Power Trac Parts Cross Reference Thread
/ Power Trac Parts Cross Reference Thread #1
MossRoad
Super Moderator
South Bend, Indiana (near)
Power Trac PT425 2001 Model Year
Anyone think we should start a Power Trac parts cross reference thread for the new year?
Here goes.... :)
PT425
Aux PTO
Hydraulic quick connect
Female
PARKER 4050-2P 1/4 FEM CLPR
/ Power Trac Parts Cross Reference Thread #3
Great idea David, would we just input into same thread or someone compile?
PJ
I suppose we should just input into this thread until we get enough information to compile.
/ Power Trac Parts Cross Reference Thread #5
25hp robin/subaru oil filter part #'s
inlet thread size, 3/4''-16tpi
gasket 2.19'' i.d. with 2.44'' o.d. gasket thickness .190'' to .200''
14 psi relief valve setting
Robin, 248-65801-00
Amsoil, EA-009
Fram PH4967
Hastings LF410
K&N HP-1003
Purolator L14476 or P14476
Wix 51394
Stp s-4967
Stens 050-777
Napa 1065 or 1394 or 1395
Penzoil PZ39
Motocraft FL836
Baldwin B33
part #'s supplied by local Amsoil dealer I personally have used only Napa and Amsoil filters so far
/ Power Trac Parts Cross Reference Thread #6
hydraulic couplers
Parker series 6600
1/2''x1/2''-14NPTF x 2.08 hydraulic coupler male
1/2''x1/2''-14NPTF x 2.75 hydraulic coupler female
Purchased locally from MSC supply
/ Power Trac Parts Cross Reference Thread #7
25hp Robin/subaru air filter
I use a Kohler part#4708303 with Pre cleaner #2408302 air cleaner on my engine but I had to retain the original steel plate off the robin air filter to make it seal properly and note it is a snug fit but for difference in cost well worth the effort in my opinion
/ Power Trac Parts Cross Reference Thread #8
48'' brush hog disk conversion kit blades
original blades are solid mount with two retaining bolts Oregon brand
currently using ''swing-away'' style blades
Harvest KIng brand #D31-242 6pk disc mower knife blade $5
Harvest King brand #904-623 6pk bolt-on fasteners $9
I lost 1.5'' on cut width using this style of blades but considering difference in price and ease of availability plus the blades do not ''launch'' when hitting solid and unseen objects, well worth it for me
/ Power Trac Parts Cross Reference Thread #10
PT 1850 Info
Filters
- engine oil filter Wix 51034, Napa 1034
- fuel Wix 33195, Napa 3195
- hydraulic Wix 51759, Napa 1759
- air Wix 46294 or PA2422, Napa 6294
paint Rustoleum Machine Red, Flat Black
/ Power Trac Parts Cross Reference Thread #11
Does anyone know of compatible alternatives to:
Blades and bolts for the 48" Brush Cutter (PT425)
PT 425 Hydraulic oil filter?
Thanks
/ Power Trac Parts Cross Reference Thread #12
2007 pt 425 hydraulic oil filter oem; Parker #921999 10c, specifications, 1''-12tpi unf threads 20gpm flow rate 10 micron filtration 150psi max. pressure 225degree max. temp. 15psi relief valve setting alternative filter found locally was WIX 51551 and/or NAPA 1551 , I would recommend cutting open your OEM filter and checking for a relief valve and keep in mind this is a ''suction filter''? if anyone could clarify the difference between a hydraulic suction line filter and a hydraulic pressure line filter please by all means educate me I have cut open both types and could not discern any difference in manufacture internally
/ Power Trac Parts Cross Reference Thread #13
Supposedly the suction filters have better resistance to collapse. One of the challenges in suction is cavitation by cold oil, which can erode filters quickly. I have never seen a collapse spec.
All the best,
Peter
/ Power Trac Parts Cross Reference Thread #14
oem exhaust system part #'s for Robin Subaru EH 63,64,65,&72 (EH 72 is 25hp ) #263-34101-A1 exhaust manifold with flange for muffler (no muffler) exhaust exits on oil filter side of engine, #2703520101 exhaust gasket, #92630044 exhaust manifold kit with clamp-on style side mount muffler, exhaust exits on oil filter side of engine (exhaust manifold pipe would need to be extended for muffler to clear tub of PT) hope this helps for any one who wants to upgrade/replace their exhaust system
/ Power Trac Parts Cross Reference Thread #15
Does anyone know of a Napa equivalent for the Deutz fuel and oil filter for the 1430? Is there an option for the hydraulic filter?
Thanks,
Bill
/ Power Trac Parts Cross Reference Thread #16
For the PT1850, the filters are:
NAPA Filters:
Engine 51034
Fuel 33195
Hyd 51759
Air 46294 or PA2422
/ Power Trac Parts Cross Reference Thread #17
Thanks,
Bill
Deutz oil filter 01174416 -> Wix 84085 or 57085
Deutz fuel filter 01174696 -> Purolator f50284
Haven't yet researched/located alternatives for the hyd. filter.
/ Power Trac Parts Cross Reference Thread #18
Anyone using the wix/Napa hydraulic filters on 425? I'm due for a change but the pt OEM filters are $22 ea. No problem spending the extra $ if the pt filters are special for some reason. The specs on the wix/Napa filters do not indicate they are rated for suction.
/ Power Trac Parts Cross Reference Thread #20
Yep, it's what I use everytime.
