whining hydrostatic
/ whining hydrostatic #1
djp1218
chichester nh
mahindra 2816 hst tlb
Hi Was wondering if someone could tell me just how much my new mahindra 2816 should whine when i press the forward or reverse peddle it was just delivered yesterday and noticed that it seems to whine pretty loud also what rpms should i be running this tractor at when using the loader can anyone help me with this? thanks
/ whining hydrostatic #2
:welcome: to TBN
/ whining hydrostatic #3
Read your owners manual, Mine I run at least 1800 rpm
/ whining hydrostatic #4
Hydros do whine. I can here my neighbors JD hydro whine and he is 300 yards away. On my loader I run just enough RPMS to work the loader smoothly. About 1800 RPM on my tractor.
/ whining hydrostatic #5
Some HST's whine like a banshee and others are quite. New machine may quiet down some with a few hours on the clock but No real definite answer. Engine RPM probably minimum of around 1500. I would suspect most people runs theirs between 1800 - 2500 RPM.
/ whining hydrostatic #6
I think the brands whine differently. The neighbors JD has a high pitched whine. My Kubota has a whine just as loud but it is a lower pitch.
/ whining hydrostatic #7
well i'm going to ask that question have you checked the fluid level. i know it's new and it just came from dealler but that don't mean it's got the proper amount of fluid in it.
so you think about 1800 is in the ballpark? I guess im just going to have to play with it to find the right mix of throttle and ranges I also read on this site that colder weather makes it whine louder its about 30 today and yesterday when it was delivered it was 28 along with 65mph on the highway it was probably pretty stiff oil was also wondering if you check the hydro oil with it running like you would on a car?
yes with the engine off it only reads a little bit on the stick with it running warmed up i cant really tell its clear
/ whining hydrostatic #10
Mine does whine louder when it's cold outside until the fluid gets warmed up. On the FEL RPM's my FEL will run sluggish if the RPM's are too slow. If the RPM's are to high the FEL runs kind of jerky. 1800 works best for me.
/ whining hydrostatic #11
not sure on that make but i would not think so, your manual will tell you
/ whining hydrostatic #12
2000 RPM on my B26 is a sweet spot; plenty of power and operating speed and yet the engine isn't screaming like it does at WOT (2600 rpm)
/ whining hydrostatic #13
My B 26 does whine and much louder than my BIL's New Holland. I am thinking seriously of trying to find some SUDT2 or other synthetic to see if it quietens it down a bit. This as soon as I get my RV setting stabilized
the manual really doesnt say it just says check it when its warmed up and i have heard that if you use a thinner oil it pretty much stops it but i want to use whats best for the tractor and not my ears is it safe to use a thinner oil? also how fast should the peddle come back up it comes back up kinda slow im used to using my buddies case 580 gear so this is all new to me
/ whining hydrostatic #15
The tractor should stop immediately when your foot comes off the hydro pedal.
yes it does stop but the peddle slowly returns is that normal?
/ whining hydrostatic #17
as long as your sure the fluid level is correct the warmer it get's will quiten it some but not alot and no i would not use a thinner oil because of the tempature.
/ whining hydrostatic #18
It would be something I would be concerned about. If the pedal doesn't freely return to the center position it may want to cause the tractor to creep down the road. I'm sure it's nothing major. Maybe it needs a shot of grease or a better return spring.
i will have to ask the dealer if it should be running or not when checking the oil if it doesnt need to be running then i would have to say its low it barely touches the stick and with it running it seems to be splashed over the whole thing
that does seem like what it could be its a leftover 2011 its been sitting for a long time its kinda hard to push down also i will put some grease to it in the am its got a spongey feel to it thats the best way that i can explain it
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
John Deere 2680H (A64126)
John Deere 2680H...
2008 DRAGON KILL TRAILER (A65643)
2008 DRAGON KILL...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
