disc mower advice
/ disc mower advice #11
Here's a link to the Kuhn website. You will find tractor requirements and mower specs. I did a quick look, and your tractor would probably just barely meet min HP for a GMD600. (8') Probably better the 500. (6 1/2') But, it's not just HP that you have to consider. Your tractor also has to be big and heavy enough to handle the weight of the mower. (if it's 3 point hitch) I run a GMD600 on my NH TN70A with no problem. But, that's a larger, heavier tractor with more HP than yours. I've never tried it on a smaller tractor.
A disc mower should cut a lot faster than your sickle bar haybine. When I'm cutting, my ground speed is usually around 5 mph.
/ disc mower advice #12
Hi everyone im new to the forum and I am in need of some advice. I have a kubota mx5000 (about 50hp) with a New Holland 477 mower conditioner that I cut about 15 acres of hay with. It works but takes forever because I have to go 1st low the whole time or else it will plug. I am planning on getting another 15-20 acres this year. Does anyone know how big of a disc mower my tractor would handle? Thanks in advance for any help.
5 head is big enough. We have good new and used in stock. Check them out here Sweet Farm Equipment Ken Sweet
/ disc mower advice #13
I've used a Kubota M4900(45 pto hp) to pull both a NH 617(9 ft cut) and a Vermeer 7030(9 ft cut) BUT both were mounted on a caddy which is the only way I would own a 3pt disc mower. Straight 3pt disc mowers are a PIA to attach to tractor and IMHO put undue strain on RH wheel of tractor while in transport especially in a custom hay baling operation. Plus I think a caddy mounted mower follows the contour of the ground better. The M4900 would handle the disc mower but needed a little more HP so I bought a M70409(65 pto hp)
/ disc mower advice #14
You people must be content going a lot slower than we do.
/ disc mower advice #17
Yep gophers(moles) & fire ants make hay fields way to rough to go any faster.
Wild hogs get ours several times a year and those dang gophers
/ disc mower advice #18
Luckily no feral hogs in the fields I've been haying but they're not many miles away.
Bobcat A770 (A60462)
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
