No power to dash
/ No power to dash #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
I went out to start the tractor and nothing. No power to dash. Battery is showing 12.5 volts. Checked all the small plastic fuses in cab - all fine.
Where do I start to get a fix on this.
Thanks.
/ No power to dash #2
There should be two yellow 60A fuses right above your starter, I think they provide the dash with power, check those and see if one of them is blown. I think it's a $2 part at your dealer.
/ No power to dash
YOU ARE THE MAN! Just checked the wire and yellow fuse(?) wiggled wire and heard a click. Should I take it apart and spray with some cleaner. It was wrapped with electrical tape and held into position that way. Tractor is running now and charging battery. Huge THANK-YOU!
Lloyd
/ No power to dash
I guess this may be a maintenance issue. As spring is on the way I was thinking that I should give the tractor a good going over: wash extremely well, clean and regrease, sand, prep and paint any rusted surfaces etc(do implements as well). Would it be advisable to go over all of the connections - clean and spray with an electrical coating of some sort? If so, what would you use?
Thanks.
/ No power to dash #5
That fuse should be tightly socketed into that plug so it might be worth your while to pull the fuse out and see if it's loose in there or not.
If the fuse looks ok, I would give it a light brush with some fine sand paper or emery cloth and put a little dielectric grease on the connectors. If you run your tractor down the road in winter it's possible some salt worked it's way up into there and is causing some problems. The grease should help prevent that.
Jason
/ No power to dash
The fuse was blown - not sure why. The two metal bands in the fuse would make contact when I rattled the wire - thus starting. When I went out yesterday morning the battery was down to 4v and no dash lights no matter how hard I wiggled the wires. I stopped into my local auto parts store and they had the fuse - actually same manufacturer too! I brought it home used the grease and it started(battery was charging this morning). I pulled apart every connection I could reach and greased.
The two fuses(extra one) with tax was just under 20 bucks - ouch! I will take the loader off to access other wires as per spring maintenance noted above.
I looked for a wire that could be worn and had shorted out but found nothing. Any ideas regarding why it would have blown?
Thanks.
/ No power to dash #11
Thanks.
What I am about to tell you may or may not be the problem.. And you may not be able to tell. BUT. look at any blown fuse very carefully, I mean really examine it.. to tell if it blew instantaneously with the element gone and possible black marks inside indicating a serious current overload. Or is it just barely melted and sagged just a little in the middle but the element is still all there, just not quite making continuity, then it could have opened from many years of use and just a little overload one time or just was operated at the near limits for a long time.. Or if the element looks intact but when wiggles or jiggled, it moves, but does not appear to have ever really been hot, the fuse can fail from metal/vibration fatigue. No electrical overload at all, just vibration cracked the element. Now you might not be able to tell from just a cursory look at a fuse what happened, but sometimes you can.
/ No power to dash
k0ua -thanks for the reply - "element is still all there, just not quite making continuity" sums it up. Unfortunately the old fuse is gone... but, from what I remember, the copper element, where split, was grayish silver, not black and the interior of th fuse/plastic was not marked. The break was clean. Hope this helps. Your vibration point actually triggered something that happened last Friday. I was traveling to a friends over a snow covered road and bounced through a major frost heave in the road. The tractor bounced heavily - hit my head on the cab roof. After returning home the tractor was parked for 5 days without use.
Hopefully it was just fatigue. Thanks for your help.
/ No power to dash #13
One thing for sure, if it is a current overload, because of intermittent abrasion in the wiring harness, it will happen again. Intermittents all love to raise their ugly head when you least need it to happen. But hopefully you are all done..
James K0UA
/ No power to dash #14
James K0UA
Also when your the farthest away from the barn.
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
2004 John Deere 4710 Sprayer (A63688)
2004 John Deere...
2014 FORD F350 4X2 S/A DUMP TRUCK (A59914)
2014 FORD F350 4X2...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
