oil loss issue ???????????
/ oil loss issue ??????????? #1
Streetman
ford 2600
Guys, I have kinda been a "Creeper" on this site for a good while, and i really appreciate the way all of you step up and try to help each other as opposed to trashing a guy for even asking a question, (my post could very well change that today LOL).
I have a 80's Ford 2600 diesel tractor that is loosing a ton of oil when its running, it does not smoke, knock, or rattle. It starts easy with no temp probs. I am kinda stumped, i am curious to know if anybody has any ideas.
Thanks
"lost but makin good time"
/ oil loss issue ??????????? #2
Well I would start by checking these things first. Look in radiator to be sure no oil is getting in the cooling system. Possibly the rear main is leaking it into the trans case. Check trans oil level and see if it is high. Even though it is not smoking it may still be burning it. Have to take a compression test cold and then hot. This will at least give you a few things to look at. Hope you find it. Keep us posted as to what you do and if you find where it is going...
/ oil loss issue ??????????? #3
Actually, if the rear main is leaking, it should go into the bell housing and run out the drain hole in the bottom of it. I don't think the engine oil can enter the transmission.
This thread should have been in 'parts and repairs' though.
/ oil loss issue ??????????? #4
Post your question in the Ford forum and hopefully Sound Guy will see it. He is the defacto expert on these tractors. And Welcome to TBN.
/ oil loss issue ??????????? #5
Don87 Thanks for clarifying the trans and bell housing. Wasn't sure if it was separated by that. Just trying to give him some things to check out. I am not a ford tractor expert. Hope he finds one here to solve his oil issue....
/ oil loss issue ??????????? #6
My guess is you are burning it. Compression check is necessary
Chris
/ oil loss issue ??????????? #7
You did not say wheather it was leaking out onto the ground or not
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
Case SV280B (A60462)
2013 BMW X28I AWD SUV (A61574)
2013 BMW X28I AWD...
500 Gallon Hydraulic Oil Holding Tank (A61573)
500 Gallon...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
