3 point hitch pallet mover
   / 3 point hitch pallet mover #1
94BULLITT
Super Member
USA
yes
I have been working on this the past couple of days. It is made out of 2x4 box .250 wall and the 3 point hitch mounts are 1/2''. I had all of the metal. The only thing I had to buy was 1 hitch pin. I still need to add some gussets, cap of the ends, and a few small things then I will clean and paint it.
   / 3 point hitch pallet mover #3
You would be a good neighbor to live next door to ,Nice Job
   / 3 point hitch pallet mover #5
Looks very handy. You just gave me an idea too. I have several sets of fork lift forks but no frame to mount them on. I think I'll just use the forks and build cross members like you have done here. Thanks for the idea!:thumbsup:
   / 3 point hitch pallet mover #6
It looks good, but I would be worried about that critical point where the fork is attached. I've seen that design before, and always thought why couldn't that fork extend rearward past the frame, maybe 4 or 6 inches, that way you could gusset it there, there would be a bigger attachment area as well as greater leverage.
Just a thought, the light duty pallet movers TSC sells are just square butt welded (just angle iron) so I guess it must be pretty strong. plus you used a heavy wall box material.
Good idea, For the lower cross just use a horizontal draw bar, you would be half done right there, since it would secure the forks and already has the pins on the ends, Plus it's plenty strong enough.
JB
   / 3 point hitch pallet mover #7
nice work.:thumbsup:
   / 3 point hitch pallet mover #8
How high is the top link attachment point from the lower lift arm pins? I'm working on this same project. I want it to lift level, as far as possible.
Thanks for all of the replies. I got everything finished last night but the cleaning and painting it.
I had to put lift pins on backwards to get the spacing I wanted. I added some angle as a tie down point.
JB
I did gusset it in the back but I probably should have left a little more hanging over in the rear. I used the king kutter pallet mover for inspiration.
I am 99% the top link is 18" for the lift arms. The pictures I just posted are with it lifted all the way up. Everyone says a hydraulic top link is a must for a pallet mover but this one lifts pretty decent. Before I paint it tomorrow I will get a better picture so you can see.
I have a set of forks I am going to use to build a set for the fel. I wish I had would have had another set to use on this build. This may help your build.
TOP BOTTOM PALLET FORKS BAR kubota attachment fork - eBay (item 300541702265 end time Apr-04-11 16:14:45 PDT)
I did not get the forks completely painted, just the underside. I ordered some of these to make the official. I put the forks through a stress test today.
YouTube - Stress testing the 3 piont hitch pallet mover Sorry the truck in the video is not for sale.
Here is pic of how it is gusseted.
I double checked it is 18" from the lift arm center to center.
Here are some pictures showing them throughout their range of motion.
Here is a video showing them go up and down. I think with them lifted all the way up they were 4 inches off level but you really don't need to go that high going over most terrain.
The finished product.
Well I have used the pallet mover for close to 2 years now and i have move probably a couple hundred pallets with it. They are real handy. I got a quick hitch for the BX back in the summer and have been wanting to make them quick hitch compatible. I got a imatch for the L4240 so I finally made them quick hitch compatible. Now they just need painted.
   / 3 point hitch pallet mover #14
You do some good work Roger.
I forgot to say the pallet forks have a Bobcat decal on them on a John deere imatch on a Kubota tractor:confused2:
   / 3 point hitch pallet mover #17
It seems I will be going with the JD I match also and buy the bushings from Belaurus.
   / 3 point hitch pallet mover #18
Need to make this so you can use it on the Loader too, Pallet forks.
what kind of price did you get on a imatch?
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2339 (A60432)
2339 (A60432)
KIOTI SL7504-PL SKID STEER (A60429)
KIOTI SL7504-PL...
2020 DRAGON ESP...
Case Titan 3530 (A61307)
Case Titan 3530...
