How To Build A Traditional Hay Stack?
   / How To Build A Traditional Hay Stack? #1
Localmotion
Gold Member
Spain
New Holland 50-86 / Siromer 204S / Case CK-28 / Cat 302.5 / Nissan L35.09 / Nissan Atleon 110
As the title says - looking for tips from those who have experience of building a proper loose hay stack...
I have plenty of experience of baling when I was in the UK, but around here balers are few and far between and contractors charge heavily!. Often when we clear plots of land there is good grass which could be made into hay at different times of year, and so I am looking for a cheap affordable way to store it without getting the rain into it. I seem to remember that a traditional haystack sheds the rain if properly built?
Any tips / ideas to make the process as simple as possible will be greatly appreciated :thumbsup:
   / How To Build A Traditional Hay Stack? #2
I don't know, but will follow this thread because I think it is interesting.
I have an old dairy barn, circa 1920 with the original hay hook in it. I don't think it was used for bales by the looks of it.
   / How To Build A Traditional Hay Stack? #3
Try and get the outside so the hay stems are in a semi vertical type position. Do the top the same way so the stems point outwards. Sorta like thatching. I many cases a poorer quality of hay is used to cap the stack. You may also consider sprinkling a little salt between layers.
And yes; it all depends on how the hay is gathered as to how the stack is made. It doesn't always have to forked onto a hay wagon. Sweeps, things called buckpoles etc may be used. Takes a lot of the labour out and is definetly easier than the small square bales.:)
Check out my Avitar.
At one time the area I grew up in used what was called a tractor mounted Farmhand and Stack movers to handle hay.:):) farm hand.jpgP8120040.jpgP8120070.jpgP8120037.jpgP8120031.jpgP8120030.jpgP8120041.jpg
Thanks Egon - great photos... Is it your own collection or a museum somewhere near you? My wife has family in Canada and really hope one day we can go visit - especially if I can spend some time looking at old machinery :licking:
Around here it is difficult to grow hay unless spending lots of money of irrigation. Part of our business is clearing fields / plots which have become overgrown to reduce the fire risk... In the past we have always simply scraped all the weed off into a pile in the field, and left it to rot. However on plots where we have now done this several times we are actually starting to get some half decent grass growing during winter - and because of the past scraping there is now not many rocks or stones to damage a mower. We have a topper, so this year I am going to start topping the plots which have been previously scrapped and had thought that I would convert an old muck fork into a sweep to collect the cuttings when they are dry to feed to our horses, donkeys, sheep, goats etc...
The problem I have is that the plots are generally small. I had thought that I could make a stack on each plot, and then once I have enough to make it worth while I could get someone to go around all the plots and bale the stacks for me. But I think this will still cost more than any hay I get will be worth!
Another option is that I can load the grass onto our lorry and bring it back home to build a stack, but I'm not sure if it would work out well as the stack may sit for a few weeks (catching the dew and any rain) before getting more grass added to it - risking the chance of simply building a giant compost heap rather than a haystack! Is it possible to build small hay stacks (ie - what volume of crop is needed to ensure the majority stays dry)? Or has anyone else tried building a stack which can be added to throughout the season?
It may be that I am just dreaming, and actually this "free" hay will cost me more in time and effort than buying in bales, but it just seems such a waste to see it piled up to rot and not use it!
   / How To Build A Traditional Hay Stack? #5
Pictures are from the Stettler Alberta Museum.
With small amounts and a sweep think about
tarps and frames to allow circulation???:)
Please note that My agriculture experience is from a long time back from one specific area so it may be a little shady.:eek:
Thanks again Egon - the tarps / frames idea is a good one. I even have an old Poly tunnel frame here somewhere, so definitely feed for thought (and hopefully the animals)!!
"long time back" experience is what we're needing here - I have many years farming and machinery experience, but here in Spain I can't justify the cost of buying livestock related machinery not vital to our core business as the animals are now my hobby instead of my income!
