Another Harbor Freight quick hitch success story
   / Another Harbor Freight quick hitch success story #1
rbstern
GA
LS MT225E, Yanmar 2210
A few months ago, I picked up the HF quick hitch, on sale for $69, and with the 20% off coupon, it came to a whopping $57. After playing with it and pondering implement modifications, it was apparent that the top link adapter would require far less work than changing my implements. So I ordered that. Also picked up some bushing adapters from Northern Tool.
The last few days, I finally got around to setting everything up and testing with my attachments. Made a couple of modifications. I did the typical grind to allow the top link adapter to swing over the top of the top attach point, so it can stay in place when using the hook. I swapped the HF bolts for 1/2" pins, so the hook can be removed easily when not needed. Also drilled an additional hole in the hook, between the two existing holes, to allow it to sit one hole lower in the bracket, while still using two pins.
With my box blade (Lowery Manufacturing standard 5') and rotary cutter (Lowery Manufacturing Clipper 400), both set up with adapter bushings, attachment is quick and easy. In fact, I even managed to attach the box blade without leaving the seat of the tractor (Yanmar 2210). My dirt scoop is a Leinbach 30" model, and the top attach point is completely fubar for a quick hitch. What I did find could do was remove the hook from the quick hitch and lift the dirt scoop slightly via the bottom pins, and then slide the hook in place and pin it to the quick hitch. Ideal? No. But still about five times faster than a manual hook up without the quick hitch.
But the real revelation for me was the value of the hook for dragging logs. I was going to buy a boom pole to drag logs (and probably still will, for other reasons), but I find the hook of the HF quick hitch works great for this. I used a heavy duty tow strap, because I dont have the right chains. Can anybody recommend an appropriate chain setup for this application?
Only downside to this whole process is now I need some suitcase weights up front. Did some scoop and box blade work late this afternoon, and with the attachment a few inches further back, the steering is getting a bit too light for my comfort.
Some pics from today:
   / Another Harbor Freight quick hitch success story #3
Be careful with the hairpin clips that you have on the pins that secure the hook. My Land Pride quick hitch used a similar method with some clevis pins. During rehearsal everything worked fine but the first time I plowed snow with the rear blade I lost one of the pins. I had to install a bolt and nut so I could keep working. If any of your implements touches the open end of those hairpin clips they will immediately eject. One of the other forum members suggested using Cotter Rings. They are a bit slower to remove and replace but they won't fly off.
   / Another Harbor Freight quick hitch success story #4
CAUTION !!! Do not use the hook for dragging anything. If the log got stuck on a stump it would flip the tractor
over on its back in a heartbeat. Never attach someing higher than the axle unless the lift arms are involved ...The way Ferguson designed the system was when a pull on the lift arms was there, it would make the front of the tractor
stay down. Many have been injured or even killed by pulling from only above the axle. even a quick hitch could act
as a fulcrum if what ever being pulled is not attached also to the lift arms also.
   / Another Harbor Freight quick hitch success story #5
I use the pins just like yours, except I push the clips all the way through so the pin is in the ring part of the clip. Also, the clips do get beatin up from implements..
I agree on the pulling from the top link. At least lower the 3pt all the way down if you must.
Good advice on pulling with the top link. I'll come up with a safer method.
   / Another Harbor Freight quick hitch success story #7
An easy fix would be to use a draw bar attacked to the quick hitch. They sell a hook that you can attach a chain or strap to and then around the log, and you will keep your center of gravity lower. I would also be worried about the log pulling forward if it was to hang up, and damaging your PTO. They sell both for about $35 combined at Tractor Supply, and even less on harbor freight. Unfortunately both companies outsource to china for their products.
   / Another Harbor Freight quick hitch success story #8
   / Another Harbor Freight quick hitch success story #9
   / Another Harbor Freight quick hitch success story #10
When I made pins to replace the bolts in my QH, I cut them to the width of the QH top link frame and put the pins inside the frame, next to the hook. I had to grind the hook a little for clearance, but it allows the pins to "hide" inside the frame so they are secure and it also gives me the clearance I need to get the hook inside my box blade top pin framework.
   / Another Harbor Freight quick hitch success story #11
i havent used much hf stuff,but i have had some luck with a hf 6.5 engine.out of the box replacement for techuseh,pulled twice and started right up.looks identical to honda commercial!92 dollars with coupon.runs better and more torque than original engine! you may have a winner??
   / Another Harbor Freight quick hitch success story #12
there's nothing wrong dragging a tree like you do, the front of the tree is raise so hitting a rock is impossible...and i guess you arent dragging it at 100mph...
i used to only drag them with my ATV and really fast... never had a problem..
   / Another Harbor Freight quick hitch success story #13
I saw that you have the adapter on it. Did HF still have those in stock? I'm wanting to buy a qh but can't find the adapter
Brett
Brett
Ordered from HF customer service. Call their 800 line, tell them you need the adapter for the Quick Hitch. Give them the Quick Hitch part number, and they'll be able to tell you the part number for the adapter and take your order.
   / Another Harbor Freight quick hitch success story #15
I have the same quick hitch and have just gone to using the adapter. The top hook was too close to the frame to grab some of my attachments. Yup, had to order the adapter on the phone. Got it fairly quick and for a good price. I had to have it anyway for my rear finish mower. Now, that is where my biggest problem comes in. The quick hitch sits down on the PTO shaft guard when I am mowing. I try adjusting it so it stops beforehand, but I think I need a height stop to keep it above the shaft when I drop it. Anyone know of a decent way to do that? I was thinking of some sort of "bar" on the tractors draw bar. Just wondering if anyone has ever "been there, done that". Any ideas or techniques would be appreciated.
One thing you can do with the tongs is run a safety chain from them to the tractor draw bar. Make sure it is short enough to pull that direction if something hangs the log, and not put a bunch of downward force on the top hook to flip your tractor. You want to do this so you can use the tongs to lift, pull, and drop the logs without having to get on and off the tractor and chain up/unchain your logs every time. Of course, it may be better to use the choke chain as your short link to the draw bar after you lift the log with the tongs. You just need to be safe and not climb around under the log while you have it lifted.
   / Another Harbor Freight quick hitch success story #16
I am happy with my quick hitch I had to make a few modifications to get it to work properly. Here is my thread.
Would you mind sharing the dimensions of the toplink adapter?
I like the welding job you did on the top hook. Very good solution.
I'd be happy the share the top link adapter dimensions, but I am away from the tractor for at least a week. Maybe somebody else here has it close at hand.
   / Another Harbor Freight quick hitch success story #18
Thanks.
Okay.
   / Another Harbor Freight quick hitch success story #19
I have a question for you guys. My wife bought me HF quick hitch and I am having problems, it appears the hooks where the pins from my rototiller and brush hog sit in are too wide and I was wondering if I could cut them down some to make it work I like the ability to just back up and hook up and go but I cant do that presently :-(
   / Another Harbor Freight quick hitch success story #20
Could you turn the pins inward to make the spacing more narrow like on this implement?
Tractor 3 Point Dirt Mover Scoop Pan, 30", Reversible Hookup
John Deere 7410 (A53317)
John Deere 7410...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
