Stumps under slab
   / Stumps under slab #1
Don in LA
Member
South Louisiana
1967 Ford 3000, 42 HP Diesel, 2WD
My son is planning a 30'X40' workshop with a concrete slab. He has cut down 3 pines from the site and one water oak. The trees range from 10 to 18" in diameter. He is debating whether to leave the stumps and place about a foot of fill over them, grind the stumps, or remove the stumps. Of course, leaving the stumps would be the easiest option but I was concerned about the stumps rotting and eventually leaving a void under the slab. The slab is being placed over sand---the entire area has about 15' depth of sand. Also, there is a 12" water oak which will be about 6 to 8 feet from the slab. I think that the roots could cause problems with the slab down the road. Opinions?
   / Stumps under slab #2
Lots of rebar and concrete thickness??
   / Stumps under slab #3
The price and/or effort of pulling three stumps is insignificant compared to the price and effort of building a 30 x 40 shop. I would remove them.
   / Stumps under slab #4
I would (and have) pulled the stumps under anything I build.
   / Stumps under slab #5
Unless you will have sufficient footings/piers to suppor the building and reinforcement to allow the slab to be supported on the foundation always remove any compostible materials. It is usually cheaper to remove than reinforce.
   / Stumps under slab #6
I had a backhoe remove the stumps when I built the barn. I would not build on top of the stumps, eventually it will cause problems.
   / Stumps under slab #7
Having burried stumps and built on top (just a shed), i can tell you that every piece of wood will become a void and lead to issues. Far better and cheaper to remove them now.
   / Stumps under slab #8
I would remove them. The last thing you would want is a void that could get filled with water that you'll need to deal with down the road.
   / Stumps under slab #9
Roots don't seek dry gravel under a building, they look for moisture. I don't see how roots from a tree that far away could be a problem. If it dies from the construction you might want to take it down so it doesn't fall on the building, but if it lives, hey that's more oxygen in your yard to breathe.
On the stumps I think grinding them down to the root line would be sufficient and less disruptive to the soil. If you pull a big stump, you're going to have to do a lot of compacting as you add the fill.
   / Stumps under slab #10
A few trees in the workshop may be handy for hanging stuff from!:D
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2012 FORD F-150 XLT (A50854)
2012 FORD F-150...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
