Amphibious ATV
/ Amphibious ATV #61
It has nothing to do with the phone, it's the app.
Keep on using your Jitter Bug, but you're missing out.
I'm using a pc.
And if it's the app, operators need to learn to get the correct app to use the equipment correctly or............trade for something that is useable for their situation.
Dunno if you people realize it or not, but bandwidth is becoming scarce, so do us all a favor and fix the equipment, or get the correct app so the bandwidth isn't wasted.
As with any equipment you utilize on a daily basis, if you can't operate it correctly............get training or get away from it:thumbsup:
/ Amphibious ATV #63
If it reposts to the same thread an hour later by itself its junk, plain and simple. ain't no need or desire on any forum for that crap.
This is where you miss the point.... It ain't the phone.... It is the tractor by net application......
Just like a gun can't shoot by itself the phone only does what the application tells it....
So the application programming said do x... So it did....
If the app said do x and it didn't then it would be crap...
Please don't go all Joebuyer on us.....
/ Amphibious ATV #64
I'm using a pc.
Can you reprogram Microsoft office ?
Software bugs exist.... And the average user can no more fix them than you could fly the space shuttle .... The training to do so is years long..
Bandwidth scarce?? Nope... It is growing faster and faster!!!
5 years ago the fastest connection was 1gigabit... Now it is 100gigabit... Wireless was 54meg... Now 3 gig and 7 gig will be released soon...
This is what I do....
Don't believe me google 802.11ac.
Anyway....
/ Amphibious ATV #65
You've just proven that Iphones are junk, and is the reason that I refuse to buy one of those overpriced pieces of crap, that do nothing but clutter up the bandwidth.
When people are too cheap they say things like the above...
/ Amphibious ATV #66
That's 3 of you now that have taken me, and this thread to places it never should have gone. Keep trollin fellas.
I apologize to the OP and others reading this thread.
/ Amphibious ATV #67
Maybe you could find a older, high clearance agriculture spray machine that you could adapt. They aren't designed for water, but they are built high with those big flotation tires, and the motor is up high too.
/ Amphibious ATV #68
You started the iPhone is crap rant... Not us. I'm just here trying to keep the facts straight. :)
/ Amphibious ATV #69
I think you missed a post, so continue trolling.
/ Amphibious ATV #70
very nice unit!
alot of neat ideas....I like the an army duck solution, designed for both water and land,
how about the aquacar! http://www.youtube.com/watch?v=HyJRaAWRcfw&NR=1&feature=fvwp
still around, novel, parts available, wheel or prop driven!
arrive dry at your location and it seats four!
BTW...the solution is directly proportional to the amount of money you have! so, how much you got to spend on the solution to this problem? got a big budget???? http://www.youtube.com/watch?v=Yy2lY38yedo&NR=1&feature=endscreen
/ Amphibious ATV #71
Have you considered a floating bridge? It might be cheaper than a specialty vehicle.
/ Amphibious ATV #72
One thing I have heard of doing is to put a couple of PSI into the vents for the axles, transfer case, transmission, etc to keep the water out.
Aaron Z
You heard WRONG! Even a couple of psi will blow out your seals that is the reason for vents in the first place, so as not to build up pressure. Run 'em high and run 'em dry!
/ Amphibious ATV #73
I never thought of that, there is a lot of old ones around here. I think someone was importing them. They go cheap and are hydraulic drive you wou know its all water tight down there. They are very slow though.
/ Amphibious ATV #74
The government would like to disagree with you on that one. The original Deuce fording kit was setup to put 1-2 PSI into the axles. See Fording Kit Instalation or Home Made Fording Kit?
Aaron Z
JOHN DEERE 4039TF001 POWER UNIT (A62131)
JOHN DEERE...
Trava Long Gooseneck Livestock Trailer (A64047)
Trava Long...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
