Haoleguy
Did your wife get a finder's fee? She deserves one for pulling you out into public........Cheers, Gary
Also if you keep it to the 160-180,000 mi mark be ready for a few big repair bills and then be good till almost 500,000 if properly maintained. The 7.3 has a few issues that tend to pop up around that time. But otherwise very reliable and strong.
I would wonder about the excessive rust.
I live here too (Florida)......
That much rust makes me wonder.
Certain time periods of the 7.3 after they added the turbo result in head gaskets, timing chains, and a few other issues that were mostly resolved when ford updated parts. If you had work done more recently that those items were replaced/repaired anyway you wouldn't notice. I made it to 180,000 before my head gasket blew and at 183,000 my timing chain decided to give up. Good engine, teething issues after some updates to it. If it is newer than about 2001 MY you should be good. If the engine has been rebuilt or replaced you're good. Just a really high failure rate that is fixable.
I have the first version of the psd that they pretty much just slapped a turbo on at the factory and changed a few parts to accommodate. .
The truck is a 95.5 PSD. They did make a bunch of changes between 94.5my and the 1996my but started calling it a power stroke for the 95my. A lot of the parts for the 7.3 are the same between 95 and 2000 and even after.
My son and I took the bed off last night. We cut the heads off of the bolts that hold it on, took out the tail lights, filler neck, and aux fuel tank.that is not a PSD.. it's the same old 7.3 NA engine with an ats turbo essentially. It bears little resemblemnce to the PSD.
date wise.. somewhere around 89 thru 93.5 was the NA 7.3, from 93.5 to 94.5 was the ats 7.3, and that's when the psd came out.. I believe, the early models thru 95 were 5spd only.
again.. can not compair a na 7.3 or a 7.3 ats turbo directly to a 7.3psd in terms of repairs.. they are different engine.
all were solid well built near bullet proof designs but they ARE NOT the same engine.
Good deal!
Now that the bed's off it's a good time to check the gas tank straps (prone to rot and break), change the rear diff fluid (easy access), the rear shocks and mounts (might as well replace the shocks), the leaf spring shackles (prone to rot and cracking), and exhaust. A straight pipe vs the muffler won't add a ton of power or even be very noticeable unless you replace the entire turbo back exhaust with a larger 3". Here in NH the turbo counts as a muffler so you don't need a muffler for state inspection. Your state may allow that as well.
when, if ever he had the radiator flushed. If he hasn't I will flush it and follow the above recommendations.
