axle fluid fill for ct450
   / axle fluid fill for ct450 #11
anybody else with a 335 and up. Did you get all 8 quarts back?
I got about 7.5 quarts back in my 335. I had to pull the upper plugs located on the inboard side of the front tires and add about a quart into each side to fill. There are two plugs by each wheel, a lower one for draining and the upper one that I used to fill.
Do you guys use regular gear oil or synthetic? I think bobcat is regular
   / axle fluid fill for ct450 #14
Thanks milkman. I pulled the other plugs and got 7 back in but its rite in the middle of the glass. Weird they don't tell you do that in the owners manual
   / axle fluid fill for ct450 #16
You're welcome.
I have the factory service manual and don't remember it in there either. After only getting a little over 5 quarts back in through the fill port on top of the axle tube, curiosity got the best of me and I pulled the upper plugs at the wheel ends just to see if there was oil there. It sat overnight and each wheel end was still a quart low on oil. From reading other posts on here it sounds like the oil eventually finds its way down there, but I felt alot better seeing them full of oil before running it.
2022 WESTERN STAR 49X TRIAXLE (A55745)
2022 WESTERN STAR...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2012 FREIGHTLINER M2 106 (A55745)
2012 FREIGHTLINER...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2019 BOMAG BW120AD-5 SMOOTH DBL DRUM ROLLER (A52707)
2019 BOMAG...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
