L4240 grill guard
/ L4240 grill guard #1
nybirdman
Super Member
north of upstate ny
Kubota L4240 HSTC,L3000DT
AFTER punching a hole in my lower grill and battery on my L4240;I decided to give it a little protection.Any-one with a grapple my want to consider doing this.I was lucky that I missed the radiator.
/ L4240 grill guard #3
Did this very same thing to my Deere when I bought it and before I put it to work. Deere wanted $140 bucks for one that covers about the top 8'' of the Hood guard...useless IMHO, so I built one myself...Grilles and batteries are a lot more expensive than a little expanded metal. Looks good birdman!
/ L4240 grill guard #4
Very clean work!!! Looks factory made. Isn't painting expanded metal a PAIN!!!! ;)
I built sides on mine as well so nothing could slip past. All manufacturers should offer something similar as an option at least for loader tractors.
/ L4240 grill guard #5
I took the grill guard off on my Kubota L4400 and took it to a welding shop in Danville. They charged me $35.00 and supplied the heavy expanded metal. The results were excellant and even the underside was covered. I did have to supply one can of Kubota spray paint. The $35.00 price covered the paint job also.
/ L4240 grill guard #6
Thanks for posting the pics. I need to build this for mine as well. :thumbsup:
/ L4240 grill guard #7
I know i'm dredging up old posts but is there any chance you could post a picture of your brush guard. thx looking for ideas
/ L4240 grill guard #8
No worries. Don't wanna take away from the OP's ideas. I modified and strengthened the factory grill guard, using the same hinge points and latch.
Hopefully these pics will just add more to the imagination Took these today.
/ L4240 grill guard #9
thanks, I think i remember seeing those pics somewhere in my searching.
I'm also using the stocker as a base ,I wont need the tilt function but i do want it to wrap around somewhat.
I will also be "meshing" the back of my grapple.
/ L4240 grill guard #10
My Brother bought a 12" tree shear. It has a strong mesh panel that protects the tractor or skidsteer from limbs.
I had to keep the tilt to get my hood opened. I added some bracing and blocks for the guard to push against so the small latch pin didn't have to hold that load. I pile a lot of brush with my Grapple and am certain my guard has protected me from a LOT of tractor damage. I still get small scratches on the front of my hood and lights from small twigs getting thru the mesh.
/ L4240 grill guard #11
I just modded the stocker.
I ditched the idea of the wrap around wings due to space issues, it would have only gained me 2" per side and that would have been pretty close to chafing my hydro hoses.
It needs some paint then I will take another pic after install.
/ L4240 grill guard #12
View attachment 350568View attachment 350569
I built wings while I was at it. Had plenty of space too which helped. I've got almost as many dents and scrapes on the wings as on the face of the guard. But I pile a LOT of brush with my Grapple!!!
/ L4240 grill guard #13
I've been trying to get one of these for my L4400, but the local dealership says the ones Kubota makes will not fit since mine has the loader.
Where did you get this? I'm guessing you did not build it from scratch.
Does anyone have a part number for it?
/ L4240 grill guard #14
If you are talking to the OP, he modified the factory guard. So did I.
/ L4240 grill guard #16
My L4400 came with a guard and FEL. It did not fold down and didn't need to. I modified it, adding screen and side shields.
/ L4240 grill guard #18
I used perforated on mine just to be different I guess. Is a little easier to paint though.
