Good morning!!!!
   / Good morning!!!! #8,521
good morning well we have dodged the ice so far 34 degrees and rain and snow mixed and of course 30 mph winds. we had a nice day yesterday, needs to dry up some it's time to start plowing but way to wet now.everyone have a great day.
   / Good morning!!!! #8,522
13 degrees here calling for another nice day then tonight look out for snow, rain ice etc! Spring around the corner.
   / Good morning!!!! #8,523
Good morning! Rainy and 35˚ here with falling temps later today. Too many projects to do with too little time. Have a good one.
   / Good morning!!!! #8,524
2013-02-19, 0415
9 degrees right now and a high of 41 predicted, along with snow showers.
More snow tonight, but only about an inch...we'll see.
House inspection went OK...no major issues for a 23 year old house. We'll get the radon and water test results in a couple of days. Then we have to decide about the septic system. The ground is frozen and the seller isn't sure where the tank is. There's no requirement in VT for cleanouts coming to ground level...that's interesting. The septic pumper/inspection company has ways to locate the tank (I'm assuming some type of magnetic detection), but actually getting to it might be a different story.
Roy...I assume your waste disposal system uses 3" PVC pipe, and I have never seen a line to a septic tank that curved after exiting the house so there is an excellent chance yours also runs straight. That will give you some idea of where it is located. Now, there is obviously a cleanout plug located in the PVC pipe just before it exits through the foundation, all you need to do is run a 100' (hopefully long enough) fish tape through the opening until it hits the inside of the tank, and when you pull it back (using good sanitary practices of course) you can measure the length of the tape and that will give you an idea of how far from the house the tank is.
   / Good morning!!!! #8,525
Got first cup of coffee poured. 64 degrees with clear skies this morning. Heading to 77 with a chance for a shower. Made it back from San Antonio yesterday afternoon. Winds lived up to the forecast. 20 mph with gust up to 40. Not a problem driving in those kind of winds. But it sure cuts into fuel millage. Setting up our site for rest of winter today.
Good Morning All.
   / Good morning!!!! #8,526
35 early, 52 and rain later, windy again, been windy a lot this winter. Should warm some by the weekend.
   / Good morning!!!! #8,527
we have light snow falling and a strong wind blowing.it sounds like the wind is going to be with us all day and night.its 10 degrees only getting up to 12 today.
   / Good morning!!!!
32 and getting colder? today. Yuck. Need to get my taxes done. Yuck.
David, see my post on your septic thread.
   / Good morning!!!!
I'd just eyeball it. The tank is at least 1000 gallons, if not more, it's a big chunk of crete. This time of year, it might be easy, the snow will melt off the tank area faster than the rest of the yard. My tank leaves a rectangular bare spot!! Take a couple hot showers and see if it helps.
   / Good morning!!!! #8,530
I would have suggested that Roy run a lot of hot water into his drain, but there seems to be a lot of snow in his area right now so I wondered if the hot water would heat up a 1,000 gallon tank that much.
   / Good morning!!!! #8,531
Hey Roy, pour 5 gallons of gas down the drain then flush a cherry bomb, that out to locate it! :D
   / Good morning!!!! #8,532
Seriously, divining rods are a very easy way o locate something that large.
   / Good morning!!!!
Probably not!! I thought about that after I posted it, I'd need a lot of hot water to heat up a big concrete tank full of crap. But the tank area is always the first area to melt off the snow.
   / Good morning!!!!
That would work. Propane might work, it seeks a lower level. Unfortunately, the collateral damage might involve a crap explosion!! I 'd think that might be a darwin award technique. Can you imagine explaining that to Saint Peter? You might be sent right to helll!!
   / Good morning!!!! #8,537
63F this morning
rain stopped, but sure messed up yesterday's plans
hope for today
Have a great day
   / Good morning!!!! #8,539
Good Afternoon, 39 with some rain. Yesterday I noticed the first yellow crocus. I think the little guy may be pushing his luck but it's like a promise that spring will be coming.
Chris
   / Good morning!!!! #8,540
2013-02-20, 0425
29 degrees and light snow right now...looks like we've got about an inch or so of fresh snow. Predicted high is 32 and snow showers today...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59905)
2018 FREIGHTLINER...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
406 (A52706)
406 (A52706)
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
