Engine oil for B&S engines
/ Engine oil for B&S engines #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
Bought a new to me pressure washer with a B&S 8.75hp engine, didn't get the instruction manual. What type of engine oil do these engines normally require? 10W-30 or 10W-40? I am in SC, never gets real cold here, but I won't be using it during the winter anyway. Thanks.
/ Engine oil for B&S engines #2
Of the various B&S engines I have owned over the years, 10W-30 was always listed in the owner's manuals as being fine for the temperature ranges in the Southeast.
Steve
/ Engine oil for B&S engines #3
I always use Mobil 1 5w30
/ Engine oil for B&S engines #4
I use 20w-50, sae 30, or 15w-50 in non-pressure lubed engines, and I use 10w-40 or 15w-40 DEO like Rotella in pressure lubed engines. I only have B&S and Kawasaki single cylinders and they sound the best during cold start and high temp with those viscosity oils in my area (80-110 degrees). The easiest way to tell if you have a pressure lubed engine is if it has a spin on oil filter.
/ Engine oil for B&S engines #6
kebo,
I tend to agree with the Briggs & Stratton recommendation and have always used Briggs & Stratton "brand" SAE30 oil here in Tennessee. I have never needed any equipment with a B & S engine when the ambient temperature was 40 degrees or colder and as pointed out even though 10W30 gives a better cold starting range, it can lead to oil consumption over time(as described in the B & S link that user smstonypoint provided). I had a True Value Lawn Chief lawn tractor with a 16hp B & S Vangard engine from 1995 until my son retired it last year(17 seasons of use). I changed the oil every season and the filter every other season and even though after 17 years the Lawn Chief was suffering from a lot of rust and the deck was pretty well shot......that 16HP Vangard was still running like new and not using a "drop" of oil between oil changes. I think that's a fairly decent testimonial for Briggs & Stratton SAE30 oil!!! In fact I just bought a 2012 Gravely Pro-Turn XDZ 152 which has a 22HP Kawasaki FX691V Commercial engine and guess what I plan on running in it beginning with the very first oil change(only has 5.4 hours on it so far)............yep, you guessed it, I'll be using Briggs & Stratton SAE30 oil in the Kawasaki based upon my experience that this oil seems to work very well in well-maintained lawn mower engines:0)
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
Conveyor Belt (A64194)
Willmar Wrangler 4500 Loader (A66285)
Willmar Wrangler...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
(10) Massey Ferguson Tractor Weights (A65640)
(10) Massey...
