Buying Advice What does the JD model number system
/ What does the JD model number system #1
CesumPec
Member
Ocala National Forest, FL
JCB 214 Loader BackHoe, Farm Tractor TBD
Can someone direct me to any previous discussion of what the JD numbering system means? I was at an auction today and the prices and model numbers are all over the place. There doesn't seem to be a direct relationship between HP and model number like there is with Kubota. I just want an easy way to quickly evaluate a tractor so know if it is one in my range or not.
/ What does the JD model number system #2
I went to tractordata.com, choose JD. You can view by model numbers, year of mfg, hp or series. You can see a little bit of relation to hp in some of the model numbers. I saw a relation to the first number and the letter on the end. But I'm just guessing.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
New/Unused 72in No Till Seed Drill (A61166)
New/Unused 72in No...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2019 FORD F-250 (A60736)
2019 FORD F-250...
