50 Hour Service
/ 50 Hour Service #1
mangus580
Gold Member
Western, NY
Bolens (Iseki) H1502; LS R3039
So reading my manual - it states that just the filters get changed at the 50 hour service, not the actual oils.... I thought the oil got changed too?
/ 50 Hour Service #3
You are correct, according the the manual, you change just the filters at fifty. I changed my oil as well as the filters @ fifty, and will likely change it, as well as the hydro fluid @ around 150 (manual says 300).
/ 50 Hour Service #4
I try to stick as close to the manual as possible that way I don't have to remember when the last time I changed something> I do write the dates on the filters also when I change them. I don't believe in wasting our hydrocarbon resources and figure that if the manufacturers think it will go to 300, it likely will go to 600 without a problem so they already have a built in safety factor to protect their warranty money so why do I need to spend the extra /extra money.
/ 50 Hour Service
I was just curious, as I had thought I heard somewhere (maybe hte dealer) that the hydro fluid gets changed too. He charges like $500 for it.... so....
I can easily just do it myself if I follow the manuals schedule...
/ 50 Hour Service #6
Check your operators manual for the change/replace schedules. It seems most manufacturers are backing off on some maintenance intervals, Kubota in particular has extended time intervals considerably in the last few years.
/ 50 Hour Service #7
The 50hr service for new Yanmars includes changing the hydro fluids, but at least that service is free. OEM Hydro oil isn't cheap!
/ 50 Hour Service #8
The only HST tractor I have is my B26 and I recently picked up a filter change box, Kubota has a package deal with every thing you need for 200 hours service which is basically same as 50 hour service. It has fuel filter, both hydraulic filters and air filter for around $100 and I wouldn't expect LS to be any higher. Then you have the oil and nothing is as high as Kubota oil@$20 per gallon. I have been researching the oil specs for a universal hydraulic oil. The oil listed in my LS manual is something I never heard of so instead, I have been using the Universal oil from Atwood's in a green can, Super S I think but I have to go look at the can again for verification. It meets a whole bunch of specs for Caterpillar, CaseIH, New Holland etc. Meets Kubota SUDT spec, Hy-Tran and basically lists the same specs as a bottle of UDT oil from Kubota and its less than $10 per gallon. It must be sold by others besides Atwood's, maybe TSC also.
SO if your tractor holds 10 gallons of hydraulic oil or less, $100 will buy you all the oil you need, 100 for filters and then your time of about an hour to do the work and save $300. You may have to buy an oil container to hold the capacity of oil that you will be draining also but I didn't count that as an expense as it can be used many times for other oil changes.
/ 50 Hour Service #9
I've noticed different models have drastically different instructions. I got the service manual for my S3010 and it had me change all fluids (except coolant) and filters at 50 hrs -- even the front axle gear lube and fuel filters.
/ 50 Hour Service #10
I can kinda see changing oil and even oil filters due to poor machining and bearing wear in, but FUEL FILTERS. Come on that is ridiculous. That little tractor couldn't possibly burn more than 2 gallons per hour so 100 gallon for fuel. I wouldn't change them till they showed some sign of contamination / fuel problems or at least 200 hours of service. I filter all my fuel with5 micron filters from my storage tank and so far I haven't had to change any fuel filters on any of my vehicles. Kubota RTV over 2 years and over 200 hours and filter is still clear(well red) with no water or other contamination evident in the clear plastic housing.
/ 50 Hour Service #11
As I remember there was a little bit of trash in the bottom of the bowl, but nothing I could see on the fuel filter itself. I'm pretty frugal so it was hard for me to do change it out like that. Did it anyway just to be following the maintenance schedule for warranty purposes. Had the same problem with the hydraulic oil -- that stuff was SO clean it seemed like such a waste.
/ 50 Hour Service #12
That oil makes me wish I had some 5 micron filters like the fuel filters to pass it thru and just put it back in. All hydraulic Oil that I have changed has been clean as new oil and just a bit of black residue on the magnetic plugs.
