New to owning acreage
/ New to owning acreage #1
ddmoit
Member
SE Tennessee
None yet
I moved to Tennessee last fall. I have nearly 7 hilly acres, most of which is wooded. Still, I have a few hilly acres to cut.
I've just about convinced myself that I'll need a tractor with a locking differential. Right now, I'm looking at 3 models
Deere X500
Simplicity Broadmoor
Husqvarna GT48XLS
The first two are nearly 2 grand more than the Husky. I'm not convinced that they are worth the extra 2 grand for my needs. I gather that the Deere has the beefiest transmission. I think it has a Kawasaki engine, which seems to be preferred. The Simplicity has a Tuff Torq K62 and the Husky a K66. I presume they are similar; I cannot find any comparisons.
The Husky and Deere lock-diff must be engaged by the user as needed. The Simplicity has some automatic system. Something more to break?
The simplicity also has what appears to be a nice rear suspension that separates it from the other models.
Any thoughts? Is one of these tractors 2 grand better than another? Are there others I should consider?
Thanks.
- Dan
/ New to owning acreage #2
Deere X500
Husqvarna GT48XLS
Thanks.
- Dan
Are you just wanting a tractor for mowing? If just for mowing why not consider a zero turn mower. They have a much lower center of gravity for hills, and the commercial units have a heavy duty welded deck,which holds up against running into small stumps and rocks.
I've seen conflicting information about the performance of ZTR units on steeper slopes. I don't anticipate using any ground engaging accessories, but I might find it useful to tow a cart around on occasion.
/ New to owning acreage #4
Zero turn mowers on steep hills can be problematic. If you have a hill here or there is one thing but they aren't good where your entire yard is a hill or series of hills. My yard has slopes and a bit of a bank near the road. It does fine on most of the yard but on the bank at the road it does tend to "crab" across the hill. A dealer of any worth will help advise you on a Ztr for your yard. Mine let me use one on my yard and test it on my bank before I purchased.
/ New to owning acreage #5
Most ztr 's can still pull a cart. Do you have a Exmark or Scag dealer, that would let you try one on your hills ? I use my ztr now in places I would not use my old lawn tractor.
Most of what I have to cut is a slope.
/ New to owning acreage #7
I vote for the Deere. It is more of a garden tractor instead of lawn mower. Something to consider; if you can't do the repair work/service yourself, where will you have it done. You apparently have a Deere dealer close since you are considering one, what about the other two? The Deere will also give you the option of some attachments if you decide you want some later, will the other two? And that brings up another question, have you considered a subcompact tractor? With 7 acres you will be surprised how many projects come up.
/ New to owning acreage #8
Hi ddmoit,
I do not know alot about the mowers you are considering. However my Dad does. He has a Deere and he loves it. He has a few acres in W.VA and it is very hilly. Basically I think his yard is just one big slope. I have never heard him complain about this mower. He had a Husky before this one and he did not care for it much. He said that it was not as comfortable and felt like it was always trying to "slide" down the hill.
He can tow his yard trailer with the Deere too. I am not sure if he could tow the trailer/wagon with the Husky.
Good stuff; keep it coming, please.
The Deere dealer is nearby. So is the Simplicity dealer. The Simplicity dealer doesn't sell Husqvarnas, but he is an authorized repair shop for them. The Husqvarna dealer is not too far from me in Georgia.
/ New to owning acreage #10
Ddmoit, You might want to consider looking at a subcompact tractor (JD1000/2000 series) like Bikerdib mentioned. They are much more versatile than a mower and they aren't that much more expensive when you consider all that you can do with one.
/ New to owning acreage #11
The mowers you are looking at are finish mowers, for the work you will be doing a rotary cutter or bush hog is probably needed. I have a 4 acre field i was cutting with a husky 48" ZTR and 54" husky rider. i would have to cut it every 4-5 days to keep it manageble, otherwise it would take 8 hours with multiple cuts trying to get it knocked down.
Here are some pics of my property where I try to capture the slopes...
/ New to owning acreage #14
I would be cutting grass with a ZTR, Them slopes look mean for a tractor.
Yes, it's a real outhouse, but there is no latrine beneath it, so it's more of a decoration.
Pretty much everything that needs to be mowed is on a slope - hardly any flat spots.
/ New to owning acreage #17
I just moved here in November, so I have never cut it. I didn't see myself what the previous owners were using, but to hear my wife describe it, it was nothing more than a big box rider. I don't really know.
/ New to owning acreage #19
Whatever you decide to buy had best be quite robust in the hydro trans , and be serviceable . You are going to generate alot of heat mowingand that will kill a light duty unit . Have you ever mowed this place , and with what ? Very nice place , love the crapper .
/ New to owning acreage #20
Very possible , that blows my theory all to **** .
