Yanmar verses Kubota
/ Yanmar verses Kubota #2
Looks like they sure have thought out the controls and user convenience not surprising after owning an old one with all the handy well thought out features on them. The speed of the loader at idle is a big deal I can see where that would be nice.
/ Yanmar verses Kubota #3
I'm sure my Wifey would love all those features to. LOL :confused:
/ Yanmar verses Kubota #4
As an EX450 owner, I would love to watch this video. It comes up "not currently available". Who got upset, Yanmar or Kubota?
/ Yanmar verses Kubota #5
We own a BX2200 and BX2660 and the Cub/Yanmar sure has some nice features; not worth trading, but surely something to consider when buying new.
/ Yanmar verses Kubota #6
The main points of the Video was that the small Yanmar vs. the Kubota Bx series had a faster loader at all speeds, especially evident at idle, and the Yanmar has the ability to change the Hydrostat ranges on the move, while the Kubota Bx has to stop to change ranges. The third and final important point was that the Yanmar has position control on the 3pt which the Kubota Bx lacks. These are good points.
James K0UA
I just checked it and it comes up for me, maybe it was just temporary.
/ Yanmar verses Kubota #8
I don't have a Yanmar dealer anywhere nearby, and if there is, they aren't prominent. That would decide it for me. I do wish that Kubota would pay attention to the small details like the position control and work lights, but that wouldn't be a deal breaker for me, nor would the loader speed at idle- that is a non-issue. When do you do loader work at idle? And, a second or two difference at half throttle is sure splitting hairs; and I noticed that they didn't compare speed at full throttle. I would imagine that they must raise the same, or they would have shown that. So, loader speed is a non-issue, to me.
Kubota also has a broader selection of tractors than Yanmar does.
I believe in Yanmar as a quality tractor. But, I'm not sold on them as superior to Kubota.
/ Yanmar verses Kubota #9
While I haven't actually owned either model of these tractors being so called "compared ", I have owned both Kubota and Yanmar of close to the same size and rating and were close to being able to do the same task with each, Though the Kubota was not suited for having a FEL the Yanmar does have the option,....
I thought this Video was going to be a Yanmar / Kubota showdown:D , To me was not impressive to only compare the FEL speed and preset rear lifting height, :cool: actually the 3-pnt lifting height would not be a necessary feature for me, as I like to have the ability to pull the lever back lifting the implement all the way clear of the ground in one motion, as well as lowering all the way down, I never really find it necessary to need positioning anywhere in between, Besides most lifts can be stopped at any position anyway, ;) To me these comparisons was nothing more than a cheaply produced advertising scheme, Surely Yanmar has more to represent in this tractor :confused: I'm sure they put them through extensive testing and have more to show for it, ... Show us some plowing, how it maneuvers, digging with the loader bucket or at least a full load of dirt in the buckets while lifting, Ya know! some real working conditions,...
/ Yanmar verses Kubota #10
I wish my loader worked that good I would be very happy. I dont like having to have the engine wound up all the time or having to throttle up and down especially dumping and reversing to get another load but thats me.
/ Yanmar verses Kubota #11
For Sure:thumbsup: But mine certainly isn't as slow as the Kubota they're comparing it to;)Incidentally: my FEL is faster without a load than having it fully loaded, I offer a challange, just to see exactly how quick our loaders do operate, .... 1st test at idel speed, 2nd test at 1500 rpm. from the ground fully lift and curl and back down on the ground, Time this either by minutes or sec. which ever the case may be.;) I'll be back with my results later:)
/ Yanmar verses Kubota #12
27 seconds from floor to top of stroke and power down not float down idling, 20 seconds floor to top of stroke and power down not float @ 1500 with cold oil and cold engine well its in a warm shop so 50-60 degree oil fwtw. It will slow down considerably when the oil is hot least mine does.
Couldn't check curl speed because I have my SSQA pallet forks on and they would flip over backwards at the top didn't want to bend or dent anything.
I have the SC2400 in the vid @ 12 seconds at idle and 7 at fast engine speed thats smokin inho. The Kubota is pretty fast at fast engine speeds though gotta give it credit it is no slouch!
/ Yanmar verses Kubota #13
Wow! I think you have me on both, although I did curl the bucket under while full up and let it down while remained curled, 700 rpm's idle speed was 55 seconds, 1500 rpm's took 25 seconds also curled while all the way up, It take more time to curl than the lift/lowering speed, there is one point ( about half way through the curl) it speeds up, Mine FEL has no float so it's all power down,
I'll need to check for just lift & lowering speed,
OK Just checked without curl and the results are 32 seconds @ 700 rmp and 17 seconds @ 1500
rpm,..
