Extending pole barn help
/ Extending pole barn help #1
dilligaf
john deere 110 tlb
Hey all,
Me and the wife are looking to extend our 36x36ft pole barn by 16ft this spring. We currently have more animals than stalls and need to get two more stalls for our two new boys. I have built pole buildings in the past and am pretty handy. I can do the main structure but I've got a lot of questions on how to tie into the existing roof. Our current barn has a 2x12 ridge beam with 2x10 rafters 4ft on center. We need to go with a beam rather than a board so we can keep the open ceiling fr ventilation and extend the hay loft also, otherwise I would just get pre-engineered trusses. I'm just not sure on how to tie into the existing ridge beam and end plates without ending up building an entirely new barn. I appreciate any tips that you folks can pass along to help me with this project. We have gotten some quotes on having it done professionally and the cheapest was around $18k and that's with us doing the ground work.
Thanks,
Jim
/ Extending pole barn help #2
Hi dilligaf,
You can get storage trusses that give you an open space in the middle. Usually 16' open in the middle. For a 16x36 addition 18k sound high especially with you doing the ground work.You would only need 9 trusses 24" o.c. and 5/8 plywood for the roof and you are good to go.
/ Extending pole barn help #3
I guess I am not understanding your problem
jsut copy what is there and extend it, (you nearly going to have to leave your end wall is my guess, jsut take the door off) and may be open up the wall, (as it is most likely supporting the end of the building and roof,
can you post some prictures of the existing building
I seems to me like it would easy jsut to copy the construcion you have if it working, and extend I not under standing your needing of a beam, or where you want this beam,
even if you do build a second building (that may be an avantage) if some thing catches fire, not the whole thing is in danger, (one reason old farms has so many little buildings spaced all over the place),
Thanks for the answers.
Builder, were trying to avoid any overhead obstructions that a horse can possibly hurt itself on if it rears up. With only 10 ft walls, if we went with anything pre engineered it would leave a ceiling that's a potential danger. I would love to use those trusses, I built my run in sheds with them and they make life so nice.
BHD,
Essentially, if I built off of the last two posts, I would need to tie into the existing ridge beam and I'm not really sure how to do it properly. With rafters 4ft on center I would have 3 ft of ridge beam not attached to anything after the last set of rafters that I know isn't such a good thing. Also, just extending an ag structure doesn't require a permit but building a desperate structure does and my town isn't what I would call ag friendly.
/ Extending pole barn help #5
Pictures would sure help.
If I understand this, you want to make the building 16 longer, keeping the existing roofline the same.
Are you wanting to removed the existing wall that is supporting the ridge beam?
Will you put in a post to support the end of the existing ridge beam? or are you wanting to have it totally open? Can you use any part of the stalls to extend up to support the load of the roof?
As far as extending the ridge beam and rafters, I would double up the last rafter and start from there with the new ridge beam.
It sounds real simple, so I'm at a loss why it would cost $18,000 grand. For that kind of money, I'm missing something pretty significant.
Eddie
/ Extending pole barn help #6
Eddie sounds right. All the weight is essentially on the side walls so you can more or less remove the end wall if you want to. If you double the rafters going to the extension and bolt the heck out of the two rafters together, it should be one solid structure.
Thanks guys,
That's exactly what I'm looking for. I just want to remove the siding, doors and all the girts and build off of the existing poles. We need interior posts for the stall fronts and hay loft so there will be plenty of structure to support the rafters.
Eddie,
That's exactly what I need to do. Extend the building by 16ft keeping the same roof line. Just wasn't sure how to safely attache the new ridge beam to the existing building by using the existing poles. Its not a huge task, I have no idea why quotes were so high. We received one for $30k! $18k was the lowest quote.
Kenny, thanks for confirming and that's exactly what I'm going to do.
/ Extending pole barn help #8
Do you have an existing overhang on the gable end? You want to extend the hay loft also, are there any support posts inside the barn? If the walls are 10', how high is the loft floor? Do you have any pic's of the existing building? Is the loft floor atached to the outside post's or the rafters. If you duplicate everything you have and tie into existing ridge beam with 2 steel plates, and tie wall girts to existing corner post. Also set your new perlins on top of the last roof rafter and secure to the side of the existing perlins. I would not remove any existing posts, on your end wall, they may be supporting the loft! I would think you could do this yourself for less than half of your contractors bid.
Dave
/ Extending pole barn help #9
Hi Dilligaf,
Quick question, Are your rafters seamed on what looks to be a single 2x10? If there is a beam i can't see it from the pic. On your new structure if you can i would try to use a full length rafter. Depending of course on the length required. Then place the beam under the rafter if the span is to long. And yes as everyone else has suggested double up your gable rafter once you have removed your over hang and start your ridge from there. you can even use some simpson straps to tie the 2 ridges together.
