Shaft Conversion for PTO Generator
/ Shaft Conversion for PTO Generator #1
DieselDon
Member
B2620
I purchased an used Winco 5300 PTO generator the other day. But it has a 3/4" square shaft. Is there a conversion part which will allow it to join to the rear PTO or do I need to replace it at the u-joint?
Also, I noticed that it says 3600 rpm. Will that convert due to the shaft on the tractor being larger?
Thanks
Don
/ Shaft Conversion for PTO Generator #2
The 3600 rpm is usually converted from 540 PTO rpm by the gearbox/transmission.
Without photos, it sound as if you will need to convert at the cross/U-joint with the implement end of the pto shaft.
/ Shaft Conversion for PTO Generator #3
My negative thinking is that your generator needs 3600 rpm to provide the 110/220V outputs. I have a Winco 25Kw PTO generator and that label says 540 rpm. That may be why the 3/4 shaft so you won't try to use tractor pto to drive it. I have been wrong before and will be again soon! Hope things work out for you.
Dennis
Thanks
Don
/ Shaft Conversion for PTO Generator #4
In full agreement. The gearbox is attached to the genny and steps up the RPM from 540 at the tractor pto output to 3600 the genny needs.
/ Shaft Conversion for PTO Generator #5
Are you sure it's a 540 pto generator? Just because it has a pto shaft doesn't mean its for a 540pto like tractors have. Sounds like it was made for a front pto or it's just the way someone hooked it to a motor.
/ Shaft Conversion for PTO Generator #6
post a pic.
heads are commonly needing 1800 rpom or 3600 rpm.. depends on # of poles.
pto gensets are coupled with gearboxes to step up the tractor pto to the heads needs.
post a pic of what you go for more info
Thanks for the responses.
Note: The tag says:
5300 Watts
115/230
23 Amps
3600 RPM
1 Phase
You'll also note that it's a 3 point hitch setup, which I assumed was for a real 540 PTO.
/ Shaft Conversion for PTO Generator #8
What I see is you only have 1/2 of the pto shaft. Eather it's old or someone made it from a engine mount generator. Get the other 1/2 of the pto shaft and see if the generator works.
/ Shaft Conversion for PTO Generator #9
From the last picture it also appears that the 3600 rpm is generated by the drive pulley being bigger than the driven one. W/o out knowing the exact size of both pulleys, can not really say what the pto input rpm sb but looks like the unit was designed to run off the 540 rpm. Because of the 3 point mounting frame .
/ Shaft Conversion for PTO Generator #10
/ Shaft Conversion for PTO Generator #11
This thread is a good example of what happens when an inadequate description is given. We all have something a little different in our mind and comments and suggestions wonder all over the place. :) I'm sure most of us had in mind a more modern setup with a gearbox transmission and wasn't sure about the sq shaft.
Have to agree with LeeJohn about half the pto shaft is missing. As for speed change, the belt drive has to increase the input speed by 6.666 to give an output speed of 3600 rpm when input speed is 540.
/ Shaft Conversion for PTO Generator #12
I saw square shafting at Tractor Supply for the other half of that PTO shaft.
I agree with the 'inadequate description' and I own it:)
So far, you've all helped me figure this out. I studied it more and am hopeful that the ratio (from the belt drive) will indeed allow it to work with a 540. And I'll get the second half of the shaft or swap it out at the universal joint. For only $150, I consider it a good learning opportunity. Especially with the help of this forum.
Thanks much,
Thanks also for the mention of Tractor Supply. I'll hit it up tomorrow
Ok,
I found the shaft at TSC and got the PTO generator running. It generates but at very low output. You'll note in the picture below that the pulley ratio (top n bottom) look like their set up for a 540rpm correct?
I plugged a droplight in and got a variable brightness out of it depending on the rpm's on the tractor. The voltmeter never got above 100 even though it looks like the sweet spot is around 250. And I could only get it to 100 by running the tractor at 2750 rpms.
Question, I thought I had it grounded well enough, but would a poor ground affect the lower output? Or, perhaps the beast is just too old to generate much.
/ Shaft Conversion for PTO Generator #16
Measure the two pulley diameters. The difference doesn't look like enough to me. Maybe it was set up for a faster PTO.
Put your numbers into this calculator:
http://gadi.agric.za/software/renting/pulley_calc.php
Bruce
/ Shaft Conversion for PTO Generator #17
666?
You are going to have a devil of a time to makeit work.
/ Shaft Conversion for PTO Generator #18
666?
That generator will be a real beast.
/ Shaft Conversion for PTO Generator #19
Do you have a multimeter that will measure hertz? If not, most Kill-A-Watt meters will measure both voltage and hertz for not too much.
You need to check how many hertz it is putting out and adjust your RPMS until it is putting out 60-62 hertz unloaded (or with just a little load like your drop light plugged into it). Then see how many volts it is putting out.
I would not run it much more until you can check the hertz and voltage output. You could burn up the voltage regulator if you aren't spinning it fast enough.
Aaron Z
The pulleys measure as follows:
Large = 7" (roughly 175mm)
Small = 2.5" (roughly 60mm)
That's the issue right? If the PTO generator calls for 3600rpm's and the tractor is a rear 540, I need a larger ratio between the two pulleys. It seems to make sense why the volts are only reading 100 or so.
Any brilliant ideas? Like, sell it and buy a different one? I only have $150 into it and it's a Winco. Old but apparently working.
Thanks for all the quick responses
2019 International DuraStar 4300 Service Truck, VIN # 1HTMMMMN1KH714519 (A61165)
2019 International...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2017 Ford Transit 350 Passenger Van (A61568)
2017 Ford Transit...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A62130)
2008 GMC C7500...
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