   / How To Build A Traditional Hay Stack? #7
As a boy we hayed with horses and put it into the barn loose. The hay was cut with a six foot ground driven mower pulled by the team and ,when dry, raked into windrows with a ten foot wide dump rake. These were then cut into sections and rolled up into tumbles weighing about fifty lbs. with a hand held "Bull" rake. Picture a comb with eighteen inch wooden teeth four inches apart and four to five feet wide. When the teeth were flat on the ground the handle came out straight up but was bent in a quarter circle forward and ended waist high in a two foot horizontal section that fit the hands. The handle was split in two sections in the curve and attached at the third points of the comb back and there was a round cross hand grip where the two sides come together. The handle and back beam were of ash and the teeth were of maple. Whole farms were raked with these before the invention of the dump rake which was inspired by them.
These tumbles were pitched onto a hay wagon with a pitch fork and built into a load in a regular pattern as they bound together and had to be pitched off in exact reverse order if not using a hay fork.
To build a stack outside plant a wooden pole about fourteen feet long and three inches in diameter into some dry ground so it sticks up eleven feet or so. Add some old planks or crushed rock in a circle around the base to ****** moisture uptake if you wish. Then pitch off your tumbles around the base of the pole in a circle three or four rows of tumbles out from the center treading each one in with your feet . Add more layers again treading them in and filling in any low spots by putting the center of the next tumble over the gap between the ones below. Round and round up and up pulling in the last layers slightly packing and treading as you go to get it as dense as possible. At the end of each day comb down the sides with a pitchfork to line up the outside layer of hay to promote runoff and pitch the combings back onto the top. I'd cover with a tarp to save wastage especially until you get the whole stack built as you don't want water to get into the center. When you get to the top of the pole set back each layer sharply to build the peaked haystack shape and throw on a layer of hay you don't mind wasting if your not going to tarp it.
Smaller stacks without center poles are called cocks and can be built with just a dozen tumbles of hay and were often hastily built when rain approached. A tumble if picked up right with a pitch fork can be carried over the shoulder with the handle almost vertical for quite a distance. You can then pitch it up as far as your arm and the handle will reach and pass it to the man building the stack.
   / How To Build A Traditional Hay Stack? #8
It sounds to me you need to investigate silage before the large round bailers came into vogue around here it was popular I have never done it myself so you need to do some research Basically the grass is cut semi dried and packed into a pit cut into a hillside as much air as possible is squeezed out by rolling the pile with the tractor wheels as you are loading the pit then the pile is covered with a large plastic cover dirt around the edges to keep it air tight. The grass ferments /breaks down into a fowl smelling product that the stock love and is twice as nutritious as hay
   / How To Build A Traditional Hay Stack? #9
Localmotion,
If you go to Youtube and search for 'hay sweep' you should find a modern home built one in action. It's on a Kuboda with a belly mower and carries some impressive loads of hay for the size of the tractor. The dimensions are given somewhere under the videos or in the comments. This is a two parter. There's also some video on Youtube of a horse drawn sweep and stacker in operation. One of the workers throws a white powder onto the hay and I actually have a question in as to what that powder is. Fortunately Egon has confirmed my theory that it must be salt. I can't remember what search words brought up the video with the salt. I've been interested in this for a long time and sometimes use 'hay sweep, sweep rake, bever slide, and hay stacker.
   / How To Build A Traditional Hay Stack? #10
Yes the powder would be salt. It draws excess moisture out of hay that is not quite dry, helping to prevent mold and makes the hay taste better to the stock it is fed too. We used to go through a 100 pound bag per year for barns that held some forty ton of hay.
   / How To Build A Traditional Hay Stack? #11
Thanks vtsnowedin and egon as well. I've been fascinated with these things since I ran across some sales literature on them at my Allis Chalmers dealer, in the 60's or early 70's.
