Pulling out remainder of broken-off 6x6 fence post
/ Pulling out remainder of broken-off 6x6 fence post #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
My fence has several places where there is a 6x6 post with a long (drive-through, opens-in-the-middle) gate hanging on one side and a short (walk-through) gate hanging on the other side. Two of them have recently broken off at ground level--probably rotted away, I would guess. I would love to be able to get the old post out and re-use the existing hole for a replacement. Does anybody have any tips for how to do this?
One thought that I had was to treat it like a stump, drill some holes in it, fill it with diesel, and start it burning. This would leave a neat 6x6 hole to receive the next post, but I'm not sure whether it would reliably burn out completely. Alternatively, I thought maybe I could affix some kind of an anchor and pull the post out with my tractor. But I'm not sure what I could sink into the post, especially into the end grain, that would hold strong enough to take the post out.
Any other suggestions?
/ Pulling out remainder of broken-off 6x6 fence post #2
Dig down around it for a foot and wrap a chain around it and try to use your FEL or 3PT hitch to lift it straight up.
/ Pulling out remainder of broken-off 6x6 fence post #3
I like the driving in some kind of anchor and pulling it out.
/ Pulling out remainder of broken-off 6x6 fence post #4
If concreted in,dig down around it,use long metal bar to break concrete. It breaks a lot easier if it has room to break away from post.
/ Pulling out remainder of broken-off 6x6 fence post #5
Seems to me that a long lag bolt (3/8 or 1/2) tapped into the top should work if you can get a vertical pull with a tractor. I've done something similar just using the hydraulics on a plow truck. You might find that it is rotted though and you won't get a bite. So then I guess the burn method. I wonder if anybody has ever tried using hot charcoal on something like that? Slow burn but sustaining.
/ Pulling out remainder of broken-off 6x6 fence post #6
Try lifting it with your tooth bar
/ Pulling out remainder of broken-off 6x6 fence post #7
using a large Eye Bolt in the top may work if only bare dirt. Use the FEL to push it back & forth a bit to loosen the grip of the dirt.
you can also use a big Spud Bar down along side to pry it back & forth a few times then come in at an angle to the post drive the spud bar in some or drill a hole using a spade bit & battery drill so there is something to bite into on the post. then use a 4x4 as a pivot point to pry it up & out if you cant get tractor close.
Next option is to use Dynamite a "HOLE" bunch :D my preferred method j/k lol. but not sure how cold you all are getting now you can also shovel out around it some to form a bowl use a sledge hammer to beat it back & forth some then fill hole up with water. let it freeze and drain along the post side come back in a couple hrs and beat it back & forth in the muddy hole and then pry out.
additional option is to NAIL or SCREW a 2x4 onto the top one or 2 sides and chain under/around it still requires some digging. then FEL or Spud Bar to pop it up also can use a FARM JACK or old style Bumper Jack to JACK it out of the ground.
Mark
/ Pulling out remainder of broken-off 6x6 fence post #8
Whatever method you use, by the time you have the post out, the hole isn't going to be a neat 6x6 hole anymore. You're gonna end up cleaning the hole. I'd use the chain loop method as described above.
/ Pulling out remainder of broken-off 6x6 fence post #9
I wonder if a fire would get enough oxygen to burn in a hole that small and that deep.
I agree that digging and wrapping a chain could work and an anchor might work as well, maybe a large lag bolt screwed into the top to pull from.
Something to think about is why it broke to start with. If you have a long gate on one side and a short gate on the other it sounds like there is no brace. If the gates rest on something like a block or the ground then that probably isn't a problem, but if the weight of the gate is hanging on the post with out a brace then it could be the reason the post broke.
/ Pulling out remainder of broken-off 6x6 fence post #11
In most cases someone drove into it with a tractor.
Now who in the world would do a thing like that? :)
Back in the summer a guy was pulling a four wheel hay wagon out of one of my gates onto the road. A 20' wide opening, two 10' gates actually. Anyway he hit the end of one of the open gates with the front of the wagon. It put a slight bend in the heavy duty gate (less than a year old) and pulled the bed half way off the wagon frame.
I was pretty mad but luckily it was his wagon and it didn't break the 10" post.
/ Pulling out remainder of broken-off 6x6 fence post #12
I hear ya. The only dent in my car hauler trailer fender came from me hitting a tree while trying to avoid the gate post! :laughing:
/ Pulling out remainder of broken-off 6x6 fence post #13
Yep never sure WHO hits stuff with my tractor or the car trailer :eek: ok maybe I could have a clue (wisper wisper wisper) sorry I've been advised to take the 5th :D
M
/ Pulling out remainder of broken-off 6x6 fence post #14
Pulling straight up has worked for me a few times. This was with a 4x4 post. I got the biggest lag bolt I could find at the hardware store, then drilled down through the top with the appropriate sized bit, and finally, screwed the lag bolt in tight. I made a quick frame with a couple of 4x4 posts, and then one across the top. I hung my come-along from that and pulled straight up. Came out with a perfect hole. I dropped the new post in, and I was done.
The times this has not worked, I dug down about 6 inches on each side of the post and gave it a few whacks on the side with an 8lb sledge. Hitting it with your backhoe bucket or FEL might do the trick as well. Once it was loosed up a bit, it came right up.
If you want to use your tractor to lift, then I would lift from the 3pt hitch. Easier to lift straight up, and you can lift more.
/ Pulling out remainder of broken-off 6x6 fence post #15
The burn with diesel idea ---- supercharge the airflow with a leaf blower... should burn out in no time.
Exactly. Whomever designed the fence put a bunch of these places in where there is a drive-through gate on one side and a walk-through gate on the other. It's just a 6x6 post in the ground with two gates hanging off of it--one of them about 8' long. The two that broke are on a hillside that sees a LOT of water running down it, so my guess is that's why they broke. I'm not sure how to fix it, though, short of taking out the drive-through gates and putting in fence rails instead. How can you brace something like that?
/ Pulling out remainder of broken-off 6x6 fence post #17
I work construction. pulling out old decks and such. Chain and FEL is by far best method. If it won"t pull right up, lift and drive forward and back a bit at the same time.
/ Pulling out remainder of broken-off 6x6 fence post #18
Redesign it with a single opening so you can brace the posts. A 8-12ft single gate is no problem to walk through by opening it just a little bit. If you really want a small gate, make a double gate with an 8ft and a 3ft, for example.
Bruce
/ Pulling out remainder of broken-off 6x6 fence post #19
If you take out the longer gate and leave a short walk through gate (4' I'm assuming) you probably wouldn't have to brace it at all.
You could leave both and put a wheel on the end of the longer gate or leave a block of wood, a rock, brick or something like that at the end to keep the weight off of the post. Then I think you would be fine without a brace.
/ Pulling out remainder of broken-off 6x6 fence post #20
Over the years when I was on the Line crew we pulled a ton of power poles! Easy when you have many feet sticking up to wrap a boom tip winch cable around, eh? :D. Seriously, for ordinary 4x4s or 6x6s, sometimes a chain and JackAll work the best, just have to dig down a ways to get the chain wrapped around the stump. I've had instances where the stump was rotted into a pointed shape so no way would the chain grip it, a lag screw or two would hold it down enough to tighten and then it pulled out with the jack. Sometime a jack works better than a front end loader as you can see what's happening. Use the loader to carry the jack, chain shovel and stumps.
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
TAG 18in Digging Tooth Bucket Excavator Attachment (A60352)
TAG 18in Digging...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
