axle fluid fill for ct450
   / axle fluid fill for ct450 #11
anybody else with a 335 and up. Did you get all 8 quarts back?
I got about 7.5 quarts back in my 335. I had to pull the upper plugs located on the inboard side of the front tires and add about a quart into each side to fill. There are two plugs by each wheel, a lower one for draining and the upper one that I used to fill.
Do you guys use regular gear oil or synthetic? I think bobcat is regular
   / axle fluid fill for ct450 #14
Thanks milkman. I pulled the other plugs and got 7 back in but its rite in the middle of the glass. Weird they don't tell you do that in the owners manual
   / axle fluid fill for ct450 #16
You're welcome.
I have the factory service manual and don't remember it in there either. After only getting a little over 5 quarts back in through the fill port on top of the axle tube, curiosity got the best of me and I pulled the upper plugs at the wheel ends just to see if there was oil there. It sat overnight and each wheel end was still a quart low on oil. From reading other posts on here it sounds like the oil eventually finds its way down there, but I felt alot better seeing them full of oil before running it.
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
Sellick 560 Forklift (A57148)
Sellick 560...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