   / How To Build A Traditional Hay Stack? #13
Here is another option: Horse-Drawn loose Haying at Grank-Kohrs Ranch - YouTube
The first part of this video: The Amish Way of Making Hay - YouTube is how we loaded loose hay as a kid. However, instead of using hay forks at the barn or manually throwing it off with pitch forks, there were two ropes that went from the front of the wagon to the rear which were used as slings to lift the load similar to the hay hook. A team of horses or tractor was located at the opposite end of the barn to pull the rope up and draw the bundle of hay into the barn. The spreader bar the rope slings hooked to had a release with a rope attached to it followed the bundle into the barn. This rope was marked allowing the person operating the release rope to identify where the bundle was which allowed the bundle to be dropped where it was needed.
   / How To Build A Traditional Hay Stack? #14
Today some forms of acid may be used when putting up hay. I'm not familiar with them.:)
   / How To Build A Traditional Hay Stack? #15
Egon,
My neighbor used to have an injection system on his balor that sprayed some kind of preservitave into the hay. Could that be the acid you mentioned?
Some really great ideas & vids - thanks guys :thumbsup:
Egon,
Definitely I've never seen any sort of additive for hay used in the UK or here in Spain. When I worked for a contractor we did used to add enzyme to silage - I had a tank fitted to the front of the tractor which sprayed enzyme directly onto the pickup of the baler to ensure the grass was evenly treated. We also had a sprayer which dosed grass passing through our self propelled forager for clamp silage - is it possible your neighbour was baling silage or haylage not hay?
Another good idea, thanks Timbatrader - I spent much of my life in the UK making both clamp and baled silage each year for ourselves and also contracting to other farms. I even got to clamp about 250 acres while spending a month on holiday at friends farm near Te Awamutu in Waikato! :thumbsup: NZ is a truly beautiful country and at the time I was very tempted to sell up our dairy herd in the UK and start again - but decided instead to modify our system to a NZ style in the UK. It worked well (my former business partner still has the farm), but now wish I had made the move as I'd probably still have cows today (it's a long story)!
I must admit I had not really considered silage here in Spain because the climate lends itself so well to making hay! :laughing:
You have now got me thinking though that it could be a good option as we could collect it from the plots on the same day it is cut and then add it to a sheeted field pile at home... Silage would be good for the sheep and goats, but I'm not sure how good silage is for feeding to horses? When I was a kid my stepmother used to occasionally get silage baled if the weather broke before we could get the hay made - but I seem to remember there were a few things to be especially aware of when feeding it to the horses and she used to also buy a lot of hay in to supplement the silage? Anyone have any tips?
   / How To Build A Traditional Hay Stack? #17
Egon,
It may have been prionic acid but that is the limit of knowledge.:D
   / How To Build A Traditional Hay Stack? #18
Thanks Egon. Your knowledge and mine are equally scant, on the subject.
   / How To Build A Traditional Hay Stack? #19
My horses love balage baled silage only problem is I don’t use enough to be able to use a full bale once opened before it goes off
Another option I have heard of but not used that could work on a small scale. Grass is cut left to wilt for a day then stuffed into large plastic garbage bags suck as much air out with a vacuum cleaner then seal the bag. It might be useful to pile the grass up and roll it with a vehicle before stuffing it into the bag to compact it and get as much air out as possible. A lot of work for a small amount of feed. But you don’t need special gear and you can open one bag at a time, as you need it saves it going off
The only problem I can see with the garbage bag idea is that it will be very difficult to get the compaction necessary / expel enough air - even if the grass is rolled first, it will expand again while trying to stuff it into the bag and it would take a lot of vacume pressure to make decent silage....
If I made a small clamp or field pile, I can layer the grass abd compact it using the tractor, and at least I could re-sheet it every day after taking out the silage I need - that said after a few times of opening and re-sheeting a clamp I'm sure I'll still get a lot of waste...? Also to make a clamp narrow enough to be able to keep an open face is not practical - my use is only very low (approx. 2 conventional hay bales per day) which would mean the clamp would need to be narrower than the tractor...
So maybe it is back to the haystack idea...???
2019 CATERPILLAR 304ECR EXCAVATOR (A60429)
2019 CATERPILLAR...
2020 DY TP90 TRAILER MOUNTER CONCRETE PUMP (A59905)
2020 DY TP90...
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
