Suitcase Weights for a BX
/ Suitcase Weights for a BX #1
94BULLITT
Super Member
USA
yes
Has anyone purchased suitcase weights for their BX? How much were they? I know weights are usually a $1 a pound but sometimes small weights are more.
/ Suitcase Weights for a BX #2
On the Kubota Build Your Own site:
1 FRONT WEIGHT BOLT KIT$6.00
1 FRONT WEIGHT BRACKET$103.00
1 FRONT SUITCASE WEIGHT$71.00
I believe the weights are 55lb ea. but I'd call the local kubota dealer to confirm that.
/ Suitcase Weights for a BX #3
They are 55lbs each.
/ Suitcase Weights for a BX #4
4shorts, what is that on the rear of your tractor; or are you just backed up against it?
/ Suitcase Weights for a BX #5
Looks like a homemade Zamboni
/ Suitcase Weights for a BX #6
Tom gets the prize :laughing:
I did this for a customer a few years ago. It reappears at the shop once in awhile for service. Works well. The one technical issue I had was getting the 3pt arms to lift the resurfacer. I got around that by shortening the two lift arms 1.5". Once I did that it's was all perfect.
Extra weights to keep the front down
I wonder how much off retail the will do? I guess I will have to call the dealer and see. I can get these at Lowes but they are 12lbs lighter. I am going to make my own bracket so I can use the grill guard.
/ Suitcase Weights for a BX #9
I just got some weights from Lowes
42lbs for $53 tax included. So $126 per lb.
Vs Kubota weights
55lbs for $71 ?? tax. So $1.29 per lb.
/ Suitcase Weights for a BX #10
Vs Kubota weights
Are the weights stock items? Don't believe I've seen any at my local Lowes.
/ Suitcase Weights for a BX #11
I bought a couple from lowes a month ago- had to special order them (shipped to store), but free shipping and excellent price.
Vs Kubota weights
I just happended to think you can save 5% if you use a Lowes Credit card.
/ Suitcase Weights for a BX #13
I'm guessing you don't want green weights, but they are even less expensive at 47$ for the 42lbs weight
Color does not matter but I don't think the little deere on them would look good on a BX.
/ Suitcase Weights for a BX #15
Yeah, pretty much heresy, but i thought i put it out there:)
/ Suitcase Weights for a BX #16
Some stores stock them, some dont. They will ship to store for free, or they told me ship to home for free, but only 1, order 2 or more and shipping gets charged.
The ones I got were the Troy Built ones in this link. They were 49.95 + tax = $53 each.
Shop suitcase weights at Lowes.com: Search Results
They have the Green JD ones, The black Troy Built ones or the Arnold ones (plastic coated).
/ Suitcase Weights for a BX #17
Obviously you've had this working for a while now, but I dug out a BX18/2200 manual that I'm mailing this afternoon to another member. I opened it to a random page this morning and it talked about ballast. I believe it said 275 lbs max. You are at 550 with 10 of them. Are you at all concerned about the front end on this rig?
/ Suitcase Weights for a BX #18
Not at all. Two and a half years and counting since completion and used daily. I really had no choice in the matter. Customer had the BX1800 on hand and this was the resurfacer he wanted mounted to it. He's also an engineer so he understands these things. He just told me to make it happen. He is very pleased with the outcome, I'm paid in full and everyone is Happy, Happy, Happy :thumbsup:
/ Suitcase Weights for a BX #19
I should have thought over that question before I even posted it. Duh! The loader is 400 lbs and they lift more than 175 lbs. I guess maybe that's a limit for the stock weight holder. And nothing you've touched is stock. :laughing:
So I guess I'm happy too.
/ Suitcase Weights for a BX #20
I actually thought it was a great question and observation on your part. The resurfacer never comes off the tractor. It's used only for that purpose and even though there's a lot of weight on the front you could almost pick the front up because of the weight of the resurfacer so I was never concerned about it. Like you said. Put an FEL in there and factor in what it will lift and your well over those weights. Ya I'll admit I tend to mod a bit :laughing:
(APPROX. 13) CASE INTERNATIONAL WEIGHTS (A63290)
(APPROX. 13) CASE...
PEERLESS 4-WHEEL DRYING WAGON (A63290)
PEERLESS 4-WHEEL...
Giyi 79" Vibrating Bucket (A62183)
Giyi 79" Vibrating...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Snapper 300Z (A62183)
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
