Plasma cutting - how much air do I really need?
/ Plasma cutting - how much air do I really need? #51
Or maybe he just wants one. It's his money!
And TBN folks are just the ones to help him spend it whether WISELY or not is yet to be determined.
/ Plasma cutting - how much air do I really need? #52
I have had a plasma CNC machine since 2005. I got it as a hobby, but its ended up being used more times than i can remember to make a bracket here, repair this item there, etc.
I can make a quick drawing in Coral, transfer it to a cut path drawing on the computer in my shop and have the part cut in nothing flat.
Last summer i added a hydraulic down assist to my post hole digger, and needed a simple attachment point for the ram. Took about 10 minutes on computer then sent it to the plasma table. A few minutes later the part is sitting there ready for a light sanding and welding to digger bar.
Im so spoiled now, i really dont care what this hobby cost me 7 years ago. id do it again in a heartbeat.
I live 45 minutes from town, and i HATE having to drive there to get a part i can make myself.
/ Plasma cutting - how much air do I really need? #53
I just kinda smirk to myself everytime I read one of these threads where someone wants to spend several hundred $$$ for a plasma rig because they cant make a decent cut with any oxy acetylene torch or think its cheaper because they dont have to buy gases. Danger of storing compressed gas bottles is less than storing a plastic gasoline container so any fear there is only perceived and not real although just as in storing any flammable product proper precautions should be followed. Please post back your costs for equipment, parts replacement ie tips, nozzles, tungsten electrodes etc, larger air compressor and quality of cut that you get using you new plasma rig compared to what it would have cost you to get your oxy rig upgraded.
If you already have a cutting torch and are only going to be using Carbon Steel, then your money would be better spent in learning how to use the torch you have and investing in some larger bottles and a bottle cart to move them with.
i am just finishing up with yet another 5 year contract on my torches, and it will be the last one because i've gone to a plasma cutter. i will still have the portable torches and tank setup i've had for the last two decades, but for any cutting done in my shop, i will be using a plasma cutter. my current tanks are a 118cf acetylene and 250cf oxygen, and the last time i checked, it was over $100 to fill both. if i go through 2 tanks of each a year, that's $200. around here, bottle contracts are $35-$50 per year per bottle, so there's another $350-$500 for 5 years. tanks never run out at the same time, so every year that's four round trips to exchange tanks - $12.50 fuel per trip, give or take, plus all that wasted time. just that is $1600-$1750 over the next 5 years, which is pretty much what i just paid for my hypertherm 45. in the first 5 years i'm breaking even, and i'm thinking that i should make at least 10 years before the cutter fails. the cost for gases over the next 5 years will be the same, or likely more, based on inflation. what i spend on electricity and consumables will be far less than the second 5 year contract. i figure i'm break even somewhere around year 6 or 7, and past that i've saved money. sure, it's more up front, but that's also because i bought a more expensive machine. buy a cheaper one and your 5 year contract and first fill will not be much less than the cost of a plasma cutter.
You can buy or make a little chariot for you cutting torch also so you can just drag (actually roll) it along, use straight edges also, but with any equipment, you need some skill to use it for good cuts and long use of the equipment. Dragging the tip on the metal will mess up the tip if a bit of spark or molten metal pops up on to it requireing expensive replacement parts.
the tips shipped now are called "drag" tips for that exact reason - that's what they are designed and intended for.
i haven't used mine other than one quick test - other things taking priority right now, but i can say that the cut is far better than a torch. i made one cut with a straightedge and i didn't take any care in paying attention to travel speed or anything. when finished i was left with the slag/dross along one edge. i smacked it with a hammer and it fell off to reveal a clean sharp edge. i have spent two decades with a torch and i can make pretty decent cuts when i need to, but i can make better cuts with the plasma on day one. i can guarantee that i will be saving money and time on grinding.
another plus for me is that i won't have to spend any of my off time getting tanks. i'm decades from retirement, so when i need to get a tank filled, it has to be in the tiny window of their business hours and my off hours, generally saturday morning. that limits my evening time that i can do anything if i have to wait until saturday to get tanks swapped.
/ Plasma cutting - how much air do I really need? #54
People have ways of justifying things when they WANT them and don't NEED them. I'm in that boat just not as much as i was in the past.
Don't saying you don't NEED the plasma; you may very well need it. I've had the money saved up for over a year now for a plasma (Hypertherm 45 or Miller 625) but cannot get past the fact that I really don't NEED a plasma cutter. Although it would be awesome to have if needed.
