anybody built a hydraulic powered post hole digger?
/ anybody built a hydraulic powered post hole digger? #1
Dongerosa
wellington ohio
7510 bota...RTV 900
pictures? motor spec's? cost to build...ideas?
/ anybody built a hydraulic powered post hole digger? #2
I have considered building one using a torque hub I picked up a while back. One of the hurdles is to keep it from mangling everything when it hits a big rock or something. Instead of a mechanical clutch or shear pin I was thinking of using an adjustable hydraulic pressure relief valve which would just bypass the hydraulic motor (torque hub) when the auger gets stuck.
/ anybody built a hydraulic powered post hole digger? #3
some just use a motor on the PTO gear box, and many times mount to the front end loader,
I would think a motor that ran at about 500 rpm and was in the 10 to 20 hp range would be more than capable, If working throught a PTO gear box,
and even smaller should work (as a lot of hand held diggers are only a few HP, 3 to 6 gas motors,
some depends on what your wanting to do, turn a 6 inch auger, or a 24" auger, and if it like digging asphalt or sand,
I thought about using a old combine hub reducing gear, with hydraulics one should be able to reverse it if you get it stuck, you will not be doing that with a PTO unit,
/ anybody built a hydraulic powered post hole digger? #4
/ anybody built a hydraulic powered post hole digger? #5
The combines I am failure with there usually a bull gear and a pinion, in a gear case,
the combine, use a lighter transmission and then the wheels are bolted to a reducing gear case, that takes the strain of the unit, Called the final drive,
my choice is that I have a old parts machine that I could use and the cost would be "Free"
picture from this site, Final Drive Gearbox for John Deere Combine Harvester, China Final Drive Gearbox for John Deere Combine Harvester, Manufacturer & Supplier
my brother in law, was going to just use a PTO gear box and mount a hydraulic motor on it,
ETA Full Size Auger Gear Box PHD-50
I see some just use a a direct hook up to a hydraulic motor,
Kanga Powerhouse Skid Steer Auger Post Hole Digger Attachment Drill with Bits | eBay
When I was considering doing this I was wanting to build a unit that would work a 24" to 36" auger for setting posts for a pole barn, (my SIL was starting to build pole barns and considered building to help him, (the power company was cheaper to hire than to build our own) so I never went much more than the planing stages, (besides discovering the seals leanking in the final drive I had would have needed to be replaced as on end they leaked, the drive was from a old MM/cockshut combine,
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
2015 Caterpillar Backhoe (A60352)
2015 Caterpillar...
CFG Industry ECAG QA Auger w/ Bits (A60463)
CFG Industry ECAG...
