K. From the research I have done it seems everyone loves their 110TLB. Does anyone know how the 110TLB compares to the 595 backhoe when it comes to the digging capabilities and reach. I believe it can dig a little deeper, but I am not really planning on digging a 10' deep hole on the farm anytime soon. Is one of them stronger when it comes to removing heavy stones and plants that need to be uprooted? I'm a newbie when it comes to the dedicated backhoes, so any guidance on what I should do is appreciated. I do not know a lot about the specifics of the 110, but I am going to see it this weekend. Anything I should be looking for specifically that would be deal breakers? Other than anything obviously mechanically wrong. I meant lack of this, that, or the other thing. Thanks again for all the help!
/ 110TLB vs. backhoe for tractor #2
I just got off my 110 this evening after laying 620' of 12" irrigation pipe and as always it did a great job with it. I feel after 8 years of use that it has served me very well.
AKfish has both a 5075M and a 110 so his opinion is the one I would seek in this case. I am sure you will hear from him soon. If the 110 you are considering is in decent shape I would give that the nod over the attachment. My reason for this is I prefer having a separate tractor for 3ph work and a tlb with the 3ph for backup. So my 110 and 4520 work well for me.
/ 110TLB vs. backhoe for tractor #3
The Deere 310C BH is a lightyear ahead of my 5200 tractor. The BH will lift more and is stronger in every way. Two units are very handy to have. That's a ton of fertilizer I didn't have to shovel by hand. :D
/ 110TLB vs. backhoe for tractor #4
My (limited with the 110) experience with the choice says go with the 110. It suprised me when I used one, that in every way it is just a scaled down "full size" tlb. Good power & well thought out and way ahead of an "attachment" that you'd have on your tractor. Having a 2nd machine in my experience is a big plus as well. I love the "creep" feature that allows you to move the machine without climbing back around to the seat to move it. $5k is a CHEAP price for another (4x4) tractor & fel!!
/ 110TLB vs. backhoe for tractor #5
guestimating with the numbers here, a 10ft backhoe for your tractor should be around 9k new, so are you looking at the 110 for 14k? if so.. and it looks good and the hours are reasonable, thats a bargin. 110's are discontinued, so they are not as desirable as they had been... but its still a good tractor.
I'm not 100% sure what the guy will finally take at the end of the day for the tractor, but I am thinking it might be closer to 20k when all is said and done. That makes it is a bit more than the $5k I was originally thinking, but it is still a tempting offer. It's also nice having something used for a lot of the clean up work I have to do. It makes those first scratches a few easier to take. I will admit that the creep function is a huge selling point for me, since my other tractor has a cab. That makes repositioning a much bigger pain in the butt. If I had to lay 600' of pipe that would make the money worth it alone; that's a lot of getting down, getting in the cab, moving, and getting back on the backhoe. The more I think about it the more it seems it is a worthwhile investment. If it turns out that he actually wants closer to 20k is it still worth it for a discontinued tractor?
/ 110TLB vs. backhoe for tractor #7
T Dew,
800 hours is not that much, I have 1025 on mine and it is in very good condition. Lots of models of machines have come and gone but the 110 hasn't been out of production for much more than a year and is well supported by Deere.
The creeper function works very well. I could use the hoe today to reach over the trench and pull dirt back over the pipe and use the front fel with a chain to pickup the 12" pipe and turn it around and set the pipe all from the rear seat position. Had one man on the ground using gasketed pipe and used the hoe to push the joints together.
The 110 had several hydraulic options that would vary the cost of it considerably including the topntilt hitch, front and rear triple outlets and 7 function hoe (with auxillary outlet on dipper stick). I have a Laurin cab on mine so being in the cab for all uses is ideal imo.
I should also add that most have a full length skid plate which I consider a "must have" for clean up work. you might want to check tractorhouse.com and machinery trader to get some comps but you need to know what options are on the tractor you are considering.
/ 110TLB vs. backhoe for tractor #8
I used my 110 to unload and reload 22 of those bags last Spring during the local hay-Coop fertilizer delivery. With the eHydro, I could creep and reposition to fit those bags between the fender wells of pickup truck beds and a handful of car haulers, too.
Very, very handy piece of equipment - IMO.
The decision would be a no-brainer for me.. get the 110. As jenkinsph mentioned, it is really nice to have one tractor all setup to work with any of your 3pt implements and having another with a hoe and loader is icing on the cake.