/ Extending pole barn help #10
Most of the time a "ridge pole" is NOT weight bearing or necessary, it is just convienient during construction and a handy way to fasten your rafters. Your floor is your "tie" and your extension of the ridge is really a minor consideration. If I understand your situation, you could support your last (existing) rafter temporaraly, cut 1 1/2" off each side, "scab" on a 2x to the side of your ridge, extending back to the next set of rafters (4') letting it extend 4' past the existing ridge. This will give you a real nice splice and continuation of the ridge. I would not worry about doing it to both sides of the ridge, but if it makes you feel better, it's your barn.:thumbsup:
/ Extending pole barn help #11
Highballing is how contractors say no thanks.
/ Extending pole barn help #12
I'm guilty of this. If a client seems like they are going to be annoying to work for, or the job has that, it's going to be a pain to do factor to it, I raise my rates to make it worthwhile to deal with the client or the problems I foresee with the job. Sometimes I'm the only one who even submits a bid and I get the job. Sometimes I never hear back from them. Since there is so much work in my area, I tend to be on the higher end of bids anyway and kind of pick and choose who I want to work for.
Eddie
/ Extending pole barn help #13
If you 'need' 16' now, I'd pony up the bucks and go 32'..... Hard to have too much barn or too much tractor.
/ Extending pole barn help #14
Hi dilligaf,
For a hay loft, the load requirement is for "light storage" which in the International Building Code is a 125 psf (pounds per square foot) live load. This is really beyond the capacity of any affordable prefabricated wood roof truss.
/ Extending pole barn help #15
Just copying the existing design is no guarantee of structural success. Pole buildings "work" due to the shear strength of the roof and wall sheathing. Depending upon the wind speed and wind exposure factor, by moving the endwall, it could cause one or the other of the endwalls of the new structure to become inadequate in being able to transfer windloads from the roof to the ground. Also, lumber values (especially those of Southern Yellow Pine) have been significantly lowered.
IMHO - While the best solution is a new code conforming structure (which will be less expensive in the long run), if the insistence is in adding on, it would be prudent to hire a registered professional engineer to evaluate the existing building and design an adequate solution.
/ Extending pole barn help #16
In most cases, when a contractor adds onto an existing structure, he then becomes liable for the structural integrity of the entire building. From the contractor's standpoint, why take on the huge risk, unless their is also a huge reward?
/ Extending pole barn help #17
While this is technically correct, I wouldn't overthink this one. Remember, the original building is not a truss structure, it's rafters on post walls, if I understand it. As long as the rafters are tied the building can be as long as it needs be. The end walls are not going to be a limitation on the building length. The post size/spacing and the rafter size/spacing should just follow standard timber tables.
While I always appreciate people getting professional engineers involved (I am one), this case certainly doesn't seem to require it.
/ Extending pole barn help #18
going back to tieing in if the ridge beam goes thought the wall it is simple two steel plates with holes and a few bolts, (ply wood and nails would work as well, if necessary one can weld up a bracket that can bolt on the last set of rafters and then to support the ridged beam, (remove the siding if necessary), basically a T shaped unit with two pieces on the center to bolt to the beam, a beam hanger may work as well that one can buy at the lumber center
on the (over hang) one can just cut the rafter ends out to clear the roof beam the closer the cut the better, or remove the over hang rafters,
but like said the ridge is not actually a support , it is a convenience and makes putting up the rafters easier, as it supports them and gives a spacing and locater, (not that that is a bad thing in any way shape or form)
many old buildings do not have ridge beams or boards, trusses don't have ridges beam/boards,
/ Extending pole barn help #19
If the building is not sagging and has some age on it (proven) and no problems the existing method of building is not a SIN,
My barn would not meet modern building code but it is as straight as the day it was built and has only stood over 105 years, I would not have any fear of copying it's design and or construction, ( know it has stood in over 85 mph winds that lasted for over 8 hrs, a number of near tornado), I am not saying do not build to code, but most likely the existing structure is a good design (from the picture it looks good).
what I am saying you have a proven design copying it and constructing in like manor and similar materials I really doubt if you ever would have any problems, (unless the tornado takes the whole building), Put it this way the new part will stand as well as the old part if built the same, using equal or better materials,
I have been building things for over 40 years some professionally (I ran my own construction company)and on my own place, and I will say from what i see that is a fairly well constructed building and it has a lot more than lumber and depth of structural members than most,
/ Extending pole barn help #20
When a trussed building or not, the framework is not stiff enough to be a rigid frame, therefore the shear loads are being transferred from the roof to the endwalls. It very well could be a problem. The column sizes need to be appropriate to be able to carry the combination of 1/2 snow plus wind. A simple table is not going to be able to adequately size the columns, and the roof diaphragm will need to be adequate to transfer the loads, else the columns should be designed as a pure cantilever (in which case it is going to take sidewall columns larger than 6x6).
Pole buildings are remarkably complex structures, this is why I would recommend investing in the services of a professional.
2019 KOMATSU D51EX-24 CRAWLER DOZER (A64279)
2019 KOMATSU...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
UNUSED WOLVERINE LL-12-78W-78" LAND LEVELER (A64281)
UNUSED WOLVERINE...
Caterpillar 235C Excavator Service and Operation Manuals (A63117)
Caterpillar 235C...
