Clearing Pine Tree stumps
   / Clearing Pine Tree stumps #1
RW Gates
Livingston, Texas
JD 4010 85hp diesel
I've just had 5 acres cleared of basically pulpwood pine trees. The logger cut the trees about 3 to 6" above the ground, and left the stumps in place. The stumps range from 3" up to 9" in diameter. I'm wanting to grub up the stumps, and disc out the pasture for horses, but have been unable to find a ripper plow small enough to pull behind my JD 4010, 85hp diesel besides a single blade attachment. The tractor is in excellent shape, but all the rippers I've seen are like 5 to 7 row plows, that would require a much larger tractor to pull. Anybody got any ideas on where I might look?
   / Clearing Pine Tree stumps #2
I checked on www.TractorData.com and it stated that your make and model is Engine - 18,5 HP and PTP - HP - 14. It is my opinion that your tractor will not be up to the task of clearing 5 acres of Pine Stumps. BTW, have you ever tried to dig up a pine stump before? Have you considered renting a backhoe or an excavotor? 4 acres is going to be harder than you think. Just my thoughts. Best wishes.
I checked on TractorData.com - information on all makes and models of tractors and it stated that your make and model is Engine - 18,5 HP and PTP - HP - 14. It is my opinion that your tractor will not be up to the task of clearing 5 acres of Pine Stumps. BTW, have you ever tried to dig up a pine stump before? Have you considered renting a backhoe or an excavotor? 4 acres is going to be harder than you think. Just my thoughts. Best wishes.
Well, I don't believe you're looking at the right tractor. My JD 4010 is not a lawn tractor...but a 10,000 lb., 85 horse, farm tractor that I have plowed literally hundreds and hundreds of acres with, utilizing a 6 row tandem disc plow. My dad bought it in '78, and it was 15 years old then...has been maintained with excellent care, and will probably be here when I pass on.
I have pulled pine tree stumps up with a track hoe with rippers attached, basically a D6, and there were no problems. Pine trees don't have a tap root, such as oak or mesquite. I can't afford a track hoe, and I've never tried stump busting with my JD, so...hence the question.
   / Clearing Pine Tree stumps #4
You are correct. There were two JD 4010 models. I didn't see the other one. Sincerely sorry. I realize that the tap root is different regarding pine than hardwoods. I have found it easier to push over a pine with the stump intact than digging one out. I had some pine stumps and finally had a buddy of mine use his excavator. 5 acres is a lot of pine stumps. Best wishes.
   / Clearing Pine Tree stumps #5
Rw Gates
You may be able to buy a 3 pt ripper cat 2 used pretty cheap, Take off the ripper shanks all but the one in center.
The V Rippers will go about 18" deep, Don't know how good this will work, you won't have much ground clearence with it raised up.
I pulled a 1 shank ripper with my 4010 to plow in wire worked good for this.
I also owned a 4010 very good tractor was the narrow front end, put over 10000 hrs on it, only have my old 3020 now and it stays. Everything else new and you can't work on them yourself like the old ones.
Hope you can find a cheap V Ripper, You won't be out much if it don't suit you. Junk steel prices are pretty good.
Treetrimmer01
   / Clearing Pine Tree stumps #6
Have gave any thought to renting a mini Ex. Around us a 9-10K machine rents for about $800 a week and would do a GREAT job with pine stumps. Plus you can stack them or put them on trailer for removal... Just a thought
   / Clearing Pine Tree stumps #7
Stumps are tough . Trees kill .
   / Clearing Pine Tree stumps #8
You may be able to find one of the old single bar sub soilers that you can use to cut the side load roots by cutting either a box or triangle around the stump, then pulling it with a chain from the draw bar. It going to be lots of work. Smaller stuff, if you can get a chain to hold, then just yank them out without the subsoiler. You can likely pull out everything up to about 6" size in one try with a chain. Another thing you might try is the chain over a rim method to pull up and out at the same time. You really need a ground person to work the chains rather than up and down all day long. I have removed a lot of pines and some of them don't have much of a tap roots but others I have had to dig 4-5 feet deep with my back hoe to reach the bottom of the tap root. I have never seen uprooted Oaks with a tap root, just a huge root ball.
One poster here showed a picture of a stump puller he made from approximately 4 feet of heavy pipe which a 12" square foot plate on the bottom to prevent sinking into the ground and (this is kind of vague)some sort of chain holder on top. He would chain the stump, run the chain over the top of the 4 foot pipe and then out to his tractor which would be 15-20 feet away. The pipe would act like a big pry bar and just lift out the stump. Similar to the wheel or rim idea of yester year.
I would try this on all of them first and see how many I could pull out with just a chain around them, then maybe go to the truck rim or pipe idea and then try the sub-soiler around anything I couldn't get with the other methods. I suspect you will be able to pull all but the largest with just a chain around them.
