JUST MOUNTED NEW 54 BLOWER ON NEW 1026R -- WHAT IS SENDOR FOR ?? DEALER NOT KNOW -- SO I REMOVED IT BLOWER WORKS NORMALLY WITHOUT IT -- NOW WILL DISABLE THE REVERSE IMPLEMENT SWITCH PER FOLLOWING LINK -- THKS LLB
How to Disable Reverse Implement Option RIO on 2012 John Deere 1 Series SCUTs 1026R 1023E :: John Deere TechTalk – The Source for John Deere Technical Information
the sensor is only there for use in 2012 and newer tractor that have RIO,
Reverse Implement Option.
This sensor will tell the tractor that the Front PTO is operating, and therefore the
RIO system is in bypass and no action will be required by the user to operate the
snowblower while backing up, unlike a mower deck which will require the operator
to lift/hold his PTO switch while transitioning to reverse while the mower deck is
engaged.
yes,
and the system will move up into the line, probably anything that can
have a mid mower.
Removed the Sensor because JD Set-up tech advised sensor was involved with blower shut down when in reverse -- (case where I out smarted myself) So I and the JD Set-Up Tech was not aware that it actually was intended to allow blower to keep running until reading Dutch445 explanation / Thanks Dutch - ALSO the Sensor has wiring plug connector by the PTO coupler which I would just as soon not have to fool with --
and I DO NOT want the mower deck to keep shutting down in Reverse so have installed a simple 'L' bracket on RIO switch per the Link I attached to my first question -- was simple and very easy to do which solved the RIO stupidity on mower and blower ----
Thanks LLB1026R
