Finally made grab bar for m59
/ Finally made grab bar for m59 #1
Hersheyfarm
NE ky
You can tell Kubota left provisions for one but don't offer it. This runs over top of the flat spot on the fender incase I want to run it down, but its sturdy enough to swing on so no need now. I was starting to make the console loose from grabbing it.
/ Finally made grab bar for m59 #2
You might want to put a rubber end cap so you don't rip out your kidney if you get out too quickly
Lol, I'm going to close the end up if I don't run to fender. I never enter/exit on this side bit having a handle makes it easier.
As I think about it this grab bar is close to you because of height, to clear console. I bet Kubota killed the ideal because if you roll it body parts could get underneath. The bar on other fender is low and of less hazard.
/ Finally made grab bar for m59 #5
Looks great! Get some ROP matching gray paint and an end cap and no one will ever suspect it didn't come that way!:thumbsup:
8086 (A61165)
8086 (A61165)
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2022 K-Z Sportsmen LE Toy Hauler Camper, VIN # 4EZTU2621N5051599 (A61165)
2022 K-Z Sportsmen...
