How do you store you logging/tow chain?
/ How do you store you logging/tow chain? #31
I also learned this trick here on TBN. Four inch dia. PVC bolted to the loader arm supports. I have chain in the left one and rope in the right one. Drain holes in the bottom.
/ How do you store you logging/tow chain? #33
I've got a tray right on the front of the forklift for chains, and a trailer ball and hook for the holes in the fork tips. Keeps everything handy and out of the way. A while back I bought a bunch of ammo cans, both .30 and .50 from a surplus place, the 30's work great for keeping a chain and ratchet straps for behind the seat in the pickup. Not only does it keep everything together and untangled, having handles you can grab them and go if you need to change vehicles for some reason.
/ How do you store you logging/tow chain? #34
Any pics of that? Sounds interesting.
Unfortunately I don't have any good pix but I will show what I have.. The ground is covered with ice right now, and sliding down the hill to the barn does not sound like much fun. The first is of course the tractor and ballast barrel overall. The second shows the level of the concrete inside, and you can just see the tops of the chain organizer pipes I put in. They are just some scrap 6 inch or so PVC pipe about 9 inches long bolted in by the same bolts that hold the hooks on the side on. I can only get one chain in each, and the third one just lays on the concrete of the ballast barrel. Also on the barrel are three 2 inch pvc pipes for handle tools (rakes, shovels, brooms etc.). On the back is the 2 inch receiver tube, which I use for my sprayer. I have about $100 in the whole thing, including the barrel. the last pix is an old one before I put the chain organizers in the barrel taken in 2010.
James K0UA
/ How do you store you logging/tow chain? #35
I like to have my chain with me at all times but haven't found a good place to put it on my tractor. How do you deal with this? Thanks.
When I got this tractor it was missing the front cross brace for the Koyker loader so I incorporated this steel box to hold chains. works ok. Also it helps to have holes in the bottom for drainage...Rhino-picking up blow down trees 001.JPG
Thanks for all the input guys!
/ How do you store you logging/tow chain? #37
Hey wesmann is that made to slip over the rops? I like it easy on and off. Great ideas now you guys have made a ton of work for me out in the barn next good day. Thanks. :)
/ How do you store you logging/tow chain? #38
Hey, don't forget me...here's mine! I have one on each side.
/ How do you store you logging/tow chain? #39
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2018 Nissan Sentra Sedan (A59231)
2018 Nissan Sentra...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2000 16ft T/A Utility Trailer (A59231)
2000 16ft T/A...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