The 5075M is a good sized utility tractor. My 5075 as it's currently set up is around 10,500lbs. Both backhoes have nearly identical specs (except the 595 does not have a thumb option). At least, that's what I recall from researching the details when buying the 5075. So, why not have a tractor that's more than a ton less weight and is able to inch around foundations and across open trenches versus a tractor that will lurch around the edge of a dig and cave off the bank! No comparison in my book!
That said, I'd like to find another 110 (with all the options that my 110 has) with only 800 hours for $20K! I'd buy it in a New York minute - and sell mine! :thumbsup:
AKfish
/ 110TLB vs. backhoe for tractor #9
Why did Deere drop the 110? They seem pretty popular around here.
/ 110TLB vs. backhoe for tractor #10
In my opinion, just about any 110 for 20 grand is a good deal, even discontinued, unless of course it's completely beat, or the engine is seized or something, which it doesn't sound the case at all. Go for the 110!
Also, (I have to admit, I have never used a 110 nor a "creep" function, so this may be worthless :laughing:)
I believe the creep function to be highly over rated. It seems like it would be something great for a beginner to help re-position the tractor, however, you do not need to have a "creep" function to move the tractor.
I have a 410 with no creep function, it is a dedicated backhoe so all I need to do is swivel the seat to operate the controls, pretty easy really, however, I almost NEVER do this. Any time I need to "creep" to a new position, I just raise the outriggers up, and use the backhoe itself to move the tractor forward, backward, or even side to side. All backhoes have this "creep" function built in, you just use the backhoe to move around.
Obviously since I have no experience with the 110, I'm just talking out of my ***, but it is something to think about. I wouldn't purchase one backhoe over another just because of the creep function. I'm sure all of you with creep, will disagree, and I respect that. :thumbsup:
/ 110TLB vs. backhoe for tractor #11
Just speculation, but there's kind of a limited market for small construction TLB's. First, you see lots more mini-ex's and tracked skid steers on jobsites these days. Also, the 110 competed price-wise with the glut of full-size used TLB's that would be favored by big-time construction outfits and competed with Kubota, which has a whole range of construction TLB's (B26, L39, l45, M59), that bracketed the 110. 110 seems like a great little unit; a landscaper pal of mine had one and really liked it.
/ 110TLB vs. backhoe for tractor #12
I would guess that it is due to the price and amount of sales. I have a Kubota B26 TLB which is a smaller Kubota TLB version like the JD 110 and the new cost for this 26HP, 4000 # TLB is right at $40K with all the options. I would assume that the 110 JD is even higher as it is a much larger tractor. When you start getting into that kind of money, it is a very limited use, before the buyer would opt for the full sized backhoe. I got my B26 for the sole reason that it is small and very easy to get into tight spots. I use is solely for Loader and backhoe work since it is my second tractor. Having a dedicated TLB is so convenient that it is my go to tractor for most of my chores. Yesterday I planted two fruit trees using the hoe, made some large holes (3'x3') in my hard clay soil, filled them back with a combination of peat moss, garden soil, native soil and fertilizer, stirred it around well with the hoe to mix it thoroughly then plopped in my trees. It took about an hour including the time deciding where to locate them. I would have been all day with a shovel trying to dig out the hard clay and rocks and likely wouldn't have made a hole nearly that large to support a good root growth.
I would think that if you can get the JD110 for $20-25K it would be a bargain if it is in good shape which it should be with only 800 hours
/ 110TLB vs. backhoe for tractor #13
I do think a person needs to use the creep function to understand the benefits. For instance if I am drilling post holes with the auger on the rear I can not use the hoe to reposition. While it doesn't make a small tlb an excavator it does make repositioning the machine a lot easier without making divots in the ground every time you move the machine.
I would also say that there is a big difference in width between the fender wells on a 110 and 410 so you can swivel the seat to the front position on the 410. On the 110 you have to get up flip the seat over and climb to the front, without the creep to reposition to alleviate that would be more trouble. Any decent backhoe operator can use the hoe to move the tractor around and does so quite often whether it is a 110 or full sized 410. Trust me on this the creep to reposition feature is a real plus on the small backhoes.
