Dumb plumbing/vent question...
/ Dumb plumbing/vent question... #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I understand that every plumbing drain is supposed to have a vent somewhere within 5 feet (or something like that)
Ok...find/dandy....
I'm just trying to better understand how the vent works (yes I've got a poor draining tub and the lack of a vent seems to be the logical reason why)
If you have a clothes washer and its pumping out water I can see how a vent would help because there might be no air coming into the system from the washer... meaning.... as the washer pumps water out, when it stops pumping it will otherwise create a vacume of sorts.... because no air can enter into the system... I think I've got that.
A tub is what is confusing me...
Seems to me that if you have a tub that is draining, not only can the water simply go down the drain but, there is nothing for the water to pull a vacume agains since the drain is exposed to the air in general.
Heck...the more I type, the poorer I think I'm asking my question....
If you have a hose connected to the house (washer analogy) and turn the spigot off, then the water will drain very poorly from the hose as the air has to come in from the END of the hose to allow the water to bypass it and work its way out. If you crack the hose open at the spigot and allow air to enter the hose then the water will drain out rather quickly.
I understand that logic.
Now...
If you attach the same hose on a "sink drain" that happens to be elevated 5 feet into the air (the sink is the bathtub) and remove any obstruction at the outlet side... the water will STILL quickly flow out of the sink, down the hose and out of it because there is nothing enclosing the sink to draw a vacume to fight the draining process.
Seems to me in the first picture you must have a vent but in the second picture you don't need a vent. By that logic, I ask...
Why would you EVER need a vent on a tub/shower drain??
I'm asking this in part because I know I do not have one, I've got a poorly draining tub and have been told I NEED a vent. You see my logic above and I don't really want to rip my walls & attic apart to install a vent to only not actually need one and still have a poorly draining tub.
How far off base am I?
:confused:
/ Dumb plumbing/vent question... #2
First off. I'm not a plumber, but this is what I think. You need tubs and sinks to be vented to allow for smoother drainage, without the vent it would be popping and gurgling as it tried to breath as it was draining out and it would drain slower. there is air in the house sewer but there's a gas trap in the tub/sink drain that doesn't let air through unless forced, that would create a vacuum.
Did yours always drain slow? How do you know you don't have a vent? I have slow draining tubs but it's due to hair, have to take them apart every few months, what a PITA,
John,
/ Dumb plumbing/vent question... #3
I am not a plumber and not skilled at plumbing but I will tell you a little I know about the situation from experience. One of my houses is not properly vented and the unvented drains gurgle much more than the vented drains. Also, when the unvented tub is draining it will pull a vacuum on my unvented sink drain and pull the water out of the trap allowing sewer gas to enter the home through the drain until you run more water into the sink.
Possibly, the vent helps the septic tank release pressure when the tub is drained into it.
A real plumber will probably answer your question more fully soon.:)
/ Dumb plumbing/vent question... #4
tallyho8 is right - an unvented drain can siphon the trap dry. You don't want that. Plus a poorly vented drain WILL collect more "crud".. you don't want that either.
~Paul (not a plumber either)
/ Dumb plumbing/vent question... #5
Can't answer the vent question (not a plumber either) but we keep a small piece of screen in the tub drain that is easy to pick up and pick off the hairs--much easier than taking the d**n thing apart every couple of weeks (can't believe my wife isn't bald with all the hair she loses!!). Oh, and it doesn't seem to impact draining speed (old shower/clawfoot tub combo) so gets used at least 2x day
/ Dumb plumbing/vent question... #6
Thank you, I'm going to do exactly that! was thinking about it, now I just need a nice little stainless steel screen.
John,
Wife says it did NOT drain slow when we first moved in. If it helps any facts to know this, then realize when we moved in, my septic tank was empty/dry as it was all new construction. (don't know if an empty septic tank would HELP a drain issue since it's got a big air pocket in it)
/ Dumb plumbing/vent question... #8
So somewhere in this discussion is there an answer to why our kitchen area smells bad lately (like air from spetic system) when the heat pump in that area runs?
/ Dumb plumbing/vent question... #9
They may not have installed a trap on the drain line of the heat pump that runs into the sewer. If there is a trap, it may be getting sucked dry by a stoppage in the air vent or a vacuum caused by the blower especially if your air filter is dirty.
