Roller / Compactor For Freshly-Dressed Gravel Road
/ Roller / Compactor For Freshly-Dressed Gravel Road #31
Hey crash, looking for inexpensive ways to work my rec acreage, like your pic, and way to help with how you built your unit, pics, drawings, measurements, and where you found parts
/ Roller / Compactor For Freshly-Dressed Gravel Road #32
i like to let the tractor tires do my compaction. I will turn the scrape blade around to back drag as i go. I just drive up and down the road, moving over one tire track width at a time, letting the scrape blade drag as I go. I will repeat until I cant see any more compaction taking place under the tractor tires and the finished product is baby butt smooth.
/ Roller / Compactor For Freshly-Dressed Gravel Road #33
Those of you thinking about a vibratory roller, how are you planning to do it? I've been thinking about one for awhile and my thoughts are to run off the PTO to a shaft turning an out-of-balance disk near or behind the roller axle. Anyone have any thoughts about how much out of balance it should be? Or better ways to do it?
Also, I have slopes here as well and have to deal with that, very little level land. So, I plan to put brakes on the roller. I can do it with the hydraulic ports running a cylinder that presses a piece of tire against the drum. I also have brake lights on the tractor so i've been thinking about tapping into those to run an electric solenoid to power the drum brake.
/ Roller / Compactor For Freshly-Dressed Gravel Road #34
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
John Deere 568 Megawide Plus Round Hay Baler (A60462)
John Deere 568...
SCAN TO RECEIVE TEXT UPDATES (A62130)
SCAN TO RECEIVE...
Kubota B2601 (A60462)
2019 GALYEAN...