   / Clearing Pine Tree stumps #9
I've had some luck plucking small ones (< 6" diameter hardwoods with no taproots) using a single point sub-soiler. This is on a 3,500# 32 HP machine. It's not quick and sometimes I have to "fly the box", cutting the side roots, as Gary describes. If you can get the point of the subsoiler hooked under the stump you will have tremendous power pulling straight up with the 3pt hitch. Especially with a 10,000# tractor and its beefy hydraulics.
   / Clearing Pine Tree stumps #10
I saw my neighbor do a similar method. He wrapped a chain around the base of the trunk tight. Chainsawed a V-groove in the top of the stump. Clevis hooked the pull chain to the wrapped one, threaded it in the groove then to the hitch on the tractor about 25 ft away. Pulled them right out of Georgia clay with a 40 horse machine. Basically it was just like raising a telephone pole by redirecting the pulling force.
   / Clearing Pine Tree stumps #11
About your slash leftovers,
You will need to rent a small dozer with a
six way blade to peel the stumps out.
   / Clearing Pine Tree stumps #12
If you are not in a hurry just push the brush in piles and burn. keep it bush hogged for a few years, cutting over the stumps. Then after the stumps rot lower the bush hog and take the stumps out. I did this on about four ac. and it worked well.
   / Clearing Pine Tree stumps #13
Some times they rot quick, especially hardwoods, however I had one pine stump that I cut off 3 years ago and it was still solid as a rock. Had to dig it up with the backhoe to get rid of it.
   / Clearing Pine Tree stumps #14
I wouldn't even think of using a dozer to get out stumps, you would end up with hundreds of holes and stumps piles full of dirt that wont burn. If you were to rent a machine, get an excavator in 20-30,000 pound size with thumb and front mounted blade and uproot them with on swipe of the hoe, pick up the stump, shake off the dirt and stack them and fill in the holes. We had a dozer clear our fence line, taking out the underbrush and most of the trees and ended up with more dirt than wood. Ended up about 18 month later, getting another dozer to roll all the wood out and move it further from the fence line where we could then burn it and luckily the dozer owner was able to leave the dozer for a week or so and we had him spread out the dirt and ashes after ward which was full of barbed wire, steel fence post, rocks and tin from an old shed that was pushed out also. Dozers are good for moving dirt but not so great for digging stumps, although the size stumps that you mentioned it would likely do a fine job of getting them out of the ground, but for the same money an excavator can do it faster and neater.
I think a 3/8" chain and your tractor will be able to get them with ease, just going to take some time. If you have a back blade or box blade, you could fill in the dirt after pulling the stumps.
   / Clearing Pine Tree stumps #15
When I cleared the way for our Driveway, I had to cut a huge Yellow Locust at ground level. BTW, this was the only large tree that I had to cut down. I left the other trees. That Yellow Locust stump is still not completely rotted and that was 14 years ago.
   / Clearing Pine Tree stumps #16
I'm pretty much in the same boat as you; I want to clean up about 25 acres of pine clear-cut and I just purchased a JD 4020. After spending a fair amount of time researching this I came to the realization that this is not a job for a tractor... not even a big ol' honking 4010 or 4020.
What I would suggest is that look into having have someone shear and rake your property. Average cost is about $350 an acre (although it may be a little more for just 5 acres).
Here's a couple of links that describes what I'm talking about: RFC online - Site Preparation
http://txforestservice.tamu.edu/uploadedFiles/Landowners/Mechanical Site Preparation.pdf
http://www.forestry.alabama.gov/PDFs/ResourceSheets/Timber/Site Prep/Mechanical_Site_Preparation.pdf
   / Clearing Pine Tree stumps #17
It can be done. I've used an older JD855, 24hp, hydro to grub up to 9" stumps
I use a sub soil tool and chain over a car tire rim to gain pulling leverage.
It may not be a done in one weekend project, but it don't cost much.
Good luck
   / Clearing Pine Tree stumps #18
Have you considered grinding them? You have plenty of HP to run a PTO stump grinder and this approach would be faster than pulling them out individually.
   / Clearing Pine Tree stumps #19
I think a 3/8" chain and your tractor will be able to get them with ease said:
Worked for me for <6" pines. Single root pines typically pull out easily and my tractor is much smaller than yours. Two people speed up the process unless you are looking for a cardio workout.
   / Clearing Pine Tree stumps #20
It will be a lot of trailer loads. I've been digging pine stumps from a row of pines planted along the road on a new farm we picked up and a 7'x14' dump trailer fills up fast and that is with me trying to stack them like a puzzle to maximize space. Ideally if you can pull them up and knock most of the dirt off them then push them into a pile and light it up. I burn what I can but can't burn under the utility lines along the road so I have to haul my stumps out.
Also, if using a mini ex to dig stumps be careful. It is real easy to damage a hydraulic line/cylinder if a stump rolls back. I had to replace the thumb ram because a stump rolled and sheared the fitting off the cylinder.
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 International Maxxforce DT (A53317)
2014 International...
2019 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2019 CATERPILLAR...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
