No power to dash
   / No power to dash #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
I went out to start the tractor and nothing. No power to dash. Battery is showing 12.5 volts. Checked all the small plastic fuses in cab - all fine.
Where do I start to get a fix on this.
Thanks.
   / No power to dash #2
There should be two yellow 60A fuses right above your starter, I think they provide the dash with power, check those and see if one of them is blown. I think it's a $2 part at your dealer.
   / No power to dash
YOU ARE THE MAN! Just checked the wire and yellow fuse(?) wiggled wire and heard a click. Should I take it apart and spray with some cleaner. It was wrapped with electrical tape and held into position that way. Tractor is running now and charging battery. Huge THANK-YOU!
Lloyd
   / No power to dash
I guess this may be a maintenance issue. As spring is on the way I was thinking that I should give the tractor a good going over: wash extremely well, clean and regrease, sand, prep and paint any rusted surfaces etc(do implements as well). Would it be advisable to go over all of the connections - clean and spray with an electrical coating of some sort? If so, what would you use?
Thanks.
   / No power to dash #5
That fuse should be tightly socketed into that plug so it might be worth your while to pull the fuse out and see if it's loose in there or not.
If the fuse looks ok, I would give it a light brush with some fine sand paper or emery cloth and put a little dielectric grease on the connectors. If you run your tractor down the road in winter it's possible some salt worked it's way up into there and is causing some problems. The grease should help prevent that.
Jason
   / No power to dash
The fuse was blown - not sure why. The two metal bands in the fuse would make contact when I rattled the wire - thus starting. When I went out yesterday morning the battery was down to 4v and no dash lights no matter how hard I wiggled the wires. I stopped into my local auto parts store and they had the fuse - actually same manufacturer too! I brought it home used the grease and it started(battery was charging this morning). I pulled apart every connection I could reach and greased.
The two fuses(extra one) with tax was just under 20 bucks - ouch! I will take the loader off to access other wires as per spring maintenance noted above.
I looked for a wire that could be worn and had shorted out but found nothing. Any ideas regarding why it would have blown?
Thanks.
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
