Using skidding tongs
/ Using skidding tongs #1
daugen
Epic Contributor
New Hope PA
in between now
Timber Tuff Swivel Grab Skidding Tongs — 32in.W Jaws, Model# TMW-04SS | Log Skidding| Northern Tool + Equipment
I've always used a chain to wrap around a downed tree but sometimes it's hard to get under the tree.
So I invested in this pretty heavy duty tong, which has fairly sharp points on it.
Never used one before. If the wood is a little soft, will this bury itself in so it's hard to get it off the log?
Does one need to carry a mallet or hand sledge?
Just wondering what downsides there are to this gadget, if any.
thanks
/ Using skidding tongs #2
I just bought the 23" one from there. I bent it up on the first day. I had it attached to my quick hitch and would back up to the log. Lower the tongs down on and over the log. Raise the 3 pt and take off. Worked great until I pulled a little to hard. The swivel one would probably work a little better. I'm going to have to try and bend these out or return them for something else.
Brett
/ Using skidding tongs #3
I use an old set of tongs all the time.....never had a problem getting them out of the log. The points on your tongs look a bit sharper but shouldn't be a problem. If they do stick....a light tap should solve it.:thumbsup:
/ Using skidding tongs #4
Brett
So you tore them up and are going to try straighten them, and try to return them for a set that swivels? correct? You think they will go for it?
/ Using skidding tongs #5
If I can't get them straightened out enough to move freely I'm going to exchange them for the one with a swivel. Problem is nobody has these in stock in my area so they have to be ordered. They are tweaked by the ring. I think they should've lasted longer than a day. The log was on the high end they were designed for but I was not abusing them. I guess I got what I paid for. At the local hardware store they had some that were the same size but wanted $200 for them. Felt considerably heavier
Brett
/ Using skidding tongs #6
I have the Timber Tuff 25" and just bought the 32", both have the swivel. I have not used the 32" yet, maybe this weekend since I am clearing trees. The 25" seemed to work fine and did not need to have the tips hammered in. I did not bend it, but have not used it real hard. If I was pulling heavy wood, I would chain up. I use the tongs mostly to cantilever haul medium firewood logs off of the front of the FEL so I don't drag them through the dirt and dull the chainsaw when I cut.
/ Using skidding tongs #7
I just picked up a set of these as well. I bought mine at TSC. I'm looking forward to trying them out.
/ Using skidding tongs #8
I have been using the to,amber tuff tongs from TSC they seem to hold up well. A lot easier than trying to do this with a chain and log jack
I thought the 32 inch model would have the thickest steel, even if I didn't go that big, and I've gotten close. It's quite heavy, but I have no idea what kind of steel it's made of.
there is another thread on this, but important to note these are pulling tongs and not lifting tongs. The latter are about triple the price, likely due to product liability. And hopefully forged construction with lots of extra capacity. I'd expect this tong to bend long before my chain or drawbar does, which I'm fine with. But with the swivel, if the links aren't hung up, more likely one of those links will give way, though there are two of them. I think Timber Tuff has been around enough, occupying the high end of the low end.
I looked up real forestry lifting and pulling tongs. Serious equipment.
/ Using skidding tongs #10
I use mine to lift firewood up on my log splitter. I hook into the ends that are just hard wood. It worked ok but at timed it just would not hook so I sharpened them with my 4" grinder, problem solved.
/ Using skidding tongs #11
Gosh, I'm not sure what to say. I've got tongs that go back more than 100 years. I've also got some recently purchased Chinese tongs.
I grew up logging and farming where we were still using a team of Belgian horses for a lot of our daily work. As a pre-teen, teen, and into my 20's, I cut, skidded, and loaded/unloaded innumerable cords of wood. I couldn't even begin to estimate how many logs I've hooked with tongs.
Just this evening, I loaded my old F700 dump truck with more than a full load of 12-ft by 16-22 inch oak logs with the loader bucket on my tractor/backhoe (yeah, I know, no lifting with skidding tongs - but 60 years of doing it ...). The lifting was all done with several tongs, ranging from relatively new, to some that are well over 100 years old. Except for paint on the newer sets, it would be difficult to determine one set from another.
My feeling is, the problems mentioned above are coming from inexperience. Find a crusty old dude like me to work with you for a while. I still can out work most with my "cordless armstrong" tools vs., today's battery operated cordless tools -- yet, I have a lot of good modern tools.
Old Fart,
Knute
/ Using skidding tongs #12
ol.com/shop/tools/product_200426733_200426733]I invested in this pretty heavy duty tong, which has fairly sharp points on it.
Never used one before. If the wood is a little soft, will this bury itself in so it's hard to get it off the log.
Does one need to carry a mallet or hand sledge.
Yes, carry a small sledge or "engineer's" hammer with you. A quick rap below the chain hook will quickly drop the points out of any log.
/ Using skidding tongs #13
Dropping your tongs on top of the log then pulling is a sure way to bend then. The tongs need to pull at the end of the log. If you are going to drop them over the top, then place them close enough to the cut that when you start to pull, the arms can pivot past the butt of the log. If they cannot pivot past the butt and pull inline there will be a tremndous amount of leverage sideways on the arms that will bend them everytime.
/ Using skidding tongs #14
Good reminder.
:thumbsup:
thanks, I'll definitely remember this good advice.
/ Using skidding tongs #16
Mine are sharp and I caught one tip on my brand new muck boots. Tore a hole right through 'em:duh:
/ Using skidding tongs #18
Picked up a set at tractor supply Monday. They were sort of hard to find but were with the chainsaws. Good price compared to the internet price.
/ Using skidding tongs #20
@daugen
Those are light duty tongs (the ones from TSC). You can easily tear them up with that 59hp Kubota skidding a decent sized tree.
They do work well if used gently. Don't need a hammer as the points are fairly sharp.
Be very cautious with making a sharp turn when skidding something heavy (that's how they get bent)
I had a set a ways back and bent them the first day (like some of the others have said). I was excited about pulling a heavy log with ease and went around a corner and bent them up real good. And that was with a little 40hp case DX40.
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
2019 MTD 42in Riding Mower (A66738)
2019 MTD 42in...
2021 Forest River Salem FSX 280RTX 30ft Toy Hauler T/A Travel Trailer (A66738)
2021 Forest River...