When doing oil flushes on large turbines and pumps, we routinely use the same oil. It is heated and flushed thru the lines to clean them and each pass the oil is cleaned and polished via special filters that removes all the contaminates. The flushing companies that have these speciality filters, claim that the oil is cleaner than new oil as they filter it thru finer filters than the refinery.
I doubt that a 5 micron fuel filter would stand the pressure needed to push the oil thru it without exploding, but if it was heated up it may. Problem with filtering it is it cost more to do that than just buying new oil if you have to go to these companies to do it.
/ 50 Hour Service #13
I once lived across the street from a chemist who was something of a curious gearhead with his cars. When the full synthetic motor oils came out he did his own testing and chemical analysis. What he found was that the oil after 3k miles was virtually the same as when it was new. By 6k miles, the oil had started to lose the shorter carbon chains, but looked clean. By 8k miles the oil looked dirty and had only long carbon chains left. For those that dont know, its the short and medium carbon chains that give oil its lubricating properties.. Tbe shorter the chain, the better it lubricates. Heat and pressure over time broke the chains until only the longest were left. The key is to change oil before it stops lubricating.
/ 50 Hour Service #14
My hydro oil only had 50 hrs on it, but it nearly 2 years old. Not a lot of heat and pressure to break it down, but quite a bit of time for it to gather moisture from our humid Southeast Texas climate. (You guys with tractors at home are lucky -- some of us have tractors at remote locations.) Only have about 80 hrs on it and now I have a competing distraction:
Poor little blue S3010, but football is almost over and soon the two shall meet....
/ 50 Hour Service #15
That is good info for motor oil, but hydraulic oil is really not a lubricating oil even though it does lubricate the pump I suppose. It is just a non compressible fluid that moves cylinders. The only lubrication it does is with the slow sliding of the hydraulic ram and just about any slick'em will work for that. It isn't like motor oil that circulates around a hot piston and bearings. I have seen old farm tractors from the 60's and 70's that didn't even have a filter (not HST because they hadn't been invented yet) and went a life time without changing oil and never had a pump problem. Seen them so milky with water that they looked like creamed coffee and still worked well and the oils of those days weren't as good as they are today either, no synthetic just good ole mineral oil.
/ 50 Hour Service
Not true... Just one example, made starting mid-60's
TractorData.com Farmall 656 tractor transmission information
/ 50 Hour Service #17
Looks like you got the name right, although I wouldn't have thought a tractor guy would be on a crotch rocket. They tend to be more GoldWing guys or those with John Deere's probably ride Harley's to keep with their status symbol position of paying more for less.
/ 50 Hour Service #18
Nah, it only LOOKS like a crotch rocket. It's actually a "value" (read cheap) high-mileage commuter bike. They call it an adventure/touring bike:
Honda NC700X Road Test Review- Specifications- Photos
It's just like a tractor in that as soon as you get it you want to start adding stuff to it.
/ 50 Hour Service #19
How much of the $3400(if I added in my head right) in accessories did you get. I would want a tall windshield, saddle bags and some sort of back rest , maybe some highway front pegs. I didn't see any of the accessories pictured on the website you linked but it seems a cool bike. I hope those $200 each tires last more than 6K miles. The best mileage I got was with the Goldwing I had but they only got about 10K. My Yamaha Virago only got about 5K on the rear. Tires are the most expensive things about a motorcycle as long as it is running then repair cost are outrageous.
/ 50 Hour Service #20
Actually, I'm trying to go real slow with the accessories. Just like with the S3010, the first thing I got was the service manual. Added the center stand over the weekend. About the only things I see in the immediate future is a top case (trunk) to store stuff, rain gear, a cover, wheel lock, etc....
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2001 Kubota L3010 (A64126)
2001 Kubota L3010...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
