Stick Welding Aluminum
/ Stick Welding Aluminum #21
I gave it another go this morning. I don't know why, but preheat made it easier to weld. The picture doesn't seem to do the weld justices, it looks better in person.:confused3:
The slag is still a beach to get off!
Keep at it Shield, you will make pro some day!:D .Seriously though it does look tied in to the base metal, so I guess it is welded pretty well.. did you consider taking a hammer to it and finding out?
/ Stick Welding Aluminum #22
Well I accidental dropped it on the floor and it didn't break, does that count?:laughing:
I didn't think about breaking it, so I went back out to the shop after reading your post.
2-blows with a 4-pound hammer!:eek:
/ Stick Welding Aluminum #23
yeah, I am thinking that this stick welding of aluminum is for the birds.
/ Stick Welding Aluminum #24
....I didn't think about breaking it, so I went back out to the shop after reading your post.
Out of curiousity: How many hammer blows would that particular joint taken to break say it had been welded with either tig or mig? (Reason I ask is that I have never welded any aluminum).
/ Stick Welding Aluminum #25
I figure if I ever need to weld aluminum then I simply may try it this way. While recommended practice is to use AC square wave and high frequency to tig aluminum (I do not have those): This fella is using plain ole DC scratch start tig torch and using the SMAW stick rods for filler (instead of normal tig filler wire). Supposedly the flux on the SMAW stick rods helps make up for the cleaning action that you are otherwise lacking by not having AC square wave or high freq. I am sure it is an improvisation, but I simply have very little need (actually zero need) to weld aluminum so do not even want to bother with a Teflon liner in my little mig and fighting the birds nests due to lack of spool gun.
(note: While this fella is using an inverter welder, any ole scratch start tig rig on a transformer would suffice for this method as well).
TIG Welding of aluminum with a DC inverter - YouTube
/ Stick Welding Aluminum #26
When I first got my Dynasty 300 7 or 8-years ago I was trying to figure out how to run it. I did some testing, but I can't remember the number of blows. But look at the top edge of the plate, it has some pretty good dents in it. And look how much the top plate is bent before breaking.
/ Stick Welding Aluminum #27
WOW! That's pretty interesting! But by the sounds of those welds, I'd like to see the end of his tungsten.
Here is a weld I made on DC with 100% helium.
/ Stick Welding Aluminum #28
WOW! That's pretty interesting!....
Glad you liked the video - had a feeling you would enjoy it. Actually the video below is the video that I intended to link first. It is from the same fella, but everything is explained better in this video. Explanations also found in the comments/feedback section too. He is using Argon by the way and not Helium. Impressive since most of us already have Argon on hand for our steel welding tig rigs so nothing special needed except the SMAW stick welding rods for filler.
Again an admitted improvise and maybe not the best solution for frequent user's or professionals but......I expect that my $45 tig torch and my $40 Miller Thunderbolt transformer arc welder could handle this improvisation just fine on those extremely rare occasions that I might need to weld aluminum in my back yard shop.
TIG Welding of aluminum with a DC inverter .THAT'S HOW I DO IT .wmv - YouTube
/ Stick Welding Aluminum #29
You just don't see many guys chipping slag when Tig welding!:D
In that video there were several views of his tungsten, didn't look contaminated at all, well no more than any other scratch start tungsten would be.
/ Stick Welding Aluminum #30
I had to join in the fun and give it a shot, I took it a little more serious than the last time it tried them. Heres some 3/32 alum stick filler at 75 amps. The rods were horrible, been sitting in a cabinet for years.
/ Stick Welding Aluminum #31
Mike you know what I noticed about the stubs from welding yesterday? I through them in a little plastic bowel, this morning the bowel had a little water in it! Also a stub I left on the welding table was so wet it left fluid on my hands.:confused3:
/ Stick Welding Aluminum #32
I know what your saying, the flux is like a hard yet soft brittle sponge, until you have to remove it :0 I did notice it comes off alot easier when it cools down tho. Ill check my bench tomorrow and look at the stubs. In a pinch tho I felt they would work, maybe not for long term, but I felt a little more confident with them after a little tuning.
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61573)
2010 Workhorse...
(1) 23X8.50-14 TIRE W/ 6 LUG RIM (A64280)
(1) 23X8.50-14...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