I can take a 5-10 minute drive to my local welding shop and have the CNC laser cut parts for $75/hour. How many hours cutting can I get for the price of a good plasma? At least 24hrs...
Not nearly as practical than having my own 24hr/day accessible means to slaughter conductive materials!
I will probably buy one soon as I really WANT one lol
/ Plasma cutting - how much air do I really need? #55
Do NOT buy the Hobart 110 unit with compressor if you want to cut anything other than sheet metal! I made the mistake of buying one because it said it could cut 1/4", at the time I thought that was all I would be wanting to cut. I tried it on a piece of 1/4" x 2" flat bar and it barely made it through it. I knew immediately that this wasn't the machine for me. I took it back to the retailer where I bought it and got a refund, went to the welding supply store and bought the Hypertherm Powermax 30 and couldn't be happier. I run mine on 110 (only because mine didn't come with the adapter cord they have now) and I routinely cut 3/8" x 6" flat stock and use it all the time. Now my biggest problem is scraping up the money for a bigger Powermax! I want a 60, don't need it, just want it! LOL
Happy cutting :)
/ Plasma cutting - how much air do I really need? #56
The only ones of these I have heard of run off of 110v and are therefore limited in the thickness of metal they can cut. If you know of a 220v one, I'd be interested to hear about it.
Lincoln has one I thought that had a built-in compressor and could also use external
air when cutting thicker material.
I think it was their Tomahawk line that came out about a year or two ago.
/ Plasma cutting - how much air do I really need? #57
I've had a hypertherm 45 for about 5 years now , no trouble I absoulutely love it. Out of all my tools it would be 1 of the last to go, my oxy , acet just sits and collects dust.i have proBley fabricated enough items to pay for it many times over. What you think you don't need may actualy be needed more than you think. I highly recommend hypertherm.
/ Plasma cutting - how much air do I really need? #58
I was in the same boat. It wasn't the amount of money but the fact that it was a large chunk of money for a tool that I would love but only occasionally use. I finally broke down and bought one from Everlast after others here had good things to say about them. Every time I use it I'm extremely happy that I bought it but it sits, sometimes months between uses. I would even love a CNC table with a plasma cutter but know that I would never use it. But if I look around my shop/ garage I can come up with dozens of tools that I don't need. For example I have a cordless, corded, and several pneumatic impact wrenches, I could easily get by with just one. But I have accepted that my wants make me happy and who can put a price on that?
/ Plasma cutting - how much air do I really need? #59
I am the same....when I bought my first cnc plasma (about 14 years ago) I told my wife that I would pay for it (working nights and weekends) in about 6 months.....I had no idea if I could, and I'm not sure she believed me...but she reluctantly agreed. I learned how to use it and ran it pretty hard on nights and weekends...and earned enough to pay it off 100% in less than 6 months. Today it is mine (PlasmaCam, Powermax85) and is used for hobby use mostly. I take on a few jobs here and there to keep my tool buying slush fund active.
I find myself using the cnc plasma for more things than I dreamed of originally. From complex cut parts, to artwork, to making a simple washer. I can walk to the PlasmaCam and draw a simple gusset, bracket, washer....in just a couple of minutes, thow the appropriate material on the table and have the part in a few more seconds. Most small welding shops in my area come to me often when they need a part quickly...as I can often cut it and sell it to them for less than they can make it themselves. When my machine is on, and I'm cutting parts for hire...it earns at least $100 per hour.
If I didn't have a great job at Hypertherm....I would be able to earn a good living with the PlasmaCam in my shop...I have no doubt whatsoever! Next to the angle grinders...the most used tool in my shop is the cnc plasma.
Jim Colt
/ Plasma cutting - how much air do I really need? #60
I have an Everlast, mine works great and saves alot of oxy accet. cost. Cuts in less time and alot cleaner cut.
As for dry air, I have copper lines in my garage with 3 "zig zag" setups with low drains to cool the air. One dryer at the end of the run and another on the machine. Never had an issue with moisture in all sorts of temps (unheated garage).
Get the right plasma (big!) and you will never go back....though it cannot take the place of the oxy for heating and such![/QUOTE]
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
1005 (A61166)
1005 (A61166)
Giyi NWS38 Non-Connected Wood Splitter (A60463)
Giyi NWS38...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
