Let's see your welds...
/ Let's see your welds... #142
ok Guys try and welding tig up side down and havinig it x rayed thats what you have to do on power plants not bech welding
So your pictures are where exactly? :confused3:
/ Let's see your welds... #144
So what are you trying to say about the JD factory, exactly, James?? :laughing:
Sean
Sean, I don't know about the JD factory, but when I got done welding the hooks on the pads that the Kioti boys had welded to the top of my factory Kioti bucket, I stood back and decided my welds were better than the Korean guy did. Here see what you think.
/ Let's see your welds... #145
Now try welding it when you're lit on sake and have a nuclear reactor on the verge of meltdown across the strait...
Sean
/ Let's see your welds... #146
Sean
Are you saying he was in a hurry?:laughing:
/ Let's see your welds... #148
Sometimes those Korean guys don't worry so much about aesthetics as we do... although there's no reason a strong weld can't be pretty, and vice versa.
Sean
/ Let's see your welds... #149
Over 30 years ago, a guy who was trying to teach me to run a bead told me it should sound like ham. I know he meant bacon. Food in a frying pan gets confusing sometimes.:licking:
/ Let's see your welds... #150
Sometimes it's trying to hide all your welds that counts.
Here was a couple of projects I did just for fun and to practice my painting skills.
2ND LAMP 021.jpg2ND LAMP 030.jpg2ND LAMP 037.jpg2ND LAMP 061.jpg2ND LAMP 062.jpg2ND LAMP 077.jpg2ND LAMP 081.jpg2ND LAMP 090.jpg2ND LAMP 092.jpg2ND LAMP 096.jpg2ND LAMP 097.jpg2ND LAMP 098.jpg2ND LAMP 099.jpg2ND LAMP 100.jpg2ND LAMP 106.jpg2ND LAMP 118.JPG2ND LAMP 124.JPG2ND LAMP 132.JPG2ND LAMP 135.JPG2ND LAMP 138.JPG2ND LAMP 139.JPG
1st lamp
20100905.jpg2012 floor lamp 014.JPG2012 floor lamp 016.jpg2012 floor lamp 017.JPG2012 floor lamp 021.JPGlamp pics 029.JPGlamp pics 030.JPGlamp pics 036.jpglamp pics 037.jpglamp pics 044.jpglamp pics 048.JPGlamp pics 050.jpglamp pics 051.jpg
/ Let's see your welds... #151
Here is a band file belt cutter I made.
The abrasive belts are available in wider widths for belt sanders that are cheaper that the precut belts for the band file.
So I cut my own for a lot less money.
Uses a standard razor blade spaced at the correct cutting width and all you have to do is rotate the belt around and your done.
I cut up about 3 packets worth on one blade and it it still will cut more.
this would work for the floor model sanders if you can purchase the belts the same length.
Band File 005.JPGBand File 006.JPGBand File 008.JPGBand File 009.JPGBand File 010.JPGBand File 011.JPGBand File 012.JPGBand File 013.JPGBand File 014.JPG
/ Let's see your welds... #153
You sir are one fart smeller.........sorry smart feller!!!! I do very much admire your handy work sir. Lots of good ideas.
Chris
/ Let's see your welds... #160
I was going to ask if they were AR. Question, shouldn't they be going the other way? With the curl of the bucket? Or are you expecting the dirt to fill the voids, and protect the bucket?
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2020 HAULOTTE 3522A TOWABLE ELECTRIC BOOM LIFT (A65053)
2020 HAULOTTE...
2017 VOLVO SD115B PADFOOT ROLLER (A65056)
2017 VOLVO SD115B...
WHOLE PART ROOM (A68842)
WHOLE PART ROOM...
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
