Normal to smell septic from roof vent.........?
   / Normal to smell septic from roof vent.........? #12
Are you telling us your poop don't stink? :laughing:
:laughing::laughing::laughing:
Well.....
I don't like to brag.
Its really the rest of the family...
Unless I am eating beans, and then they BLAME me, for right or wrong. :D:D:D
Later,
Da
   / Normal to smell septic from roof vent.........? #13
There are carbon cannister filters that will eliminate the stink, but they have to be changed from time to time.
   / Normal to smell septic from roof vent.........? #14
remember that everything going into your septic tank is going to take up space so air is going to be displaced up the pipe to allow the liquids and solids to enter the tank.Air straight out of the septic tank spouting off the end of the pipe up on the roof.
Not so sure about that. The tank has a static level. When new "material" enters the tank, an equivalent amount of water is discharged into the leach system.
   / Normal to smell septic from roof vent.........? #15
I stand corrected, I forgot about that part but I still think there's a burp up and out and then a slow inhale as the fluids dissipate.
   / Normal to smell septic from roof vent.........? #16
Since the vent pipe forms a direct line to the smelly part of the sewage system, why would you not expect to be able to sewage in it?
   / Normal to smell septic from roof vent.........? #17
Man, I don't think I'd sewage in the vent pipe - can only make it worse!
   / Normal to smell septic from roof vent.........? #18
True except that in the tank a lot of solid/liquid material turns to gas as it decomposes and that has a much larger volume. That's what goes up the stack.
   / Normal to smell septic from roof vent.........? #19
Yes, I did a bad edit, and left out the word smell.
Sorry, my secretary is off today. :confused3:
   / Normal to smell septic from roof vent.........? #20
according to my plumber, you should be more worried if you don't smell anything! pull a sink trap and you should get the same odor (keep a rag handy to plug it up). the stink tells you it's working.
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