/ 110TLB vs. backhoe for tractor #14
I worked a 410 for a couple of weeks a year or so ago. Had a hydraulic thumb, too! :thumbsup: It's quite a bit more machine than my 110... And, the work space on the deck of that tractor makes swiveling the seat around possible - kinda like sittin' atop an aircraft carrier versus a PT boat!
Nonetheless, I use that creep feature to roll across the work areas @ 4-5mph! You don't have to "creep" at all! Crank the throttle up and push that lever all the way over - it'll move as fast or faster than you might want to go!
I paid just over $40K for my 110 with ALL of the options in 2008. It was expensive; but not out of line with either the L45-48 and certainly not when compared to the M59! I looked and looked at the Kubota's...
The demise of the 110 (and to the decline in sales for all TLB's) has been the due to the rise in popularity of the SS/mini-X combo's! The skid steer is a superior loader platform and the small excavator's are a significantly better digging platform! Simple enough - and the purchase cost is not so far out of reach that guys won't buy the package!
AKfish
/ 110TLB vs. backhoe for tractor #15
AKfish,
I think the demise of the 110 is lack of work on construction sites. I looked real hard at a Cat 902 wheel loader paired with a 304.5 mini ex and decided that for small jobs it was too much trouble to move two machines in and out.
Helped out a friend this morning and dug with his 426 Cat backhoe while he hammered thru rock with his 420. That was some tough digging. Couldn't have done it without the hammer.
/ 110TLB vs. backhoe for tractor #16
While I was disappointed when JD discontinued the 110 TLB, I am not going to willingly let my machine go. Someone is going to have to pry it out of my cold, dead fingers.
Just the right size for me, and tough as nails.
/ 110TLB vs. backhoe for tractor #17
AKfish,
That's had an influence - on just about every aspect of the countries economic cylinders! But, a 35' goose-neck trailer behind a 450 or 550 SuperDuty loaded up with a Bobcat 160 and a Cat 304 is an easy load! One trip.
Things slowed down up here - but, we've never, ever had the same level of decline that the rest of the country (Arizona, Florida..) experienced. Foreclosures were barely outside the normal, average for the state.
Currently, Anchorage is in the midst of a rental and new construction CRISIS! Projected to be that way for the next decade. Discussions about available raw land vs multi-story dwelling's, etc.
(You ever consider commuting...) Guys fly all over the world going and coming from their shift's in the "oil patch" up here!
AKfish
/ 110TLB vs. backhoe for tractor #18
http://www.tractorhouse.com/list/list.aspx?manu=JOHN+DEERE&mdltxt=110
TractorData.com John Deere 110TLB backhoe-loader tractor information
T Dew based on owning a very worn 1983 310B backhoe unless at 800 hours a JD 110 was abused it should functionally be new like and go until at least 2050. They are not cheap but I think would be light years ahead of some options. When clearing ground I would prefer our 310 series but the sucker is big in a yard and at 12.5K needs more than a single axle trailer and 1/2 ton truck. :)
I wound up with the 310 by accident. Was just looking for a FEL to mount on the MF 265 and that was going to cost me $6K+ but because in that size the used stuff was junk plus I did not want to screw up a naked tractor with a FEL that would be in my way when bush hogging, etc. While very worn the 310 was only $7200 yet starts, runs and works hard after several hundred hours of hard and abusive (using as a dozer clearing ground. building wrecking, etc) work with only replacing some hoses and the starter.
Add-on backhoes that do not use the OEM tractor seat would not work so well for me due to physical limitations. I think a BH one size too big is safer than the other way around.
Bottom line there is NO one machine that is good for all the jobs that can come up around a farm.
After adding the thumb it became clear the digging depth specs are quite important because that determines REACH. :)
/ 110TLB vs. backhoe for tractor #19
Gale,
You are so right about one machine will not cover all the jobs on a farm. My friends Cat 426 is three times the weight of my 110 and has twice the reach too. I'm guessing his hoe is about 25,000 lbs. I just don't want one that I need a lowboy and large truck to transport.
/ 110TLB vs. backhoe for tractor #20
OH man, what I would do for a hydraulic thumb! The worst part is, I designed one, cut all the steel, started welding it together and the guy whos welder I was borrowing sold his welder before I finished. :mad:
I really need to just have a local shop finish welding it for me. All I need is time. Story of my life.
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2016 John Deer 5075E (A60462)
2016 John Deer...
