What should the settings be? Ranger 9
/ What should the settings be? Ranger 9 #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
Guys
I am borrowing a Lincoln electric ranger 9 to weld some 1/2" steel brackets onto my land pride box blade. What should the settings be and what type of rod should I use?
I don't know much about welding and nothing about the settings. I have welded before but people have always setup the welder for me.
I could really use your help :)
/ What should the settings be? Ranger 9 #2
I would set it on DC+, use 1/8-inch 7018, for flat welding I'd set the main selector at 160-max, and adjust the fine tune as needed. For vertical up I'd set the main selector at 120-max, and adjust the fine tune as needed. ;)
Thank you!
I'll give that a shot. :)
/ What should the settings be? Ranger 9 #4
Remember all those settings have the blue background, don't switch anything to a Mig setting / CV!
/ What should the settings be? Ranger 9 #5
Ditto, I have the same unit. Poor thing sits and collects dust waiting to save the day.
/ What should the settings be? Ranger 9 #6
i would use 1/8 6011 at about 100 amps.
/ What should the settings be? Ranger 9 #7
Out of curiosity Piston, do you have the manual for the welder? I would think Lincoln would have a cheat sheet of settings to use.
If you don't have the manual. I'll bet it's on Lincoln's website.
/ What should the settings be? Ranger 9 #8
Piston, that is a excellent machine you are using however, on 1/2 steel I would stay with 7018 but prior to welding I would spend time with your grinder for prep. on the job. I just finished a replacing a battery box on my 580D CK
Unfortunately I don't have a manual for the welder. I'll try out the settings mentioned and go from there. That's a good idea about looking on the website.
I'm excited to try it out on the box blade. I would have the other day but ran out of oxygen for the torches so I couldn't cut the steel. I just refilled so maybe I'll get to do some hurricane welding tomorrow :)
Leave it on auto idle also!
Thanks, I did end up getting the job done a little while ago, following the suggestions.
This welder would never idle, the auto idle didn't work for some reason so I had to always leave it on fast idle.
The welder has long since been sold, it was a friend of mines and he got rid of it. Ill have to buy one some day as it was handy to have around.
I still wonder what the idle issue was though.
