3 point hitch pallet mover
/ 3 point hitch pallet mover #1
94BULLITT
Super Member
USA
yes
I have been working on this the past couple of days. It is made out of 2x4 box .250 wall and the 3 point hitch mounts are 1/2''. I had all of the metal. The only thing I had to buy was 1 hitch pin. I still need to add some gussets, cap of the ends, and a few small things then I will clean and paint it.
/ 3 point hitch pallet mover #5
Looks very handy. You just gave me an idea too. I have several sets of fork lift forks but no frame to mount them on. I think I'll just use the forks and build cross members like you have done here. Thanks for the idea!:thumbsup:
/ 3 point hitch pallet mover #6
It looks good, but I would be worried about that critical point where the fork is attached. I've seen that design before, and always thought why couldn't that fork extend rearward past the frame, maybe 4 or 6 inches, that way you could gusset it there, there would be a bigger attachment area as well as greater leverage.
Just a thought, the light duty pallet movers TSC sells are just square butt welded (just angle iron) so I guess it must be pretty strong. plus you used a heavy wall box material.
Good idea, For the lower cross just use a horizontal draw bar, you would be half done right there, since it would secure the forks and already has the pins on the ends, Plus it's plenty strong enough.
JB
/ 3 point hitch pallet mover #7
nice work.:thumbsup:
/ 3 point hitch pallet mover #8
How high is the top link attachment point from the lower lift arm pins? I'm working on this same project. I want it to lift level, as far as possible.
Thanks for all of the replies. I got everything finished last night but the cleaning and painting it.
I had to put lift pins on backwards to get the spacing I wanted. I added some angle as a tie down point.
JB
I did gusset it in the back but I probably should have left a little more hanging over in the rear. I used the king kutter pallet mover for inspiration.
I am 99% the top link is 18" for the lift arms. The pictures I just posted are with it lifted all the way up. Everyone says a hydraulic top link is a must for a pallet mover but this one lifts pretty decent. Before I paint it tomorrow I will get a better picture so you can see.
I have a set of forks I am going to use to build a set for the fel. I wish I had would have had another set to use on this build. This may help your build.
TOP BOTTOM PALLET FORKS BAR kubota attachment fork - eBay (item 300541702265 end time Apr-04-11 16:14:45 PDT)
I did not get the forks completely painted, just the underside. I ordered some of these to make the official. I put the forks through a stress test today.
YouTube - Stress testing the 3 piont hitch pallet mover Sorry the truck in the video is not for sale.
Here is pic of how it is gusseted.
I double checked it is 18" from the lift arm center to center.
Here are some pictures showing them throughout their range of motion.
Here is a video showing them go up and down. I think with them lifted all the way up they were 4 inches off level but you really don't need to go that high going over most terrain.
The finished product.
Well I have used the pallet mover for close to 2 years now and i have move probably a couple hundred pallets with it. They are real handy. I got a quick hitch for the BX back in the summer and have been wanting to make them quick hitch compatible. I got a imatch for the L4240 so I finally made them quick hitch compatible. Now they just need painted.
/ 3 point hitch pallet mover #14
You do some good work Roger.
I forgot to say the pallet forks have a Bobcat decal on them on a John deere imatch on a Kubota tractor:confused2:
/ 3 point hitch pallet mover #17
It seems I will be going with the JD I match also and buy the bushings from Belaurus.
/ 3 point hitch pallet mover #18
Need to make this so you can use it on the Loader too, Pallet forks.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Unverferth 235 Seed Tender Wagon (A64047)
Unverferth 235...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
Arrow Quip 10' Corral Panel X 4 (A64047)
Arrow Quip 10'...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