I guess this means it took 23 seconds to curl when idling, and 8 seconds to curl when at 1500 rpm's,
which is 15 seconds different between the two speeds, ofcorse they'll be some reaction time to figure in as well:D I'm not sure how many GPM the pump produces, But I did install a new pump 3 years ago,
/ Yanmar verses Kubota #14
Oh my curl is real bad thats my worst action it would be painful to sit and wait on it too while timing it bet we are not as far off as you think. ;) :laughing: Oh and my idle speed test was @ 1000 sorry I was a bit to high rpm on that test.
/ Yanmar verses Kubota #15
Hmm.. wow do you have really big cylinders and a really low flow pump? the rating for my Kl351 are raise the boom from the ground to the stop fully is 3.6 seconds and power down 2.3 seconds... dump bucket 1 second, and retract bucket from full dump 2.3 seconds. While I have not put a stopwatch to it, these figures are pretty close.. to what I see. Hot or cold, does not vary much. Now my Kl351 is a tractor with a fairly healthy pump and small cylinders , because the same pump is used on the DK40se with larger cylinders to lift more weight, but it will slow down the response some as in 4.5 to raise boom and 4.8 to lower the boom. But 27 seconds to raise the boom seems like a lot to me.
James K0UA
/ Yanmar verses Kubota #16
I did see that video before I bought my Yanmar. I'm going to write up a 50hr review of my Yanmar LX soon, its sure has been great so far. I have only a few minor nit picks. I've moved plenty of full buckets of driveway material and it does it with ease. Most of the time I'm using the HST synchro throttle, so if I'm stationary I'll be operating the loader at idle. If I'm pushing into a pile and have the pedal down the rpms will be higher. Note, you can set the tractor throttle to idle at any RPM you want while using the syncro (pedal) throttle.
No, I'm not going to say my LX is superior to a Kubota, but I think I got more bang for my buck than a new Kubota. Note, I don't buy into that "resale value" horse apple stuff. If my "new" Yanmar lasts as long as all the "old" Yanmar models still going strong, then I'll be happy with my purchase.
/ Yanmar verses Kubota #17
Yeah Jim I agree it is slow and you are probably exactly right why. The thing I have to give Yanmar credit or not is they didn't really design these gray market tractors for aux hydraulics. The US spec Yanmars like the 3 numbered series (165,186,240,336 etc) were optioned with loaders and BH's so may well have bigger pumps I dont know for sure?
So we are asking probably more out of the pumps than they can deliver. I think my pump is 8-9 gpm and I know its 2250 psi I set the regulators all the same when I built my 3pt log splitter and my cyls are 2" btw.
/ Yanmar verses Kubota #18
James K0UA
I'm home in town so can't make that test until Thursday but I would say maybe 20 seconds lift and at least 20 seconds curl, on the big Great Bend loader on my (US) YM240. The tractor was apparently spec'd with Loader Ready HD front axle (adjustable width, probably the standard axle for some larger model) and next size larger front tires. But the pump is standard, labelled 7 cc's/rev. (I think about 4.3 gpm). The optional pump sold by Hoye is 9 cc's/rev. This is definitely a farmer's rig for intermittent use. For continual loader use on a construction site the slow speed would be intolerable.
Photos of typical use: 1 2 3 4
That last photo is pretty near the practical limit for this rig. The tires were imbedded in the ground to where I couldn't steer and it felt spooky top heavy with the tank swinging. The builder's plate on that tank says 650 lbs.
/ Yanmar verses Kubota #19
Hey, I've got one of those snowbear trailers pictured and I've put it through a lot, on both the highway and through logging roads. I have larger utility trailers, but if I had to keep one it would be that one. It just seems like the perfect utility trailer for my Jeep TJ and for transporting tractor implements.
My YM2002D: up and down 800rpm 38 seconds, full curl cycle 30 seconds
up and down 1500rpm 16 seconds, full curl cycle 12 seconds
My pump is rated at 10cc per revolution or about 6.34 gpm at 2400rpm
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40X6MJ464380 (A65563)
2021 Kenworth T880...
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
BushHog 2615L 15ft Batwing Rotary Cutter (A65640)
BushHog 2615L 15ft...
