Acetone and tranny fluid !!
/ Acetone and tranny fluid !! #1
Bday
Lucerne, IN
53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
Thought I'd mention to the guys that didn't know about this mixture. I found it on another tractor forum. The guy's there tested all market sold rust busters, and said the mixture of 50/50 acetone tranny fluid beat everything hands down. Every time I use it on rusted bolts and fixtures it proves to work great. We tore an IH wide front down today. The axle tubes wouldn't budge. We heated and hammered, they would not budge. Soaked them with this mixture in 6 hrs could slide them out by hand. Try it. It works!!!
/ Acetone and tranny fluid !! #2
remember to agitate often!
/ Acetone and tranny fluid !! #3
I realize that most members adhere to safe measures when working with chemicals, but I wish to insert this warning. I once worked at a major boat manufacturer in Acetone Recovery. Acetone is highly volatile and is a flash explosive.
/ Acetone and tranny fluid !! #5
Good information - thanks, creekbend.
/ Acetone and tranny fluid !! #6
Thanks for the recipe. I may well try it next time i need to unstuck something rusty if my usual Kroil or brake fluid don't do the job.
/ Acetone and tranny fluid !! #7
The OP formula is a variation of Ed's Red bore cleaner used for gun cleaning. A penetrating oil test by Machinist Workshop magazine had the following results for removing rusted identical nuts in a scientific environment..
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster .............. 214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............. 106 pounds
ATF-Acetone mix....53 pounds
The tranny fluid must affect the flashpoint of the acetone. We were and have use rose buds around the mixture. As with anything flammable I wouldn't recommend using heat around an open can or large amount of the stuff! Mixture appears to boil more than ignite when exposed to flame,but I'm not trying to get any flame around a large amount! Common sense must be applied!!!!
/ Acetone and tranny fluid !! #9
Acetone had a boiling point of around 150degreesF. The gas given off is highly combustible..
/ Acetone and tranny fluid !! #10
Both of those ingredients will burn although the Tranny fluid is much higher temp for ignition. Maybe the acetone was burning with an almost invisible flame that you didnt see. I use my used motor oil and hydraulic oil to burn brush piles with and it is a good fire starter.
Try your 50/50 mix in the dark and see if it burns.
/ Acetone and tranny fluid !! #11
Yeah, those msds sheets are for chickens and osha! Neither have any common sence.
/ Acetone and tranny fluid !! #12
most of the time you add oil to something like gas.. you raise the octane.. thus the flashpoint.
/ Acetone and tranny fluid !! #15
Actually, the higher the octane, the higher the flash point
you do realize you just agreed with me don't you?
high octane.. high flashpoint.
that's EXACTLY what I said...
/ Acetone and tranny fluid !! #16
Octane is an index of a fuels RESISTANCE to volitilization. You may have been thinking of CETANE number which is more volatile as the number goes up.
Also liquids are LESS volitile as flash point goes UP. Acetone has a flash point of NEGATIVE 20C. That means it can burn when that cold.
/ Acetone and tranny fluid !! #17
I've been using the 50/50 mix since I heard about it on a certain (unique) car forum...probably 7-8 years ago...
I keep the mixture in a mason jar with a good seal and pour it into a pumping oil can when I'm working on something requiring it...if your container does not seal completely the acetone will evaporate away over time....
/ Acetone and tranny fluid !! #19
re-read my post.. AGAIN.
the higher the octane.. tha 'harder' it is to ignite and burn that 'fuel'.
ie.. both #'s go up.
I know what cetane is and that's why i didn't mention it.
/ Acetone and tranny fluid !! #20
Yes, but gasoline dissolves oil forming a solution. Acetone OTOH, forms a suspension with ATF. You have to keep it shaken up or it settles out. Such has ~no effect on vapor pressure and thus flashpoint.
larry
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
2014 FORD F-150 (A67714)
2014 FORD F-150...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2025 Auger with Bits Mini Excavator Attachment (A66734)
2025 Auger with...
213065 (A64276)
213065 (A64276)
2014 ISUZU NPR S/A 4X2 17FT BOX TRUCK (A69167)
2014 ISUZU NPR S/A...
