8n will fire but not start??
/ 8n will fire but not start?? #41
or here.. though I'm sure this willcome to a shock to Don.
'hard to believe' my but. Helps when you know what you are talking about....
yes, I am iced in and just got a new Powermatic Tablesaw. I am trying to get that put together and get all this crap out of my woodworking shop, which is my two car garage, to make room to get the tractor back in, it has been windy and cold so sitting outside is not good until the wind dies down and I can spray the starter fluid to see what happens. I have read other threads on other sites and most the have an original carb just put a new float and rebuilt it and they were good. I posted a new thread asking if anyone knew where I might get a couple 3 X 19 wheels for the front of my tractor. That salt water eat the back two up and I replaced them and now the front are going to go. May as well change them out while I am at it.
You know, I can leave the 3 point hitch up and come out the next morning and it will still be up. It may have fallen an inch. This is a good tractor. no oil leaks and it is sound and will be again. I will keep everyone posted.
/ 8n will fire but not start?? #43
Thanks for the update. Anyone that sells TISCO should be able to get you some wheels which would be most tractor dealers.Tisco Tractor Part Mart: Reliable Tractor Parts You Need. Fast :: RIM 19X4.00 6 BOLT (8N1015A) Do you have fluid in your tires? If you have calcium in them it will eat the wheels up.
/ 8n will fire but not start?? #44
Hi Pete I've read all of this & from the fact that this started when you were working it . Mine did a similar run rough & hard start, turned out to be the head gasket burnt between 2&3 cylinders ,on my 51. Now on my 50 it was just simply two plug wires mixed up. Wouldn't be too concerned about carb kit ,both of mine ran fine after disassembly & cleaning with spray cleaner ,one sat 2years the other for 4.5 years .Just my :2cents:
/ 8n will fire but not start?? #45
Well,I guess you fellas have never timed an engine by marking the crank pulley? Or are you saying there is NO crank pulley? I'm saying that this is the absolute best way to time an engine. According to CarlK's link,the timing is not so foolproof as SG makes out.
I'm also telling Pete that the distributor could be sending intermittent spark. PROBABLY Pete has a fuel problem,but there are MANY things that can go wrong with simple ignition systems also.
I'm a mechanic,in general,and i have not claimed to be a tractor specialist. don-ohio :)^)
/ 8n will fire but not start?? #46
So how do you determine TDC on an 8N?
/ 8n will fire but not start?? #47
Flathead = plug wrench and something long that fit's in the plug hole.:D
/ 8n will fire but not start?? #48
Easier said than done on an 8N. The spark plug hole in the head doesn't line up with the piston. There is also very little room between the head and the gas tank. I successfully statically timed my front mount 8N the first time I tried it using the I&T manual. Its really easier than it looks. I copied these photos off Yesterday's Tractor site. Its the best source of info on old tractors. I suggest Pete also search there for help.
/ 8n will fire but not start?? #50
why booger something when the CORRECT way is easy.
Besides.. getting tot he crank pulley requires a pocket gnome and minature ant sized tools. it's cramped up there with a front mount.
Ahh.. so you are saying that you know MORE than the engineers that designed and built the N... as they are the ones that devised the way to static time it.
I'm happy to meet someone that knows more than the people that designed the machine did.
wow...
so... you never worked on one eh?
/ 8n will fire but not start?? #51
I'd time the 8n per the book, but if someone wanted to probe a cylinder, I have found that the long pull ties to be a bendable object unlikely to scratch anything.
/ 8n will fire but not start?? #52
hard to beat, using the RTFm method. that's how the ford engineers designed it.... must be something to it... :)
/ 8n will fire but not start?? #53
I remember doing it once when I was a teenager. Our 8n had the front mount distributor. I used to have to keep the points absolutely immaculate, else the thing would go all to heck. I was just a kid, still learning...and I told my dad one day that it didn't make any sense....nobody in the world has to keep their points that nice, and there must be something wrong with the coil.
Dad bought a new coil, and I never had to touch the points again.
I loved that tractor. Such a short length, easy to maneuver, quiet, fairly thrifty, would pull nicely sized implements, etc. The brakes sucked, but that was bound to be due to my ignorance. I replaced the seals once and put new pads on it, and it had great brakes for a time, but the seals gave way again. No internet back then, so I couldn't ask folks who conquered the problem what the solution was.
/ 8n will fire but not start?? #54
yep,.. the early 8n falls in a bad spot for axle seals. late 8n has 2 seals. and 9n/2n can use sure seals. early 8n.. single seal and not much to do about it.. unless you repalce the axle and hub and seal all as a unit.. most don't repalce the axles.. nor do they seal the edge of the seal to the trumpet either..
/ 8n will fire but not start?? #55
Hey Parispete, got more info for ya.
This first link is probably the best explanation of how to time a front mount Ford distributor I've seen:
Re: front mount distributor - Yesterday's Tractor Co.
I just found this tool to use when doing the timing, wish I knew about it when I had my 8N, I would have bought one in a heartbeat:
Ford Front Distributor Timing Jig - Model 9N-1200TG
Here's the forum you need to visit to find help with your 8N. All the participants have either 9N, 2N, or 8N fords. If anyone can help you with your tractor, they can. I visited that site regularly when I had problems with my 8N:
Yesterday's Tractors :: View Forum - Ford 9N, 2N, 8N
Here are a few sites for 8N parts:
http://www.n-complete.com/Index/index.php
http://www.dennis-carpenter.com/cars.php
http://www.just8ns.com/
This site has some good videos on repairing 8Ns:
http://www.farmtractorrepair.com/01150.html
Good luck with your tractor.
/ 8n will fire but not start?? #56
G'day lots of good advice here just wondering though did you clean the points contacts before installing? The reason I ask is that they come with an anti corrosion film on them that can stop them from throwing a good spark , you say you are getting a 1/4" spark it does not sound like much to me I think it should throw a stronger spark than that. In saying that I have never worked on any of those early fords (not too common over here) maybe soundguy will correct me on the strength of the spark. Good luck with it keep us informed of your progress.
Jon
/ 8n will fire but not start?? #57
he's already getting that info.... ?
I gotta say.. this is the most discussion I have ever seen on timing a front mount.. that 1 pafge out of the manual says it all.. all ya need is a straight edge and to be able to measure 1/4" :)
n-Complete
Dennis Carpenter-Ford Cars
Just8Ns - Ford Tractor Parts and Restoration
Ford 9N, 2N, 8N Tune-Up
/ 8n will fire but not start?? #58
You're right. I got carried away.
/ 8n will fire but not start?? #59
i wasn't even really singling you out.. just the entire thread amuses me. there's no reason to fabricate elaborate ways to time a front mount when 1 page out of the 1939 service catalog shous how to do it with a ruler.. ;)
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
International 37 Square Baler (A65640)
International 37...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
