Rotary Cutter CHOOSING A HAY MOWER
/ CHOOSING A HAY MOWER #1
ROYCEWILLARDOKLAHOMA
Milburn Oklahoma
MX 5100 KUBOTA 2012/
I have a Kubota MX 5100, 4whd hydro-stat, I have approximately when none of its leased out about 300 acres with 2/3 of that in hay meadows. I need some advise on a disc mower. I would like something on a Dolly or caddi. And I need some info and advise from some of you guys. like size, brand ect. I would like to buy the rite one the first time. I may also hire myself out to help friends cut and rake. whats my best choice? I have considered swathers , and haybines. I believe my tractor is right at 60 hp with 56 in the pto. whats the largest cutter I can safely use without harming my tractor? And does it allow me a slightly larger mower if its on a dolly? I would like to go Krone, or Kuhn.
/ CHOOSING A HAY MOWER #2
Royce, morning.... Have you looked into Drum mowers ?? I'm getting one in a month or so.... from CCM machinery... There are many manufacturers and all have their +'s compared to sickles and discs... Light weight, speed of mowing and they don't plug when cutting tall hay....
/ CHOOSING A HAY MOWER #4
I'm not trying to pick on you but you and I have the same exact tractor and I believe they are 50 hp and 42.5 hp at the pto. I just want you end up with the properly sized mower. For what it's worth I have a close friend who runs a Reese drum mower on a 40 pto hp Allis 5040. They love it other than the belt drive. I believe it's 5' 6" or 6'. Good luck!
Yes, Your rite. Sorry about that. It is a little power house for sure though. I love that little tractor.
/ CHOOSING A HAY MOWER #6
Welcome
Is it flat or rocky and hilley in your area? That can make a big difference on what would be best for you.
its mostly flat, and deep sandy loam in the bottoms with just a touch of red clay mixed through it. up on the higher land its also flat but rich red clay. no rocks in hay meadows. But quite a few gophers in the sandy regions. Im stepping up the gopher poisoning program though. and even looking in to a gopher plow that puts out poison underground.
/ CHOOSING A HAY MOWER #8
I love mine as well. I've yet to put a hay cutter on it yet but I have done some baling with it and it handles a square baler fine. I have seen a few guys running 6 and 7' disc mowers with 4000 series deeres which are about the same size as our tractors and they seem to handle them pretty good.
/ CHOOSING A HAY MOWER #9
you should be able to run a 6 drum disc mower that should be about 7.5 feet.both are good mowers .i like krone the best.you may need to add wheel or front weights.
/ CHOOSING A HAY MOWER #10
Please keep us posted on what you end up with and how it works for you this season. I'd sure be interested as I might be in the market for a cutter in the not so distant future.
Im over close to Tishomingo, I seen you were in central Okla, We almost neighbors then. lol
/ CHOOSING A HAY MOWER #13
heres what i knowyou can pull with the MX5100 HST.you can pull an 8ft disc cutter with or without a caddy.an ive been told you could pull a 9ft on a caddy with it since all the cutter weight is on the caddy.
I hear you man. I just left a mans house who sold me a caddy. and he had a L 4800 kubota which is a tad smaller and he was doing just that. And he is a custom Baler. Im trying to insert a pic right now
This is a Home made caddy, and its heavy duty. Do you think its worth $1000.00
/ CHOOSING A HAY MOWER #16
I don't know what a new one runs but I'm guessing way more than a $1000! That one looks pretty nicely done too.
A new one is close to 4 grand, And up beside this one they look like they were made in China. This baby is heavy. You cant even lift the Tongue by hand. I can use it as a pattern and build them to sale. The old man who built it has passed on. Its one of the first. I think its heavier than a 10 foot vicon mower. Im adding a 8 foot Krone Mower straight from the factor after a fresh coat of John Deer green the Caddy should look nice Behind my Shiny Little Kubota lol.
/ CHOOSING A HAY MOWER #18
So you're going with an 8' Krone then? I've never been around their stuff but I've heard very good things.
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
2018 MACK CXU...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
Champion X18A Air Compressor (A65640)
Champion X18A Air...