You may need to pour water into the drain line of the a/c because it does not drip water into it during the heat cycle and it also may have all evaporated since last time you used the cooling.
/ Dumb plumbing/vent question... #11
I don't think the empty tank would have anything to do with it, and the tank would be filled after a week or two anyway, so if the tub drained normally for x number of years and just recently started being a problem then I don't think it is no vent, maybe blocked vent or trap.
You have to eliminate the drain and trap first as causing the problem, may be time for the drain doctor if you don't want to do it yourself.
/ Dumb plumbing/vent question... #12
I'am not a plumber but, I've played the part several times. 1st. the tub shower will/ should drain without a vent. 2nd. It helps odors to escape. 3rd (and most imporantly) it's code most places & I have must do what they say:rolleyes: If you are plumbed with P.V.C. check the drain for obstruction,,hair, soap scum etc,,,Soap scum will build up in the trap & drain inside the P.V.C. for some reason. You will also get orors from this build up
/ Dumb plumbing/vent question... #13
I use the zipit thing on my drains and it works quickly and works well.
/ Dumb plumbing/vent question... #14
I made a special trip to Home Depot just to buy one today, of course I impulse bought a few other things, but the zip thing was only like 3 bucks.
I figured even if I do the screen thing I still have to clean one of them first, one of our two tubs is almost not draining at all, and I just took it apart maybe 3 months ago to remove a crud ball, 3 kids use that one.
/ Dumb plumbing/vent question... #15
I'm not a plumber, but have played one on many MANY occasions. In real life, I'm the son of a plumber.
First thing that comes to mind, especially after your saying that the tub did drain well but is now slow, is hair/soap scum build-up. Very VERY common, & can happen in a very short period of time.
A common cause of this problem is setting the plunger-type stopper in the vent too low. It will work for a while, but since the stopper is blocking some of the line into the drain it will clog with hair & soap scum faster. If your stopper is the lever type on the face of the tub front, you should consider pulling it out, inspect it for signs it's sitting too low, then test drain the tub with it out. If the tub drains well with the stopper out, adjust it higher (go about 1/4" at a time) until the tub drains well & the stopper still works. This may, & usually does, take a few times to get just right.
Cleaned a fist-sized mess of hair/soap scum from my GF's tub drain last year & she was absolutely delighted in how fast the tub now drains (almost as delighted as she is that I'd removed the leaking tub stopper at the drain so she can use a simple rubber stopper & can now take a bath).
As for the reason for a vent... A "plug" of water moving through the drain system MUST have a way to allow air behind said "plug" otherwise the system will pull air from wherever it can, usually from the nearest P-trap, which can & will drain the trap allowing sewer gas into the house through the now dry trap.
Hope this helps!
/ Dumb plumbing/vent question... #18
I found a stainless steel screen basket that drops into the kitchen sink to keep all the food scraps from going into the septic system. Works great!! Really cuts down on the amount going down the drain. The ones I have are too big for a tub drain but maybe there are units to fit there.
Vernon
/ Dumb plumbing/vent question... #19
dbdartman said:
Thank you for finding that! Just what I was trying to describe.
I had just seen this on TV and I was thinking about it while reading this post.
So, if a picture is worth a thousand words, I guess a video might be worth 10,000 words.:)
Maybe this will help troubleshoot the problem for him.
/ Dumb plumbing/vent question... #20
My guess is that it is not the plumbing drain smelling. If it's a heat pump, I'd make sure you don't have "dirty sock syndrome" in your heating coils. Heat pumps are infamous for doing this. Mine does ( York) and I installed a UV light this last year. A heat pump does not have hot coils like a traditional furnace. Since the coils just get warm, they become a perfect place for bacteria and mold to grow. A UV light will kill and purify the air.
I may be wrong, but I'd blame the heat pump first.
2015 Chevrolet Silverado 1500 4x4 Pickup Truck, VIN # 1GCVKREC0FZ180480 (A61165)
2015 Chevrolet...
CRAFTSMAN ROLLING TOOLBOX (A62131)
CRAFTSMAN ROLLING...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2011 Takeuchi TB016 Mini Excavator (A61567)
2011 Takeuchi...
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
